Old Apr 22, 2015, 02:44 AM
sheriffjohn is offline
Find More Posts by sheriffjohn
sheriffjohn's Avatar
United States, CA, San Diego
Joined Sep 2012
what happened 2 years ago?
I used the 2 prong push rod that came with the kit. However, it was not long enough and had to make an extension to get to the servo. I didn't understand the instructions at first. it said to put straws (the ones that can bend) on the ends of the push rods. It took some bending and twisting to install the pushrod. The straws fit through the side openings, thus making the install a lot easier. If you don't use the straws, you run the risk of punching thru the covering! I thought it was a big help. Once I attached the pushrod to the elevators, I realized that it was short, so I added an extension.
in the photo, the elevator servo is on the left. You can see the extension! The middle servo is the pull-pull rudder servo. The instructions say to cross the wires so that the right servo arm attaches to the left side of the rudder. This crossing of wires is so that wires do not rub on the airframe.
SJ
sheriffjohn is offline Find More Posts by sheriffjohn
Old Sep 10, 2015, 12:31 PM
jwellsy is offline
Find More Posts by jwellsy
United States, IL, Champaign
Joined Aug 2012
This plane has been entreaging me now for a couple of years and I'm tempted to go for it while it's on sale through tomorrow @ $100 off.
Seeing as how most builds have needed 1 - 2 pounds of nose weight I'm thinking a RCGF 30 Twin or a DLE 40 Twin may be a good choice. I love the sound of a twin and the horizontally opposed twins tend to have much less vibration at idle shaking the airframe.
jwellsy is offline Find More Posts by jwellsy
Old Sep 10, 2015, 12:46 PM
jwellsy is offline
Joined Aug 2012
WOW, $70 shipping! Now I remember why I never ordered a plane from them before. I'm going to have to think about this before pulling the trigger.
Old Sep 11, 2015, 01:13 PM
scubbyboo is offline
Find More Posts by scubbyboo
United States, MI, White Lake Charter Township
Joined Aug 2014
When i bought mine shipping was 50 but the pri ce was 249 for total 300 so 189 plus the 70 thats 260 best deal u will get. If u order the guns pay a a.bit more and get the nice ones. Wish I did i went cheap. Mine still in the box but member at the club has his in the air looks great in the air. Not sure u need so much motor....not sure what he is flying his on it is a saito 4 stroke gas more than the plane needs but he also wanted the weight. It really is neat watching it fly over at 1/4 throttle. As far as shipping it is a large box. Go for it u'll like it
scubbyboo is offline Find More Posts by scubbyboo
Old Sep 16, 2015, 01:36 AM
Joined Sep 2012
Wow, activity on this thread!
I got mine last January at the AMA trade show in LA, so I didn't have to pay shipping. It's a small company, so I guess they don't get the shipping deals.
Guys at my field that have bi-planes, mostly from Balsa USA usually have to add about 2 lbs of weight. Can't remember right off, but I used about 1.4-1.8 lbs of weight. I put in a Zenoah 26cc mostly for the weight.
Here it is September and I still haven't flown it. It's my first gas engine airplane so I'm taking my time, plus, I don't work on it much. But I'm close, real close. Bench tested the motor then final assembly and motor testing on the plane. Seeing what vibrates apart before flying. Just finished tweaking the idle and noticed that my carbon fiber throttle control rod had a crack in it, so I must replace it. Also working on a throttle curve because i don't like the feel. Throttle up is too quick for the stroke on the transmitter. So this week or next I'll go out for some taxi runs, maybe the maiden.
It's a nice looking airplane. The cockpit is out of scale but the large size is good to get your hand in there to access the electronics. I'm not going to flatten out the surface sheen. I like it as is.
sj
Old Oct 21, 2015, 01:13 AM
Joined Sep 2012
My first flight. I'm glad its a boring video.
Only 2 flights. It took off at about 33 mph and cruised between 45-55 mph. Nice and stable. Heavy in the air, sink rate is high. I haven't pushed it at all, but it gives me the impression that it is hard to tip stall. It was fun to fly!
SJ
maiden flight. Maxford 1/5 scale Nieuport 28 (6 min 6 sec)
New Product Maxford USA Nieuport 28 EP 40" ARF Josephp13 Electric Warbirds 57 Aug 18, 2014 06:08 PM
Discussion Motor Suggestions for a Maxford USA Nieuport 28 EP Col Moonpie Power Systems 8 Nov 29, 2012 06:13 PM
Sold Maxford USA Nieuport 28 EP 40" v_dub1968 Aircraft - Electric - Airplanes (FS/W) 5 Jun 15, 2011 05:45 PM
