Old Yesterday, 07:25 PM
mistairjoe is online now
Find More Posts by mistairjoe
mistairjoe's Avatar
lake orion mi
Joined Sep 2002
large capacity connectors for batteries in series and parallel
I need to put 4 3700 MAh 6S lipo batteries two in series and two parallel to get a 12S 2P pack. Amp draw is around 65A. I need suggestions on what connectors would facilitate this. I been using Anderson poles but 10 Gage wire makes this a pain. I have to tin the wire and then file it down to make it fit before soldering.
Thanks for suggestions, Joe
mistairjoe is online now Find More Posts by mistairjoe
Old Yesterday, 07:49 PM
Bhodi11 is offline
Find More Posts by Bhodi11
Bhodi11's Avatar
United States, NC, Raleigh
Joined Dec 2013
http://www.castlecreations.com/produ...onnectors.html
These work great for me. Very easy to solder the heavier guage wire in. Plus they are rated to 200amps. What setup is this for? I have my first giant scale warbird with same configuration.
Bhodi11 is offline Find More Posts by Bhodi11
Old Yesterday, 07:59 PM
chuck75 is offline
Find More Posts by chuck75
Georgia
Joined Jun 2007
I've been using EC-%'s. That said, the power pole connectors are made in more than one size.
chuck75 is offline Find More Posts by chuck75
Old Yesterday, 08:06 PM
mistairjoe's Avatar
lake orion mi
Joined Sep 2002
Guys I can't use twins.. because of having to connect in series and parallel. The packs are going in a giant size TP FW 190 . I was looking for an alternative to Power poles.
Old Yesterday, 08:37 PM
vollrathd is offline
Find More Posts by vollrathd
vollrathd's Avatar
Joined Jan 2007
Yeah
Power Poles, and similar type connectors are great. But, their spec indicates #12 wire size maximum. And, as indicated, #10 won't fit.
There is a series 75 connector available that handles up to #4 wire. I've got a few of them, and they are HUGE! Just wish APP, and similar type connectors would come up with a size between their 45 Amp units, and their series 75 units.
vollrathd is offline Find More Posts by vollrathd
Old Yesterday, 08:54 PM
mistairjoe's Avatar
lake orion mi
Joined Sep 2002
"Just wish APP, and similar type connectors would come up with a size between their 45 Amp units, and their series 75 units."
I could not agree more...
Old Yesterday, 09:10 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Then check these out:
http://www.castlecreations.com/products/ccbullet.html
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Yesterday, 09:11 PM
BVH is offline
BVH
Find More Posts by BVH
BVH
BVH's Avatar
United States, CA, Pismo Beach
Joined Dec 2006
I use the APP crimper and the 45 Amp crimp fitting with 10 AWG, ultra high strand count wire from RobotMarketPlace. I just don't squeeze the crimper all the way to release but to the point that it is a solid connection. I then use a fine tip soldering iron to dab just a tiny drop of solder across the crimped "wings" of the connector and a few strands of wire for added measure. I don't fill the connection. I then carefully use a straight razor to slightly taper the last 3/16" of the insulation so it will feed into the plastic body and snap home after I have used a drill bit, by hand, to ever-so-slightly enlarge the housing square bore.
BVH is offline Find More Posts by BVH
Old Yesterday, 10:22 PM
Bhodi11 is offline
Bhodi11's Avatar
Joined Dec 2013
What ESC are you using?
Old Today, 06:39 AM
mistairjoe's Avatar
lake orion mi
Joined Sep 2002
CC 160 and a Rimfire 160. The ESC is an overkill but since I have one I am using it..
Old Today, 06:50 AM
mistairjoe's Avatar
lake orion mi
Joined Sep 2002
I am going with the 45A method used by BVH..I was already fitting 10 G wire to 30 A connectors by filling them down after tinning the strands. Thanks for the suggestion.
Old Today, 07:24 AM
mistairjoe's Avatar
lake orion mi
Joined Sep 2002
Best prices so far here..http://www.powerwerx.com/anderson-po...ings-contacts/
Discussion Single Large Lipo or Multiple Small Ones in Series/Parallel ? Weekend Flyer Batteries and Chargers 4 Mar 04, 2015 05:03 AM
Question Question about large capacity lipos/charging batteries in parallel Rampage Batteries and Chargers 4 Jan 17, 2015 05:16 AM
Discussion Using batteries in parallel, mixing pack capacities, brands, etc WillU Batteries and Chargers 3 Nov 10, 2014 11:43 PM
Question Charging Two 12V Series Batteries in Parallel? Snowflake6515 DIY Electronics 2 Dec 14, 2013 01:07 PM
Discussion Connecting parallel packs of different capacities in series? Sutton Bank Batteries and Chargers 4 Feb 06, 2013 10:13 AM
