Old May 30, 2003, 12:25 PM
Fast and low.
Carlisle, cumbria, UK.
Joined May 2003
My Fokker-E / GWS-Stik F
well i bought this about 2 weeks ago , built it in 6 hours. "Great" i think "i'll be able to fly it in upcoming fly-in" not so, bad weather.
So, this evening , balmy weather , warm, little wind. So i shove in my cycled 7.2v NiCad (250MaH) , check CofG one last time, cycle up, think to my self "feels like she wants to pull away" gentle push into wind climb for about 10 feet...stall.....pull out....get a little height ......trim...TRIM!....trim out.....hit the deck..oops.
Now the conundrum, it has an AUW of 6.3 Oz with 2xRipmax SD200, the IPC 100 ESC, and i HiTec feather light RX.
So, when the minimum weight , advertised on the GWS site, is about 1.3 Oz heavier than my aircraft why will this thing refuse to climb?
Why is the little 280 not turning this thing into a semi....i was going to say speed machine but we all know thats not going to happen....fast...*help me out here*...thing ?
NOTE:I have passed my BMFA 'A' test so i am technically a proficient pilot
Balsa02 is offline Find More Posts by Balsa02
Old May 30, 2003, 12:31 PM
Crash happens! :)
Utah
Joined Jun 2002
Just have to ask since I know I and many have done it. Is you prop on Backwards?
Arrow is offline Find More Posts by Arrow
Old May 30, 2003, 12:34 PM
Fast and low.
Joined May 2003
no...i'm not quite that bad lol
Old May 30, 2003, 12:42 PM
wild in the park?
wherndon's Avatar
McDonough, GA
Joined Mar 2003
maybe one of the cells in the battery pack is dead?
have you a way to check the voltage? Or better yet, how much charge it will take?
- Bil
wherndon is offline Find More Posts by wherndon
Old May 30, 2003, 12:47 PM
Fast and low.
Joined May 2003
yes its been checked, it gives out 7.8V
Old May 30, 2003, 12:56 PM
Walled Lake, MI, USA
Joined Feb 2000
A 6-cell battery sounds very marginal to me. This is the direct drive 280 motor, correct? The high-drag slowflyers are better with geared motors than DD. But this combo should work with the right combination of voltage and prop size.
Dave Hederich is offline Find More Posts by Dave Hederich
Old May 30, 2003, 12:57 PM
Fast and low.
Joined May 2003
i'm using the supplied GWS ....4x4? prop.
Old May 30, 2003, 01:00 PM
wild in the park?
wherndon's Avatar
McDonough, GA
Joined Mar 2003
well, you got me stumped.
i suppose it is possible to have a bad motor, even though it new...
Old May 30, 2003, 01:04 PM
Fast and low.
Joined May 2003
like i say.....it seems to be giving out a bit of power....i had it sitting on my front lawn running the packs through it and at full throttle it would lift its tail to horizontal and you could steer its tai around (it was bing stopped from moving forward by two screwdrivers)
Old May 30, 2003, 01:14 PM
wild in the park?
wherndon's Avatar
McDonough, GA
Joined Mar 2003
the specs say a 5030 prop is standard.
that means the prop should be 5" long.
should also be stamped 5030 on the front of the prop.
Old May 30, 2003, 01:19 PM
Fast and low.
Joined May 2003
*goes to look * so it is. i was just guessing 4x4 because a Gunther prop is 5x5...and the GWS one is smaller.
Old May 30, 2003, 01:20 PM
Joined Feb 2000
If this is the setup you have .....
http://www.balsapr.com/catalog/parkF...ductId=T496581
..... it's a 5x3 GWS prop. Others who've tried this combo have said it's OK but not overwhelming. Consensus seems to be that it needs 7 NiCd or 8 NiMH cells to deliver the goods.
The GWS chart is very optimistic about this combo producing 4.20 oz. thrust @ 7.2V. My experience in comparing the real world to the GWS charts is that you have to add a cell or two to match up the numbers.
http://www.gws.com.tw/english/produc...tem/edp100.htm
Note that if it seems to be making good thrust but does not have enough airspeed to generate lift from the wings, the 4.5x4 prop might be preferable to the 5x3. Or, if you absolutely must stick with 6 cells, the 5x4.3 prop might help make up for the lower voltage.
http://www.gws.com.tw/english/produc.../propeller.htm
Old May 30, 2003, 01:29 PM
Fast and low.
Joined May 2003
ok, now all i need is someone who sells this stuff in the UK.
Discussion My thoughts about GWS F-15 motors skyhawk GWS (Grand Wing Servo) 1 Jun 28, 2007 09:55 PM
Just won my first e-power plane (gws e-starter) jacksonjrs Parkflyers 0 Jan 18, 2004 07:35 PM
Fokker E/Fokker-Stik Balsa02 Parkflyers 0 May 05, 2003 11:58 AM
Up to my ears in GWS Mustang's 59.00 Free Shipping to E-Zone Members Only gbagley Aircraft - Electric - Airplanes (FS/W) 0 Apr 01, 2003 10:10 PM
GWS Fokker-E alterego Foamies (Kits) 6 Jun 30, 2002 08:56 PM
