Old May 02, 2015, 10:06 AM
highndry1 is offline
Find More Posts by highndry1
Joined Feb 2015
I used spackling compound on a similar gouge and it worked great..GG is a pain to sand.
highndry1 is offline Find More Posts by highndry1
Old May 02, 2015, 10:07 AM
Joined Feb 2015
Old May 02, 2015, 10:16 AM
Sledgunner is offline
Find More Posts by Sledgunner
United States, MI, Howell
Joined Apr 2015
Flyzone Tidewater
How does it stay? It seems like it would not bond and fall out. Am I missing something?
Sledgunner is offline Find More Posts by Sledgunner
Old May 02, 2015, 10:56 AM
Clive66 is offline
Find More Posts by Clive66
Clive66's Avatar
United States, CA, Fontana
Joined May 2011
I have also used light weight spackling (DAP Patch N Paint)
Works good & I have never had it come loose.
Your are right about Gorilla glue being a pain to sand (especially on foam)
I have used Gorilla glue to fill gouges, but it requires a lot of care not to use too much & removing the extra as it drys (not that easy to do)
Clive66 is offline Find More Posts by Clive66
Old May 02, 2015, 11:10 AM
Clive66 is offline
Clive66's Avatar
Joined May 2011
This is another product i use
Old May 02, 2015, 08:51 PM
Charlie P (NY) is offline
Find More Posts by Charlie P (NY)
Gravity is weak but persistant
Charlie P (NY)'s Avatar
United States, NY, Port Crane
Joined Aug 2009
It will sand, but the surrounding foam sands 10X easier. Be sure to mask it and use sanding blocks.
Charlie P (NY) is offline Find More Posts by Charlie P (NY)
Old May 03, 2015, 10:52 PM
freddy_fo is offline
Find More Posts by freddy_fo
freddy_fo's Avatar
United States, UT, Richfield
Joined Sep 2014
Tidewater Maiden
My flying buddy and I decided to maiden our water planes this weekend. Neither of us have flown off of water before so we were apprehensive about the results but am happy to report landings and takeoffs are much easier than expected.
My plane uses floats and it seems that the hull configuration of the tidewater allows it to handle better while manuevering in the water compared to mine. He also noted that the plane tends to dive while under full throttle which makes sense given the location of power system.
He is very happy with the plane and says it is a keeper so one more pilot giving it a thumbs up. Looking at the plane it appears to be a very good quality kit and he didn't mention any issues with the build. An orange rx was installed and once he got used to the smaller size of the plane it flew real nice and scale like.
Pics were taken with my cell so not the greatest.
freddy_fo is offline Find More Posts by freddy_fo
Old Yesterday, 12:48 AM
azalbino is online now
Find More Posts by azalbino
United States, AZ, Phoenix
Joined Nov 2012
Tidewater- Rear Stabilizer
There have been many posts about the horizontal stabilizer and how "floppy" it is. For those that haven't attached carbon fiber rods, does leaving the stab as is have a negative affect on flight performance?
azalbino is online now Find More Posts by azalbino
Old Yesterday, 04:18 PM
HuskyDude is offline
Find More Posts by HuskyDude
HuskyDude's Avatar
Canada, BC, Kamloops
Joined Jan 2011
I would say not. Although I do remember seeing a backward camera view of it shaking a bit in flight. (I'll see if I can find it) It will fly fine without bracing. It just tends to get bumped lots handling on the ground. Also a good piece of mind knowing it is supported.
HuskyDude is offline Find More Posts by HuskyDude
Old Yesterday, 05:12 PM
Joined Nov 2012
So I put the rods on and it seems vibration is more with vertical stab now along with a little horizontal stab.
Anybody else find this to be the case?
Is there a recommended position to place the cf rods?
Thanks!!
Sold Flyzone Beaver, Flyzone C350 Corcalis, TH P-51 JimVanLoo Aircraft - Electric - Airplanes (FS/W) 0 Jan 08, 2013 01:15 PM
For Sale Anyone in the tidewater VB area interested in a slightly crashed E-flight Edge 540. Speedfreak Aircraft - Electric - Airplanes (FS/W) 1 May 12, 2006 02:13 PM
For Sale Tidewater Pronto jimmycashley Aircraft - Electric - Airplanes (FS/W) 3 Jan 15, 2006 04:45 AM
Discussion "Hardy Souls" contest, January 1, Tidewater, VA. D_Ryan Thermal 2 Dec 28, 2005 06:35 PM
Discussion "Hardy Souls" contest, January 1, Tidewater, VA. D_Ryan Sailplane Talk 1 Dec 28, 2005 10:30 AM
