Old May 02, 2015, 11:12 PM
Bmurry226 is offline
Find More Posts by Bmurry226
Joined Apr 2015
How do I channel Elapor?
I just got my parkmaster 3d in and was fixing to brace it with carbon fiber per this website. I know some of the slots are already cut for the fiberglass but how do I create the channel for the 1.5mm rod on the tail? I haven't gotten the 8mm rod yet because Winging Wayne mentioned he puts in 1x3mm flat strip in the wing so I'm considering doing that instead of the 8mm rod (should also be easier to cut). But for future reference, how would you cut the channel for the the 8mm rod too?
Bmurry226 is offline Find More Posts by Bmurry226
Old May 03, 2015, 08:22 AM
Wingin' Wayne is offline
Find More Posts by Wingin' Wayne
I like the violent stuff!
Costa Mesa, CA
Sharp exacto blade or scalpel. Good luck.
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old May 03, 2015, 08:58 AM
Joined Apr 2015
That would cut a line but not a channel right?
Old May 03, 2015, 08:13 PM
spastic is offline
Find More Posts by spastic
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
you can use a soldering iron, i have a 25watt one that i ground the tip flat so it makes nice carbon channels or you can use the mills available for Dremel, run the mill along a wooden strait edge.
http://www.amazon.com/Carbide-Dremel...ds=dremel+bits
spastic is offline Find More Posts by spastic
Old May 03, 2015, 08:22 PM
Joined Apr 2015
Old May 04, 2015, 07:06 AM
Costa Mesa, CA
If you are going to use flat c/f you want a line for round you want a channel. A SHARP blade and metal straightedge are the perfect tools to install flat c/f.
Discussion How do I add a few channels to a 72MHz Transmitter? Rockworthy FPV Equipment 9 May 30, 2014 04:52 PM
Discussion How many channels do you use? Bob A Electric Plane Talk 17 Mar 05, 2014 09:09 AM
Question How many channels do I need? phantom_alex Multirotor Talk 0 Feb 28, 2014 01:16 PM
Help! How do i get mah channels set up?? Jonah.H FPV Talk 1 Feb 09, 2014 08:32 AM
Discussion How many channels do you need? clonedkorl Multirotor Electronics 4 Dec 06, 2013 07:25 PM
