Old Aug 09, 2014, 03:14 AM
Joined Aug 2014
A Better Choice:HKPilot32 Autonomous Vehicle 32Bit Control Set w/ Power Module
HobbyKing's support is poor compared with 3DR and their shipping is not so good! But, they do offer a better quality than those from EBay or Goodluckbuy. The quality of the accessories is completely different from the similar or competing products that you can find in this forum. Anyway, all the countries that 3DR can't export to can get their flight controllers now.
The HKPilot32 is the next step in FC hardware with its powerful ST micro 32bit ARM Cortex core and massive I/O support. The HK Pilot32 is one of the most advanced autopilot systems available with support for almost any type of vehicle from a moon rover or a multirotor aircraft, even a submarine! Designed by the PX4 open-hardware project, it is supported by a number of development communities making this one of the most flexible and reliable platforms for vehicle control, with many features and functions sure to be available in the future.
With powerful integrated multithreading NuttX RTOS, a Unix/Linux-like programming environment, completely new autopilot functions, auto detection and configuration of peripherals and a seamless transition from a HK Pilot Mega or APM, these advanced capabilities remove the limitation to your autonomous vehicle.
Features:
• Advanced 32 bit ARM Cortex® M4 Processor running NuttX RTOS
• 14 PWM/servo outputs (8 with failsafe and manual override, 6 auxiliary, high-power compatible)
• Abundant connectivity options for additional peripherals (UART, I2C, CAN)
• Integrated backup system for in-flight recovery and manual override with dedicated processor and stand-alone power supply
• Backup system integrates mixing, providing consistent autopilot and manual override mixing modes
• Redundant power supply inputs and automatic failover
• External safety button for easy motor activation
• Multicolor LED indicator
• High-power, multi-tone piezo audio indicator
• microSD card for long-time high-rate logging
Specs:
Weight: 33.1g
Microprocessor:
32-bit STM32F427 Cortex M4 core with FPU
168 MHz/256 KB RAM/2 MB Flash
32 bit STM32F103 failsafe co-processor
Sensors:
ST Micro L3GD20 3-axis 16-bit gyroscope
ST Micro LSM303D 3-axis 14-bit accelerometer / magnetometer
Invensense MPU 6000 3-axis accelerometer/gyroscope
MEAS MS5611 barometer
Interfaces:
5x UART (serial ports), one high-power capable, 2x with HW flow control
2x CAN
Spektrum DSM / DSM2 / DSM-X® Satellite compatible input up to DX8 (DX9 and above not supported)
Futaba S.BUS® compatible input and output
PPM sum signal
RSSI (PWM or voltage) input
I2C®
SPI
3.3 and 6.6V ADC inputs
External microUSB port
Included:
HK Pilot32 autopilot
Buzzer
Safety switch button
10s power module with XT60 connectors and 6-position connector cable
Extra 6-position cable to connect a GPS+Compass module
Micro USB cable
SD card
Mounting foam
3-wire servo cable
I2C splitter module with cable
Note: HK Pilot32 is a PPM-input autopilot, which means that it gets RC input from a single cable to the receiver, either via the PPM port, the Futaba S.BUS port, or the special satellite receiver port for Spektrum gear. Most modern RC receivers allow for PPM output, but some, such as non-S.BUS Futaba receivers do not.
*PX4/Pixhawk is an independent, open-source, open-hardware project aiming at providing a high-end autopilot to the academic, hobby and industrial communities (BSD licensed)
**The reference to APM refers to the ArduPilot project, a family of open source autopilots based on the Arduino open source computing platform, developed by 3DR and the open source community. It consists of a choice of ArduPilot Mega (APM) electronics and a range of free software versions for different vehicles and is governed by an open source creative commons license.
http://www.hobbyking.com/hobbyking/store/__55561__HK_Pilot32_Autonomous_Vehicle_32Bit_Contr ol_Set_w_Power_Module.html
Useful or Interesting Links:Photos and Videos:
B.Andson is offline Find More Posts by B.Andson
Old Aug 09, 2014, 09:50 AM
Joined Jul 2008
Does this version include the backup watch battery that witespy left off his RTFhawk 2.4.3 ?
teslahed is online now Find More Posts by teslahed
Old Aug 09, 2014, 10:21 PM
Joined Aug 2014
They do have the backup watch battery included.
Old Aug 09, 2014, 10:38 PM
Joined Aug 2014
Their shipping has been improved ,they now cooperate with DHL.
Old Aug 12, 2014, 09:02 PM
Joined Aug 2014
http://www.hobbyking.com/hobbyking/s...er_Module.html
Old Aug 14, 2014, 01:18 PM
WZ9V, AMA 409852
Joined Jan 2007
Which of the several GPS pucks they offer would be the best choice to use with this?
dfruehwald is online now Find More Posts by dfruehwald
Old Yesterday, 01:56 AM
Joined Aug 2014
HK neo-7m
Old Yesterday, 11:30 AM
WZ9V, AMA 409852
Joined Jan 2007
Cool, thats the one I got. They imply it does both GPS and Glonass but from what I understand you can't do them simultaneously which is what I had hoped for.
Originally Posted by B.Andson View Post
HK neo-7m
For Sale Pixhawk Advanced Autonomous Vehicle Control flyhigh300 FPV Equipment (FS/W) 4 Jul 31, 2014 08:37 PM
For Sale Alexmos 32bit W-BGC Pro High Power 3 Axis Brushless Controller RC Rotors Aircraft - Electric - Multirotor (FS/W) 7 Jul 19, 2014 01:04 AM
Help! Autonomous Vehicle (Motor? Battery? Frame?) regnar86 Robotics 1 Jun 25, 2014 02:53 PM
Wanted 3-axis Alexmos/Basecam controller (32bit or w/3rd axis board) Endlesslag Aircraft - Electric - Multirotor (FS/W) 3 Jun 19, 2014 10:59 AM
Discussion FPV system for autonomous vehicle Rchapps FPV Talk 10 Dec 15, 2013 08:58 PM
