View Poll Results: Is it possible at all
yes 1 25.00%
no 1 25.00%
with utmost care and weight saving 2 50.00%
only startable with bungee 0 0%
Multiple Choice Poll. Voters: 4. You may not vote on this poll
Old Jan 04, 2015, 10:45 AM
Joined Jan 2015
F14-A 1/24 Todays Hobbies flying edf conversion
Hello together,
nice to be here.
Anybody who did a Todays Hobbies F14-A 1/24 edf conversion that is actually
in service and flying?
Have a kit here and realy want to do it right.
Got experience with balsa r/c and scratch construction.
Thanks for any help and comments.
Best regards,
Alex
microphonemaster is offline Find More Posts by microphonemaster
Old Jan 04, 2015, 12:22 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Welcome to RCG! good luck with the build..I am not familiar with the kit. can you post some pics from the plans and some specs?
turbonut is online now Find More Posts by turbonut
Old Jan 04, 2015, 01:31 PM
Joined Jan 2015
Hi Turbonut,
it has a wingspan of 32" loa 31"
All Balsa and a few plastic ABS parts, which i will dump.
Pics of the plan attached, i will omit the folding wing mechanics to something
more decent.
Plan to build with double edf, flaperons, elevator, rudder, retracts and folding wings.
Best regards,
Alex
Old Jan 04, 2015, 01:39 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Cool it looks like a fun build. I would use all micro gear and if room 2 30mm to 40mm fans. Use taileron and skip the flaperons and rudder...
Old Jan 04, 2015, 02:46 PM
Joined Jan 2015
Hi Turbonut,
I am realy keen on full aluminim edf, do you know a manufacturer who does them
in this size?
Thanks.
Best regards,
Alex
Old Jan 04, 2015, 04:00 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Nothing that I have seen in the size your project will require. And there really is no reason to use all aluminum. Just find a proven set up...How much room is in the fuse for ducting? you may even want to consider a single fan with spilt duct/bifurcated or a oval for ease. But over all it looks like a in-depth project.. I just noticed the tape measure so it gives some scale...I think twin 40mm or single 55mm or 65 mm then keep the build very light
Old Jan 04, 2015, 04:26 PM
Joined Jan 2015
Got a 64mm aluminum for my A-10 Project laying on the table.
Would give me 1300 gramms of thrust on 4S 2600mAh.
Have you got good manufacturers for 40 mm edf?
Old Jan 04, 2015, 04:36 PM
Joined Jan 2015
Here is apic of the edf
Old Jan 06, 2015, 05:36 PM
United Kingdom, England, Hindhead
Joined May 2004
quite a few build threads if you google todays hobbies - interested to see how this turns out
kits seem very reasonable priced - 30 to 40 bucks
desmo is offline Find More Posts by desmo
Old Jan 06, 2015, 07:15 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
That fan should work for a single set up.But I suspect too big for a twin.. its also a bit heavy even for a single on this project.
Wanted Art-Tech/Blitzrcworks F14 Tomcat twin 55mm edf jet dominio01 Aircraft - Electric - Airplanes (FS/W) 1 Nov 05, 2014 10:16 PM
Discussion F18 1.6M Changesun 105mm EDF Flying smooth qiaatiger Foamy EDFs 14 Oct 08, 2014 05:30 AM
For Sale Todays Hobbies F14 Kit jimmyray Aircraft - Electric - Airplanes (FS/W) 3 Jan 25, 2013 02:10 AM
