Old Sep 21, 2014, 09:26 PM
01viper27 is offline
Find More Posts by 01viper27
Canada, ON, Toronto
Joined Nov 2011
Hawkeye 1700 PC Coated EPO FPV Plane 1700mm (PNF)
As the title says,
Has anyone had a chance to buy and fly their Hawkeye yet. I am waiting for mine to arrive. I am not a fan of the camo scheme but I will just paint over it. I like the body really more than anything else and the fact that one can fold the wing. If it is anything like the Skywalker line then it should be a great flyer.
01viper27 is offline Find More Posts by 01viper27
Old Oct 08, 2014, 11:58 PM
Canada, ON, Toronto
Joined Nov 2011
I received mine today; 75% / 100%
-Camo theme definitely not my preference. I prefer white or gray.
-Hinged wing kind of cool but could lead to failure from the hinges.
-Not sure what a wing skid is doing under the fuselage but it will break on first landing.
-Both left blind nuts on the fuselage for the left wing was filled in with glue. It took me an hour to clear the threads.
-Motor cowl does not provide enough cooling vent.
-Boom is made of aluminum not CF.
-Boom should have had a slit instead of a slot to pass the elevator and rudder servo wires.
-Boom must be glued in place and cannot be made removable as there is no provision for it.
-My vertical stabilizer came leaning to the right by 5* I had to heat the rudder fin to set it straight.
-Lack of manual.
Other than what I have mentioned above I give this plane 75%.
Old Oct 13, 2014, 09:25 PM
Canada, ON, Toronto
Joined Nov 2011
-Does anybody know the CG on this plane?
-Also the total length of this plane is 1233 mm from tip to tip. I have my fpv equipment and a Turnighy 4S 5000 mAh shoved all the way to the nose but it is still tail heavy.
-Can I just shove the tail boom in to balance the plane out?
Old Oct 29, 2014, 04:58 PM
Canada, ON, Toronto
Joined Nov 2011
CG of the plane of course is 33% of the wing cord OR 3" OR 76.2 mm from the leading edge just 5 mm from the ailron servo wire channel. What lead me different is the fact that the plane specifics says that it requires a 4S 14.8V 4000+ mAh LiPo pack for power. Not exactly true. I had a 4S 5000 pack and the rest of my equipment up front and it was still VERY MUCH tail heavy. I had to put another4S 5000 pack just to achieve the right CG.
While I am sure it will fly, it is now too heavy for my liking. I have of course corrected the few things that I had listed from my first post that the HK QI missed.
Other things I don't like about the plane is the foam. It is not contact cement or GOOP friendly like the rest of my fleet. BEWARE - THE FOAM WILL MELT.
To this date I have not seen a single video post on the Hawkeye. I am almost done on my painting and hopefully soon enough a maiden to follow.
Old Oct 29, 2014, 10:45 PM
Canada, ON, Toronto
Joined Nov 2011
The completed makeover and build of my Hawkeye
Old Jan 10, 2015, 04:05 PM
Dogdude is offline
Find More Posts by Dogdude
Joined Aug 2012
Did she fly after all ?
Dogdude is offline Find More Posts by Dogdude
Old Jul 29, 2015, 10:28 PM
zzman is offline
Find More Posts by zzman
Joined Jul 2015
If I meet designer of this plane, I'll say
hm......hm.....hm.... Are you OK? Take it easy
I believe that there is something what you can do....
You can get the another job
I know it is not easy... my experience, you may use monkey spanner at the front of canopy without light-repairing
zzman is offline Find More Posts by zzman
Discussion Hobbyking Hawkeye 1700 PC Coated EPO FPV Plane 1700mm (PNF) franknitty69 FPV Aircraft 40 Mar 24, 2016 08:24 AM
For Sale BNIB HK Sky Eye EPO FPV Glider w/Flaps 2000mm (PNF) daign FPV Equipment (FS/W) 2 Apr 21, 2015 10:48 PM
Sold P-40N Giant Scale 6s w/flaps, lights & retracts 1700mm EPO (PNF) BRAND NEW IN BOX x5heli Aircraft - Electric - Airplanes (FS/W) 3 Jul 14, 2013 08:19 AM
Sold P-40N Giant Scale 6s w/flaps, lights & retracts 1700mm EPO (PNF) ross_badger Aircraft - Electric - Airplanes (FS/W) 5 Jan 11, 2013 11:20 AM
Sold P-40N Giant Scale 6s w/flaps, lights & retracts 1700mm EPO (PNF) - $SOLD shipped ross_badger Aircraft - Electric - Airplanes (FS/W) 12 Dec 28, 2012 09:46 AM
