Old Apr 30, 2015, 05:38 PM
dhal22 is offline
Find More Posts by dhal22
United States, GA, Alpharetta
Joined Dec 2007
Originally Posted by doxilia View Post
Nice bearings Mike. If you find another source, please let us know. Worth picking them up as boring even with a drill press is tedious and tricky.
David
Mcmaster Carr. They sell numerous sizes of epoxied tubing.
dhal22 is offline Find More Posts by dhal22
Old Apr 30, 2015, 06:51 PM
Jet_Flyer is online now
Find More Posts by Jet_Flyer
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
Thanks David but I'm having a hard time finding it on the site.
Jet_Flyer is online now Find More Posts by Jet_Flyer
Old Apr 30, 2015, 06:57 PM
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
I finally got around to weighing the airframe, with engine, radio gear, etc. With everything, less the pipe header, main servo mounts, pushrods, lower wing fairing and of course covering and finish work, it is 5.8 pounds. It has a wing area of about 660 square inches, so it should be a lot of fun with the OS 61SF ABC-P in the nose.
To be continued ……
Old Apr 30, 2015, 08:24 PM
R_G is offline
R_G
Find More Posts by R_G
R_G
Wanna Hover? Fly a Heli!
R_G's Avatar
United States, PA, Farrell
Joined May 2010
Mike,
Search this item number: 6394A16 on McMaster-Carr's web site. 1/4" I.D. x 5.8" O.D. Garolite(G-10) tubing. Kind of pricey though.
Ralph
R_G is offline Find More Posts by R_G
Old Apr 30, 2015, 09:22 PM
AKA 8178
Jet_Flyer's Avatar
Joined May 2004
Originally Posted by R_G View Post
Mike,
Ralph
Yikes Ralph. Looks like it might be the same stuff and I better be careful how use it!
Old Apr 30, 2015, 09:39 PM
doxilia is online now
Find More Posts by doxilia
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
$1.50/inch of the stuff is not too too bad. One only needs about an inch/bolt in the back or less.
The front bolts are the expensive ones where sometimes one needs 2" bolts (e.g., The Tipo)!
$6 in G-10 for bolt bearings is somewhat expensive so I take my first sentence back...
David
doxilia is online now Find More Posts by doxilia
Old May 01, 2015, 04:17 AM
Roguedog is online now
Find More Posts by Roguedog
Roguedog's Avatar
United States, CA, Norco
Joined Feb 2007
edit
Roguedog is online now Find More Posts by Roguedog
Old May 01, 2015, 10:44 AM
lfinney54 is offline
Find More Posts by lfinney54
United States, ID, Kuna
Joined Feb 2008
phenolic tubing is available as well and makes a excellent and much lighter substitute, it is also much easier to drill and sand..but the dust is toxic use goggles and mask please!
lfinney54 is offline Find More Posts by lfinney54
Old May 01, 2015, 03:39 PM
Roguedog's Avatar
Joined Feb 2007
R_G the part number you looked up was for fire proof Garolite.
I got looking around and they had 10 different versions of Garolite McMaster -Garolite versions . Look up this part number 8527K212 McMaster it's called Hard Garolite and is only $12.36 for a 40in length.
Bryan
Build Log Clausxpf, F-8 Crusader, Alpha-build jweber009 Scratchbuilt EDFs 231 Jun 25, 2014 03:24 PM
Build Log BritKit Build Off 2012 - Mercury Crusader RFJ Vintage & Old-Timer Designs 66 Jul 28, 2012 06:34 AM
Build Log When You're Out Of F8... The Crusader Build Thread GGRN Pusher Prop Jet Models 390 Nov 23, 2009 06:51 AM
Discussion F-8 Crusader jetset44 style build with Video agriebel Pusher Prop Jet Models 284 Aug 12, 2009 07:32 AM
Discussion Profile Super Crusader Build burkefj Pusher Prop Jet Models 17 Feb 21, 2008 08:58 PM
