Old Oct 05, 2014, 06:26 AM
stef France's Avatar
Joined Mar 2014
Build Log
40mm Ergo version, 300W, speed flying wing
Hi,
This is the new building. Use HK 40mm 8000Kv/3S fan, seems powerfull!
stef France is offline Find More Posts by stef France
Old Oct 05, 2014, 09:34 AM
Hampton, VA
Joined Mar 2009
Lordy help us now!!!
ksqm is online now Find More Posts by ksqm
Old Oct 05, 2014, 05:53 PM
jumo004's Avatar
Joined Apr 2010
Wow !! Very nice work !!!
jumo004 is online now Find More Posts by jumo004
Old Oct 06, 2014, 04:51 AM
meerkat13's Avatar
United Kingdom, Birmingham
Joined Jan 2013
Cool... looks supper slippery !
meerkat13 is offline Find More Posts by meerkat13
Old Oct 06, 2014, 04:32 PM
Joined Mar 2014
Hi,
The nacelle with motor, all in place.
100% FSA intake and 85% FSA exhaust.
Old Oct 06, 2014, 05:25 PM
Joined Mar 2014
With fin.
Old Oct 06, 2014, 05:49 PM
DELTAS RULE
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
holy crap thats awesome!
corsair nut is online now Find More Posts by corsair nut
Old Oct 06, 2014, 06:15 PM
Hampton, VA
Joined Mar 2009
A man must know his limitations. For the moment, you've exceeded mine. You'd need FAA clearence to put that in the skies hear. You had a Corsair at 230 km/hr. Your Ergo looks smokin sitting still. Good Luck on the maiden and use a radar gun!!!
Ksqm
Old Oct 06, 2014, 08:20 PM
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Stef, Thank You Sir! You have done a superb job in the smalls work and craftsmanship representation. WOW! I believe the scale speed will surpass mine by a mile! Its gonna be so quiet it will scare you! Did you scale the nacelle intake for 100% FSA at the mid point of the inlet lip radius?
ApexAero is offline Find More Posts by ApexAero
Old Oct 07, 2014, 03:28 PM
Joined Mar 2014
Thanks Tom, i hope it will fly well..
But the nacelle don't work quiet at all, many noise coming from the sharp inlet lip, and when i use the big radius alu lip the fan become quiet and smoth, little slow down in RPM but increased thrust! May be in flight with air speed things could be different??..
I use the drawing printed scaled for 43mm diam fan that gives 36mm diam inlet, on mine it's 38mm, just over 100% FSA but the inlet lip radius is very small.
i don't know what is the best inlet shape to minimise nacelle drag and maximise thrust.
Old Oct 07, 2014, 04:40 PM
Canada
Joined Nov 2000
Study an airliner's Ducted inlet shape, as a simple guide ?
Usually the profile of an airfoil's front section works well.. beyond that, it's an open to experimentation issue.
Relocating the Rotor deeper into the ali shroud gave benefits on My 40mm edf unit.
Bit of a pain/risk to dissasemble to cut the Motor shaft length though.
Bare is online now Find More Posts by Bare
Old Oct 07, 2014, 07:31 PM
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
For speed I would have a very small radius on the inlet and reduce to about 90% FSA but that depends on if you have ample thrust if not you will need to keep it at FSA
turbonut is online now Find More Posts by turbonut
Old Oct 08, 2014, 04:06 PM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Yes it should smooth out after the speed builds up. Static thrust whine and the inlet noise will subside and the speed will build after a lap so hang on!
You need a mini bungee launcher like CN and Pdawg use on the Microlite!
Old Oct 12, 2014, 08:04 AM
Joined Mar 2014
The fins shaped.
Discussion 3 different profiles for a slow speed & high payload flying wing philgib Nurflügel 10 Dec 08, 2014 08:40 AM
Wanted speed wing dart or speed wing dart xl traderdave2 Aircraft - Electric - Airplanes (FS/W) 0 Jul 13, 2014 03:57 PM
Discussion Teksumo Flying wing CG suited to all speeds? RC Aerobat Electric Plane Talk 9 Oct 09, 2013 07:56 AM
Sold Illinois industrial tool zj4113 5-speed mini drill press 300w 120vac ½" chuck Mikemynameis Aircraft - General - Miscellaneous (FS/W) 0 Nov 28, 2012 06:12 PM
