Old May 17, 2015, 03:57 PM
R3gou is offline
Find More Posts by R3gou
R3gou's Avatar
Finland, Laukaa
Joined May 2014
Build Log
Fouga Magister build thread
Inspired by Finland's former jet trainer, I decided to try building one out of foam.
Haven't gotten far with the build yet, but more is to come soon
R3gou is offline Find More Posts by R3gou
Old May 17, 2015, 10:06 PM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
Joined Nov 2014
One of all time favorite aircraft.
BHOFM is offline Find More Posts by BHOFM
Old May 18, 2015, 01:27 AM
djacob7 is offline
Find More Posts by djacob7
Knife cuts foam like its steel
United States, CA, Fremont
Joined Jan 2009
Looks like a good start :-)
djacob7 is offline Find More Posts by djacob7
Old May 18, 2015, 07:41 PM
nuteman is offline
Find More Posts by nuteman
Joined Apr 2013
Beautiful plane.
It looks like you've decided on a very small scale. That plane will be quite challenging to fly at that scale (maybe you intend to use computerized stabilization like SAFE?).
Doing that plane at a minimum of 1.5 meter span will make it a lot more pleasant to fly.
nuteman is offline Find More Posts by nuteman
Old May 18, 2015, 08:49 PM
birdofplay is online now
Find More Posts by birdofplay
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
I like youR aspirations and look forward to your first flights.
I have always admired the Fouga Cyclone as well.
http://www.minijets.org/index.php?id=67&L=3
http://www.rcgroups.com/forums/showp...8&postcount=64
http://www.rcgroups.com/forums/showp...9&postcount=16
I built and flew the early Ziroli version back in 1969 as my 1st RC 3 channel model.
It was flying higher than the returning mornings' sortie of F105's
as they peeled of from echelon approach for a landing.
I was a bit nervous that some officer/Pilot would be coming to the model shop to
dress me down but it never happened.
birdofplay is online now Find More Posts by birdofplay
Old May 18, 2015, 09:19 PM
djacob7 is offline
Joined Jan 2009
It would be quite challenging to install two EDFs on that small size plane.
You could use two small propellers to fake it...
Or make it a pusher.
Old May 19, 2015, 08:01 AM
R3gou is offline
R3gou's Avatar
Finland, Laukaa
Joined May 2014
Originally Posted by nuteman View Post
Beautiful plane.
Why do you believe that it will be hard to fly? I would like to make a bigger one for sure, but bigger plane=bigger budget. This plane is only my 2nd scratch build one so I want to learn by making smaller planes at first
My plans are that I will install just one edf inside it. I believe it should be just fine
Old May 19, 2015, 08:39 AM
nuteman is offline
Joined Apr 2013
It's all about combination of wing loading, Reynolds number and aspect ratio. You've got a fairly high aspect ratio and low Reynolds number (and probably somewhat high wing loading for that scale). Not great for ease of handling. Small scale does not tolerate high wing loading well. Scaling up allows for tolerating higher wing loading much better. And typically (for our foam models), scaling up results in lower wing loading as well, improving things even further. High AR means high stall speed if at very low Re#. Again, scaling up greatly improves that.
That plane at 30" span will behave very differently than that plane at 60" span.
Anyway, I and others discuss the effects of scale to death in other posts, so a search will yield further details.
Old May 19, 2015, 10:43 AM
djacob7 is offline
Joined Jan 2009
Will you be installing the EDF in the middle of the fuselage or on its side?
What size EDF?
Old May 19, 2015, 11:07 AM
R3gou is offline
R3gou's Avatar
Finland, Laukaa
Joined May 2014
What size EDF?
It will come in the middle and I'm thinking of 50mm unit. The plane is 75cm long
Old May 19, 2015, 11:26 AM
R3gou is offline
R3gou's Avatar
Finland, Laukaa
Joined May 2014
Today I made the intakes. I was trying to make wings too, but my hotwire cutters power supply went dark, so I need to find replacement for it now
Old May 19, 2015, 11:28 AM
djacob7 is offline
Joined Jan 2009
Where would the inlet and exhaust of the EDF be?
Old May 19, 2015, 02:48 PM
R3gou is offline
R3gou's Avatar
Finland, Laukaa
Joined May 2014
I will make the fuselage hollow, of course right now it wouldnt fit.
Old May 20, 2015, 10:11 AM
Dreamcatcher is offline
Find More Posts by Dreamcatcher
Warbirds Lover
Dreamcatcher's Avatar
South of France
Great, a Fouga Magister !!!
I take a chair and look forwar the next steps with great interest
Dreamcatcher is offline Find More Posts by Dreamcatcher
Old May 20, 2015, 03:17 PM
birdofplay's Avatar
Joined Dec 2005
Dj just noticed your props !
:>} tricky photo shop work !
Build Log Fouga Magister CM-170 lionel_69 Scratchbuilt EDFs 26 Apr 15, 2015 02:52 PM
Discussion fouga magister Christen Diffusion 90mm fan gianni sanchez Large EDF Jets 18 Nov 17, 2014 12:36 PM
Build Log Fouga Magister fudi50 Slope 3 Nov 21, 2013 12:39 AM
Build Log EPP Fouga Magister Scratch Build RCFlybry Slope 64 Dec 10, 2009 01:38 AM
