Old Dec 08, 2015, 08:05 PM
bufordbob is offline
Find More Posts by bufordbob
United States, AZ, Goodyear
Joined Nov 2011
Question
Ziroli DR-1 Electrify
Looking for some power plant and esc,battery,prop recommendations.
Flew this plane for many years with a Quadra 35 now getting ready to electrify,for those that don't know this is a Fokker Triplane,63" top wing,weighs approx 13 lbs,has tons of parasitic drag and 3.25 wings. Any thoughts recommendations ?
TIA
Bob
bufordbob is offline Find More Posts by bufordbob
Old Dec 09, 2015, 11:11 AM
tlh101 is online now
Find More Posts by tlh101
FICKLE FLYER
tlh101's Avatar
United States, NM, Elephant Butte
Joined Dec 2002
I did this conversion several years ago, with a 160 size motor on 6s. Used a 22 x 8 prop. I am away from my computer for about a week, so don't have the pics available to post, but I may have done a conversion thread here on RCG. You can try a search to find it, if not, when I get home, I will post the pics.
tlh101 is online now Find More Posts by tlh101
Old Dec 09, 2015, 08:22 PM
Joined Nov 2011
Dr-1
Would love to see some pictures and more specs on the setup i.e..motor,batteries,esc etc,etc. Tried to do a search here for your conversion couldn't find it.
TIA Bob
Old Dec 09, 2015, 10:44 PM
Joined Nov 2011
tlh101,
found the conversion article,have a question on the motor,the one you mention is not on HK anymore and the other one they have has a different kva.do you think I can use aE
Flight Power160 with 245KV spinning the same prop? BTW was that prop an electric or just a regular gasser prop?
Bob
Old Dec 10, 2015, 05:52 AM
adamtc is online now
Find More Posts by adamtc
adamtc's Avatar
Southampton ,England
Joined Oct 2006
My Flair DR1 uses a G160 turning a 20/8 prop. 245kv
10 cell lipos ( 2 x 5000 mah , 5 cells ) , 90amp HV Esc.
I also have an AXI 5330 /18 motor which is pretty similar in size but way more grunt!
adamtc is online now Find More Posts by adamtc
Old Dec 10, 2015, 08:19 AM
FICKLE FLYER
tlh101's Avatar
Joined Dec 2002
I don't remember what Kv is in mine,and I can't find my thread on my phone. That's all have access to until next week.
Old Dec 10, 2015, 09:40 AM
Joined Nov 2011
Adamtc, Isn't the Flair a larger model? 70+" vs 63" on the Ziroli.
Trying to cut down on the number of cells tlh101 used 1-6s 5000mah @20c.
Old Dec 10, 2015, 09:43 AM
Joined Nov 2011
tlh101 your conversion showed turnigy 63-64 280kv
T can try to post the conversion thread on here to save time.
Bob
Old Dec 10, 2015, 09:51 AM
Joined Nov 2011
http://http://www.rcgroups.com/forum...rsion+electric
Here is the link to the conversion article
Bob
Old Dec 10, 2015, 12:45 PM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
quick look at Hobbyking reveals several motors that should be capable of flying theDr-1 . There's a G160-245kv, a G160 - 290kv, a G110 -295kv, and SK3 6364-245kv ,and a SK3 6364- 213kv.
The lower kv motors would use 22" props while the higher kv units would be likely limited to 20" or so on 6S.
If your using wooden props, either gas or electric will work in these larger sizes, the lectric advantage is slightly lighter, a little higher rpm, with maybe a slightly lower amp draw.
At 13lbs AUW, this plane should fly quite scale with 1500watts/70a on 6s. fwiw Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Dec 10, 2015, 03:45 PM
Joined Nov 2011
Doug,
Well getting more confused now. Have aE Flight Power 160 on the shelf,the specs read 245KV and the writeup says 9-10 cells with a 20x10 max prop,would love to use this motor on a 6s setup so I wouldn't need a CC HV esc,could use a Talon 90 with built in bec . Would use a 22-8 wood gasser prop. Is E Flight covering their bets with such a conservative spec sheet?
Bob
Old Dec 10, 2015, 06:32 PM
Joined Oct 2008
9-10 cells on the 160 would likely produce something in the neighborhood of 2500watts. I've seen several people use them beyond that. Your looking for 1500 on 6s, it will take a large prop with good pitch to get there ,, but at much lower rpms. Assume the motor is 80% efficient under load, so a 245kv motor will be turning approx. 196rpm for each volt. At 10s your motor will turn 7252 at 37.5volts also under load. The 6s system will turn the prop only 4214rpm at 21.5volts loaded. You use a prop that takes the motor to 1500watts. or 69A, all well within safe limits for an Eflite motor. Doug B
Old Dec 10, 2015, 09:06 PM
Joined Nov 2011
Doug,
Thanks for taking the time to take the mystery out of the equation for me.
Bob
Will keep you apprised of the situation.
Old Dec 13, 2015, 07:33 PM
FICKLE FLYER
tlh101's Avatar
Joined Dec 2002
Here's a working link to my conversion, and it includes video of the model flying: http://www.rcgroups.com/forums/showthread.php?t=1451067
Old Dec 14, 2015, 05:17 AM
adamtc's Avatar
Joined Oct 2006
Bob,
Yes the Flair is 1/4 scale so much larger.
1500w is the figure you get from a 110 sized motor on 8 cells. I had the eflite 110 on a 16/10 and that was very powerful and efficient. I wouldnt want to run a g160 on 6 cells. It will look and sound very odd running at 4200 rpm. For the DR1, you want the ability to get air over the controls during landing and takeoff quickly and the 110 motor seems a better option to me.
For Sale Electrify Fokker Dr.1 NIB Sessholvlaru Aircraft - Electric - Airplanes (FS/W) 4 Sep 30, 2015 11:20 PM
Discussion Ziroli Dr.1. An conversion challenge vmsguy Glow to Electric Conversions 4 Nov 02, 2009 03:01 PM
Wanted Nick Ziroli's DR-1 Plans fomocokid Aircraft - Fuel - Airplanes (FS/W) 1 Nov 29, 2008 09:20 PM
Sold Ziroli DR.1 kit crashnburned Aircraft - Fuel - Airplanes (FS/W) 2 Nov 23, 2008 01:53 PM
Wanted Ziroli DR.1 plans Kev Aircraft - Fuel - Airplanes (FS/W) 0 Dec 31, 2007 02:12 PM
