Old Mar 10, 2013, 02:13 PM
I need more SWAG!
RC30Flyer's Avatar
United States, MO, St Louis
Joined Jan 2012
Question
Trex 500 which ESC should I consider?
I recently had a failure of the Align 70amp ESC. I'm looking to replace it with the ESC from the Blade 500x, Castle Creations Phoenix ICE 2 80amp HV, or the E-Flite 80amp PRO. Thoughts, recommendations before I purchase one? Thanks, Jeff.
RC30Flyer is offline Find More Posts by RC30Flyer
Old Mar 10, 2013, 02:31 PM
wlee1017's Avatar
Joined Jul 2011
If you are running 6s for 500E, I suggest YEP 80A 6s esc, only $42.00. I used align, CC ice esc before too but YEP outperform and best buy..
I don't think you use 12s for 500E, is so then go with YEP 80A HV 12s but cost $107.00
wlee1017 is offline Find More Posts by wlee1017
Old Mar 10, 2013, 06:45 PM
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
Yes Align 70amp ESC's suck..I went thru 3-4 of them before i threw in the towel and went with hobbywing 80amp platinum pros..These are trustworthy esc's. So much so i now use them in all my heli's and planks. http://www.ebay.com/itm/ePacket-USA-...item3f1e6ae158
Those yep's are also very good esc's from what i understand. I have yet to hear one burning on anyone.
Also from what i understand Align has replaced those 70amp esc's in their 550 kits with c.c talon 90's...To date i have heard of 2 burning..Food for thought anyhow. -IMO- your best off with a yep or hobbywing.
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Mar 10, 2013, 07:09 PM
I need more SWAG!
RC30Flyer's Avatar
Joined Jan 2012
How long does it take to get those from Hong Kong???
Old Mar 10, 2013, 08:16 PM
wlee1017's Avatar
Joined Jul 2011
Usually, it takes 7 to 14 days to shipped from HK global warehouse. Unfortunately, YESP 80A 6s esc out of stock from global warehouse but you may slect USA warehosue from left pane and order same item. As you are in USA, you may select usps priority mail as shipping ,methoad and takes 2 to 3 days.
Old Mar 10, 2013, 09:22 PM
I need more SWAG!
RC30Flyer's Avatar
Joined Jan 2012
So this ESC is better than the stock Align 70 amp? I just don't want any issues running 3 digital cyclic servos, gy401 gyro, and Futaba digital tail servo.
Old Mar 11, 2013, 12:07 AM
wlee1017's Avatar
Joined Jul 2011
I have no issue with my YEP (HV) esc 45A, 80A, 100A but burnt up 2 x CC ICE HV esc & 1 x Align esc before.
It draw my attention that you need to check if futaba servo support 6v. Most Futaba servo support 4.8v only. But YEP 80A esc built-in BEC is 5.5v 6A output and you may need step down voltage regulator for Futaba servo.
Old Mar 11, 2013, 02:07 AM
Where's the swimming pool
spykez's Avatar
Joined Jul 2011
YEP's are YGE clones, and so far, my sample 1 of 1 (YGE45A on a Blade 450) is great, runs as good so far as my YGE's on the msh's I have so far.
Be aware: some have commented the soldering job is shoddy on some esc's. So I suspect that the QC might not be as good as YGE but I've not had any issue with the 45A I'm running.
My own judgement on the 'greyness' of the issue of this esc being a rip off is this - I will fly real YGE's on the heli's I value (my msh's) mainly to salve my conscience.
Be it as it may, this represents tremendous value IMHO for those who cannot afford the real thing. Get the program card with it. Governor on this thing is great.
spykez is online now Find More Posts by spykez
Old Mar 11, 2013, 05:23 PM
mhills51's Avatar
kansas city
Joined Feb 2007
I agree with the yep or Himodel Ice (same) but if you are going main stream I would go with the CC talon 90 because of it's bec.
mhills51 is online now Find More Posts by mhills51
Old Mar 14, 2013, 02:04 PM
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
I have a ice 75 on mine with bec pro , talon would be a better bet , it has both , im using a talon on my gobblin 500 ...
Dennis Everett is offline Find More Posts by Dennis Everett
Old Jul 02, 2014, 09:11 AM
Joined Jul 2014
I have a 500 ESP converted to DFC (6s, 500MX, BeastX) that I've been flying nearly every weekend for over 4 years, doing medium/hard 3D for the past 2 years... and it STILL has the original stock Align 70amp ESC! (Original, as in the one that came in the combo with the heli.) Never had a single issue with it, ever, even on days when it was 100 degrees outside. Sorry, but you can't sell me the line of BS that the Align ESC is junk. If you're burning them up, then you're doing something wrong.
KCTrex is offline Find More Posts by KCTrex
Old Jul 06, 2014, 11:11 PM
BieneFlyer's Avatar
Australia
Joined Mar 2013
I cooked the Align 70amp esc in my FB Trex 500.
It happened whilst I was fitting & testing a Co Pilot II. I think a servo went beyond limits and overloaded the esc?
Anyway, I have replaced it with the Talon 90 & all good so far.
Btway, the coloured smoke & stench was something to behold. Stunk the whole house out & woke everyone up !!
BieneFlyer is offline Find More Posts by BieneFlyer
Old Jul 07, 2014, 01:42 AM
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Yes, allowing a servo to go hard up againts it's travel limit will burn up the BEC in the ESC very quickly (dont do it!).
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Discussion Which of these motors and ESCs should I use for a quadcopter? Nathan-d Multirotor Talk 6 Feb 18, 2013 09:48 AM
Discussion Hobbyking 500-helis. Which model? Or just get a Trex? WiseDuck Electric Heli Talk 26 Jan 17, 2013 02:49 PM
For Sale FS or FT Trex 600N Pro, will consider 500/550 FBL set ups. Druss Aircraft - Fuel - Helis (FS/W) 0 Aug 13, 2011 05:53 PM
Discussion Which TREX should I learn on, 450 or 500 RajiBoy United Kingdom 3 Jun 16, 2009 04:48 PM
Discussion Which TREX should I learn on, 450 or 500 RajiBoy Beginner Training Area (Heli-Electric) 18 Jun 14, 2009 10:56 PM
