Old Feb 09, 2016, 12:00 AM
RcPro97 is offline
Find More Posts by RcPro97
RcPro97's Avatar
Joined Nov 2014
Dirt cheap sloper options. First time sloper
Hi everyone. I'm wanting to get into sloping. I have some hills that not too far that my rc club slopes from. One of the biggest appeals for me is that I should be able to do it for almost free. And and not have to worry about the massive cost some of the powered flyers have. I also love the idea of being able to fly for ages, without the need for power. And lightweight planes means less damage
Here's a few ideas I have about how to to it.
Assasin 37" wing. This one was given to me in bad shape. Probably should be the end of it's life. Don't have any electronics. But I was thinking glue it back together, throw in some servos and have a sloper for the price of two 9grams and a receiver. Great thing about this is I would not care if it was destroyed, or got lost forever. It would be the preferred rig because it would be very easy to get going.
Flite test versa, or might mini wing. Could always go to the craft store, buy some foam and make myself a versa wing or mighty mini.
I also have a old super cub wing. I could use a carbon spar as a fuselage and some scrap foam as a horozontal/vert stabiliser.
Bixler. This would be least preferred because It's my main aircraft. However it's been sitting with a dead ESC for awhile now untill I get round to fixing. I dont particularly like the idea of using it for this. But I could If I don't have anything else.
What do you think about the idea of a total noob trying to slope without a motor, and without any knowledge of sloping. I'm going to scope it out tomorrow as to where to fly, but I think it's reasonably easy to rescue aircraft if they go down there. I would say I am intermediate at flying. By no means a expert, but not a total beginner either.
RcPro97 is offline Find More Posts by RcPro97
Old Feb 09, 2016, 12:46 AM
The Flyin Beardo is offline
Find More Posts by The Flyin Beardo
The Flyin Beardo's Avatar
United States, OR, Albany
Joined Sep 2015
i was just where you were a few months ago...you will love slope soaring and wondered why you waited so long to try it...if you've got some rc guys who already slope soar see if you can get one of them to go with you cause its always better with more people...but if not, flying alone is still fun because you get the sky all to yourself and dont have to share
if you've got the assasin id say glue and cover it with 5mil laminate film if you've got it and it will last a long time...ive just covered my first epp wing with it and WOW its strong.
otherwise making the FT versa wing is an awesome idea to do for sure... ive made 3 of them for the slope and 2 of them have been crashed several times and nose dived into the hill very hard and are still flying great...there is some pictures below of them...the blunt nose has a slower roll rate so i added a motor to it but still fly it on the slope...by the way the FT wings like to be flown in 10-40mph winds.. i fly mine with just a 1300 3s in the nose for power supply and weight along with a few pieces of lead wheel weights wrapped in foam and glued in the tip of nose to get the CG right....last weekend i flew for 5 hrs off of one battery and still had plenty of juice to fly an electric plane.
also in my opinion the wings are the best for learning to slope soar with because if you crash there isnt alot that can break besides a servo...on a regular plane if you crash you have to worry about breaking the fuselage in half or wing, or tail, or rudder....so $2 worth of DTFB is worth the learning curve.
The Flyin Beardo is offline Find More Posts by The Flyin Beardo
Old Feb 10, 2016, 08:42 PM
goldguy is offline
Find More Posts by goldguy
flyin' fool
goldguy's Avatar
Vancouver Island, Canada
Joined Jul 2003
With sloping the airfoil is everything, start off with a proper design for success.
Check this one out.....................
http://www.google.ca/url?sa=t&rct=j&...13943164,d.cGc
goldguy is offline Find More Posts by goldguy
Old Feb 11, 2016, 02:33 AM
RcPro97 is offline
RcPro97's Avatar
Joined Nov 2014
Looks awesome. I've started my Ft versa build I've ordered another receiver an a bunch of servos, also got some batteries that need to be shipped by boat, so it's going to be a longtime considering that it already takes 3 weeks for most things to get to me by air.
As for my assassin rebuild I found some servos with broken teeth on the main gear. So I turned the pot inside by 180 and cutoff the end stop. Super dodgy but getting a replacement gear set was going to take me 3 weeks. I used a dead ESC as a bec. And I pumped the massive crack through the middle of the wing with glue and taped it. I should really look at giving it a nose job but I kinda like the idea of building something this terrible . My versa wing is going to replace it soon so I cant put the effort in.
Here's a picture of the assasin, or what's left of it. tried chucking it off the hill and it flew well sorta. However had to give it a tonne of up elevator to keep it airborne, eventually I just would run out of airspeed. I suspect I haven't got the cg quite right. Might take it to a feild on a calm day chuck it and see what it does.
Old Feb 11, 2016, 12:08 PM
Joined Sep 2015
wow...that is pretty beat up...it looks like you would be better off cutting out the center section and replacing it with a new chunk of foam...lol... most wings need some up elevator from the beginning so make sure you have it trimmed in first... CG is very important so id look it up and find out what its supposed to be for that wing and see if you've got it right...you can just toss it in your yard and it should glide for at least 10-20ft smoothly before landing to see if you get it right, or if you need to trim it more.
its good to hear your trying out the versa wing as you wont be dissapointed with it...i would at least install the servos on top like i did on my "red" wing so they are easier to replace compared to the FT design where they want them inside the wing with just the arm exposed... i just had to replace a servo cause i was combat fighting with another FT versa and was so glad i had it on top so i didnt have to cut up my plane i just had to cut my hot glue and pull it out.
Old Feb 11, 2016, 06:47 PM
BDOG1 is offline
Find More Posts by BDOG1
Held by Grace
BDOG1's Avatar
Upstate New York
Joined Apr 2006
RC - I would echo what has been suggested :
When I started sloping I built my own gliders, Fanfold wings, kf step types ect.
I had very limited success ,some days I would get a extended flight a lot of the time just a lot of trips up and down the hill.
Problem is just because you have wind in your face doesn't mean there is lift on the hill you are on for your glider to fly, not all hills produce good lift .
With no one else flying you have no one else to judge or receive advice
from.
If you hook up with others that are already soaring/sloping you can avoid a lot of wasted time and effort ,you might find one of them has a beater that needs a little TLC for little or nothing.
Maybe there isn't anyone in your area [there wasn't for me]
If you start with a design that you know fly's well , you can ask for advice on cg or servos or weight and people who all ready have experience with it can help you.
Good Luck and stay with it ,You will not be sorry- slope soaring is awesome !
BDOG1 is offline Find More Posts by BDOG1
Old Feb 11, 2016, 07:50 PM
RcPro97 is offline
RcPro97's Avatar
Joined Nov 2014
Yea, there's a few people who slope in my area. I found this video of the same hills
Fast Dynamic Soaring in Christchurch NZ (14 min 48 sec)
The wind hasn't been going the right way recently to fly off that side of the hill. I've been looking but cant work out how to get to the same spot anyway. I might post on some local forums and know if anyone can give me what times they fly. So I can go along and watch.
Maby the guy at the LHS knows. I notice he has what looks like his personal models tied to the ceiling of his store. Some of them look like slopers..
Old Feb 13, 2016, 02:15 PM
timbuck is online now
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
Hi rcpro. ( what your name )
Plenty of flyers around your area. Get into to contact wit Alex he is a great guy and one of the best flyers on the planet. He knows all the flying sits for front side and DS. He is alway looks for guys to take along DSing to teach and to help with radar gunning etc. every christmas they have a NZ slope fest , check threads started by Alex and you will find a gold mine of info.
Tim
Flick Alex a PM
Here is one of his threads.
http://www.rcgroups.com/forums/showt...537633&page=72
timbuck is online now Find More Posts by timbuck
Latest blog entry: More colours
Old Feb 13, 2016, 04:56 PM
AirspeedNZ is offline
Find More Posts by AirspeedNZ
AirspeedNZ's Avatar
North Island of New Zealand
Joined Jan 2009
Inexpensive slope trainer
You could always try a 3D foam trainer to begin with.
AirspeedNZ is offline Find More Posts by AirspeedNZ
Old Feb 15, 2016, 12:34 PM
Airboatflyingshp is offline
Find More Posts by Airboatflyingshp
Airboatflyingshp's Avatar
B'ham UK
Joined Oct 2005
Or a SPAD design..........
Airboatflyingshp is offline Find More Posts by Airboatflyingshp
Old Feb 23, 2016, 10:22 PM
RcPro97 is offline
RcPro97's Avatar
Joined Nov 2014
Thanks everyone. My names David btw. I've seen Alex is active on some facebook pages. So might sent him a Pm when I've got my rig sorted. Anyway this is what I've been working on. I made card templates and poke holes in the foam at key places using pins. I figured that I might want to make a few of them .
My sisters mates were around last weekend, so I was up at 3am cutting all the pieces because I couldn't sleep . So I've just finished folding the wings today, and now waiting for a bulk order of servos from HK before I get it in the air. I'm thinking about cutting out a compartment for the battery to sit. since it's pretty low power I might make up a 2s pack from some old laptop cells, make up the rest with weight. That way it's got it's own pack so I don't need to worry about stealing my miniquad batteries to run it.
Old Feb 25, 2016, 06:23 PM
bluefork is offline
Find More Posts by bluefork
Thermals are cool.........
bluefork's Avatar
meridian, idaho
Joined Sep 2005
Build a pibros. The plans are on the internet for free.
bluefork is offline Find More Posts by bluefork
Old Feb 25, 2016, 06:26 PM
parajared is offline
Find More Posts by parajared
no guts no glory
parajared's Avatar
United States, AZ, Prescott
Joined Oct 2013
Alula and Weasel clones
http://www.rcgroups.com/forums/showthread.php?t=1391999
parajared is offline Find More Posts by parajared
Old Feb 26, 2016, 12:14 AM
Joined Sep 2015
RcPro97 aka david.... your flying wing looks like its coming along nicely... i just cut a door just in front of the spar on the bottom side and its about 5"x3"... i cut three sides and left the front solid then hinged it open...i did it that way so if the door didnt stay shut the wind would keep it shut by pressure instead of flying open and causing lots of drag if it opened with the hinge at the back...also i use a 3s battery but it still required some weight... i wrapped it in some foam and hot glued it in the nose...
Old Mar 10, 2016, 10:19 PM
RcPro97 is offline
RcPro97's Avatar
Joined Nov 2014
Thanks guys for the help. Almost finished the build, I'm wanting to cover it, but it's super expensive from the LHS, and the shipping on the stuff is like $30 us to get it online. My best option is looking like banggood, but even then it's not great. Anyone know what the best option in NZ is?
I might cover it with tape, or not worry about it. What do you think?
Sold Dirt Bike riding gloves Cheap 10$ each shipped MIKEYOUR Non R/C Items (FS/W) 0 Jun 15, 2015 12:14 PM
Discussion First Time Sloper, Long time listener! MAX FISCHER Slope 14 Nov 12, 2010 05:15 AM
For Sale dirt, dirt cheap. ARF, crashed MANY times, LOL, BAE HAWK Eibo Morakinaga Aircraft - Electric - Jets (FS/W) 2 Jul 03, 2006 03:22 AM
It's that time of year again! Dirt cheap parkies! Thomas Manson Parkflyers 17 Mar 29, 2005 11:59 PM
Commercial Jets Dirt Cheap "AirCADkits" First Time Offer! gbagley Product Announcements 0 Jul 31, 2004 06:20 PM
