Old Mar 12, 2014, 06:23 PM
thnilsen is offline
Find More Posts by thnilsen
thnilsen's Avatar
Norway, Hordaland, Os
Joined Nov 2004
Build Log
Balsafactory.com 1M balsa DLG build
I've long been wanting to get on the DLG craze but could never really afford the big splash on a proper model. Last May I came across some postings done by balsafactory.com here in RCG showing of a cheap 1m DLG balsa kit at a very reasonable $30.
After a few emails going back and forth I had placed an order for one of these kits. Turned out shipping was more than the kit itself ;-). Kit arrived and got put on the todo list with so many other projects, and stayed there till about last week as the flying season is about to start again after a long, wet and windy winter.
The nice lady who took my order also sent me updates along the way on issues that they had discovered since the release of the kit. Luckily it was only two minor issues:
  1. The throwing peg on the wing not being 90 degrees to the wing surface on the plan.
  2. A missing ply wood part for support of the servo tray
The kit contains nearly all you need apart from glue, covering and electronics. A 1:2 size plan and an A3 instruction sheet with pictures and some descriptions shows you how to go about building this kit. The instruction sheet could be better and the text is a typical translation from chinese to english where half of the info seems to be lost in translation. But if one has a bit of kit bashing experience its' not exactly rocket science to put this together.
The model should hopefully look similar to this picture once the kit has been glued together. If you end up with a duck instead you used the wrong parts
Name: 1 - Kit Pic.jpg
Description: This i what the model hopefully should look like when one has completed the kit....
The kit content with plan. Note the white bits in the plastic bag which is the included fiberglass sheets. Would have been better with some carbon fiber..
Name: 2 - Kit content.jpg
Description: Kit conent
The right wing has been started. The wing is built very traditionally starting with the wing ribs and the TE. The wing ribs have support tabs which makes it easy to get a straight looking wing. The carbon strip is glued to the front bottom sheeting. This process was a bit tricky as it wasn't really possible to glue the carbon before slotting the sheet in. I ended up slotting both the sheet and the carbon strip in place and then glue using ZAP. I lifted the carbon strip from the sheet using the tip of a small flat screwdriver to be able to get the glue to flow between the two parts.
Name: 3 - Right wing.jpg
Description: Right wing panel has been started
Here one can see the two carbon fiber strips which follows the full length of the wing panel and is glued to both the bottom and top sheeting (top sheeting to follow). This should make the wing strong enough I hope. Not so sure about the wing joining area, but that's for another day...
Description: Carbon strips supports the full length of the wing.
I'll post some more info of the build again tomorrow time permitting. Now its time for some shut eye.
- Thomas
thnilsen is offline Find More Posts by thnilsen
Old Mar 12, 2014, 06:34 PM
gtrbaby is online now
Find More Posts by gtrbaby
New Zealand, Waikato, Hamilton
Joined Jul 2011
are they still available? I feel like "building" something
gtrbaby is online now Find More Posts by gtrbaby
Old Mar 13, 2014, 02:24 AM
thnilsen is offline
thnilsen's Avatar
Joined Nov 2004
I believe they are. Not sure why they don't have them on their website at www.balsafactory.com, but drop mildred (at) balsafactory (dot) com an email and ask. She sent me some pictures of their kits about two weeks ago, so I would think they still sell them.
Update: I see they sell them on http://balsa.en.alibaba.com/product/...sa_glider.html
- Thomas
Old Mar 13, 2014, 11:55 AM
MattN is offline
Find More Posts by MattN
a.k.a. Matt Nelson
MattN's Avatar
North Tustin, CA
Joined Oct 2008
lol
MattN is offline Find More Posts by MattN
Old Mar 13, 2014, 06:14 PM
thnilsen is offline
thnilsen's Avatar
Joined Nov 2004
Left wing has been started. Here one can easily see the support tabs on th wing ribs as well as the slow in which one drops the lower front sheeting into. This makes it very easy to get a clean and straight wing.
Before gluing the bottom sheeting I also dropped in the spar to make sure the spacing of each wing rib was correct.
Name: 5 - Left wing started.jpg
Description:
When doing the second wing panel and before gluing the bottom sheeting to the wing ribs I made sure the angle of innermost ribs matched up with the already glued left wing panel.
Name: 6 - Make sure wings panels are aligned.jpg
Description:
These are the wing joiners. Made up of 2 sets of 4 2mm plywood parts. They're on the smallish side so time will tell if they can provide enough strength.
Name: 8 - wing joiners.jpg
Description:
At the tip of the right wing panel there is a full balsa block. I decided to make sure the top and bottom carbon strips that is glued to the spar also entered as much as possible into the balsa block which will hold the throwing peg.
Name: 9 - Left wing tip carbon slot.jpg
Description: Name: 10- Left wing tip carbon slot.jpg
Description:
Right wing tip glued in place....
Name: 11- Left wing tip glued.jpg
Description:
Two wing panels getting near completion. Next step is to add some carbon sheets to the right wing tip.
Name: 12 - Wing panels finished.jpg
Description:
Old Mar 13, 2014, 06:18 PM
thnilsen is offline
thnilsen's Avatar
Joined Nov 2004
As the kit only contained fiberglass sheets to strengthen the wing tips I ended up using some of my own stock of carbon sheeting. It's not very thick but a quick comparison between a balsa piece with the fiberglass sheeting and my own carbon sheeting did show a slight stiffer result with the carbon, so that's what I ended up using.
Here one can also see the small area of the wing joiners...
Name: 19 - Carbon addd to wing tip area.jpg
Description:
Old Mar 15, 2014, 09:38 AM
thnilsen is offline
thnilsen's Avatar
Joined Nov 2004
Started on the fuselage. The fuse sides are blasa with plywood support. It is marked out where each part goes so you cant' really go wrong. (Sorry about the lack of focus on this picture)
Name: 13 - Fuselage sides.jpg
Description:
Next step was to glue up the wing mounting formers. Two blind nuts are pressed and glued into two layers of plywood which is the fitted in the slot between the formers.
Name: 14 - Wing mouting.jpg
Description: Name: 14.1- Wing mouting nut.jpg
Description: Name: 15 - Wing mouts glued.jpg
Description:
Both fuselage sides are glued on. I have left out the front former and servo tray to be glued in later in order to be able to insert the tail boom.
Name: 13.1- Fuselage formers.jpg
Description:
The wing will be resting on two plywood parts which are glued into the recess in the fuselage formers. A bit of sanding was needed to get a good fit. Once glued in place the bolt hole for the blind nuts was re-drilled.
Name: 16 - Wing seating top.jpg
Description:
Old Mar 15, 2014, 10:13 AM
thnilsen is offline
thnilsen's Avatar
Joined Nov 2004
Wing panels glued together.
Name: 20 - Wing panels glued together.jpg
Description:
With wings balanced and a bit of catbon added to the wing joint area the total wight is currently 48.9 grams / 1.7 oz. Once convering has been added I guess it will add another 10-15 grams to the total wight ending up at around 65 grams /2.2 oz or thereabouts.
Name: 21 - Weight of wing.jpg
Description:
Getting the holes drilled for the wing bolts is always interesting. This time I first drilled the front hole. Once that was complete I made a small tap of a 3mm bolt which I then fitted to the read mount and made sure it only came up above the wing seating ever so slightly. Then it was just a mapper of mounting the wing using the front bolt, measure the correct distance from the tail boom to each wing tip and press the rear of the wing down onto the tap. Worked like a charm.
Name: 22 - Tap used to get acurate drill mark in wing.jpg
Description:
The kit contained two lookalike carbon sheets to be used for the wing center. However, these two bits of plastic is only useful for decoration and will add nothing but weight to the model. I ended up using my own stock of carbon sheets to do the wing center.
Name: 25 - Carbon look alike tape.jpg
Description:
The canopy for the fuselage is made up of three bits of balsa. As can be seen from this picture a small sheet of balsa is to be glued between the wing seating and the canopy lid. I might just extend the canopy to cover this bit as well to make it a bit easier to get to the rear servos mounting lug.
Name: 23 - Canopy glued together.jpg
Description: Name: 24 - Canopy.jpg
Description:
Name: 26 - Servos.jpg
Description: Name: 27 - Servos.jpg
Description:
Old Mar 24, 2014, 02:10 PM
thnilsen is offline
thnilsen's Avatar
Joined Nov 2004
Progress has be a bit slow the last week or so, but then I've never been one to rush things.
The fuselage boom fairings have been glued in place. I managed to forget skip this step as I glued the horizontal stab support to the boom first which is a bit stupid. Luckily it's only basla so after splitting the fairing pieces in two it was a quick job to glue then in place. A bit of sanding is needed, but using a dremel will speed the process immensely.
Name: 28 - fairing.jpg
Description:
In the kit, the horizontal stab support consists of 4 pieces of balsa wood and two pieces of plywood, which according to the plans are to be glued together with each of the plywood pieces at top and bottom. I left one of the balsa and and plywood pieces out as it looked like the tail would just be a bit too high and too fragile. 3 levels of 5 mm balsa should be enough. I have later also strengthened the area by adding a piece of glass fiber cloth and epoxy . Before gluing ,the shape of the piece to be glued to the boom was sanded by wrapping a bit of sandpaper around the boom.
The boom also had to be slotted to fit the vertical stab. An easy job with the dremel.
Name: 29 - Tail slotted.jpg
Description: Name: 30 - horizontal stab mount.jpg
Description:
Nose cone consists of 6 pieces of 5mm balsa of which the two middle pieces are somewhat hollowed out.
Name: 31 - nose.jpg
Description:
Wing has finally been covered using SoLite yellow transparent film. Weight before covering was 46.9 grams / 1.65 oz . Once complete this part now weights 54.5 grams / 1.9 oz. Just need to glue in the throwing peg and its done.
Name: 32 - Wing covered.jpg
Description:
Old Mar 24, 2014, 02:35 PM
thnilsen is offline
thnilsen's Avatar
Joined Nov 2004
To strengthen the vertical stab somewhat I added a bit of 0.5mm flat carbon strip on both sides of the area which slots into the boom. I also glued a strip of fiberglass to the lower front part of the vertical stab to protect it against "hard landings".
Name: 33 - Vertical stab.jpg
Description:
Horizontal stab, elevator and rudders have been covered. The vertical stab has also since got its covering done.
Name: 34 - Horizontal stab.jpg
Description: Name: 35 - Elevator and Rudder covered.jpg
Description:
Stabs have been glued and secured. Horizontal stab is secured by two screws into the ply/balsa support block.
Name: 38 - stab glued.jpg
Description:
Now comes the difficult part which is why I have also left the bottom sheeting for the fuselage to be done later. How should I do the pushrods on this model. The kit comes with 0.39mm / 0.0153" piano wire and sleeve. However the sleeve is very flimsy and will have to be supported every few inches. Another complicating factor is that there is no easy way to route the sleeve outside of fuselage due to the tight area where the boom is glued to the fuselage. I'm leaning towards trying to fit the sleeve for rudder/elevator into the boom and try and secure it by making a couple of support that will fit inside the boom every few inches. I won't be easy but I can't see it being done any other way. Anyone got any other suggestions on how I should do this?
Name: 36 - Fuselage bottom sheeting left off.jpg
Description: Name: 37 - pushrods.jpg
Description:
Old Mar 30, 2014, 02:24 PM
thnilsen is offline
thnilsen's Avatar
Joined Nov 2004
Managed to get some more work done. The build is now nearly completed.
After a bit for searching around on RCG I came across this thread (http://www.rcgroups.com/forums/showthread.php?t=1374442)where magnets was used to help with keeping the pushrod sleeves to the inside of the boom while the glue was curing. Inside the fuselage I supported the sleeves with two pieces of depron.
Name: 39 - pushrod sleeve support using depron.jpg
Description:
Once the pushrod dilemma was resolved I fixed the servos and made the connector ends for the pushrods. At the moment I have only done Z-bend at both ends of the pushrod as a temporary fix. I will be ordering some T-Rex 250 ball links and balls to get an adjustable connector at the elevator and rudder end. But to get it in the air the Z-bends will do,even if there is a bit of slop in the linkage.
Once the fuselage was sanded down and covered, elevator and rudder installed the weight of the model ended up at 137.4 gram / 4.83 oz with the servos installed. I didn't weigh the servos but they're both BMS-306BB ones and according to their specs weight around 7gram each making the model with 123.4 grams / 4.35 oz.
Name: 40 - Model completed.jpg
Description: Name: 40.1 - Model completed.jpg
Description:
I'll be using an FrSky D4R-II receiver with a 360mAh 2S LiPo pack to power the RX. But since servos are not 6+ volt servos I either have to reduce the voltage to the receiver or to the servos. I ended up ordering two regulators which are supposed to be used between RX and servo. http://www.hyperflight.co.uk/product...=mks-1-5a-sbec. With these installed I will be able to get an accurate reading of the LiPo pack via the FrSky telemetry.
I could also have gone for a 1S pack but that would have left me unable to use a openXvario which requires at least 5v to work.
Hopefully there will be room to fit all the electronics in the bay. There is quite a lot of space available dor a DLG so it should hopefully be ok. :-)
Name: 41 - Lots of room for electronics.jpg
Description:
So now I just have to wait for the servo regulators to arrive from the UK before I can get a test flight - which I hope will happen this coming week since the weather is on the "superb" side at the moment. I also have to figure out the CG as the included plans/instructions doesn't mention anything about it.
Old Mar 30, 2014, 10:35 PM
Buddy Roos is offline
Find More Posts by Buddy Roos
It's a mere flesh wound!
Buddy Roos's Avatar
Woodstock,Ga.
Joined Jun 2004
It may be just the camera angle, but the wing appears to have little or no dihedral.
Rudder/Elevator planes without ailerons require quite a bit of dihedral to make a turn.
Buddy
Buddy Roos is offline Find More Posts by Buddy Roos
Old Mar 31, 2014, 01:08 AM
thnilsen is offline
thnilsen's Avatar
Joined Nov 2004
It's the camera angle. Dihedral is set at 11 degrees.
- Thomas
Old Jan 19, 2015, 07:43 PM
Joker 53150 is offline
Find More Posts by Joker 53150
Joker 53150's Avatar
United States, WI, Muskego
Joined Sep 2012
It's been 10 months - how does it fly?
Joker 53150 is offline Find More Posts by Joker 53150
Old Jan 30, 2015, 03:47 AM
ThunderstruK is offline
Find More Posts by ThunderstruK
United Kingdom, England, Northwich
Joined Jul 2013
Nice build, thanks for the pictures.
I'm about to build one myself but it's only my second balsa build so I have a simple question I hope someone can help with.
Do I glue the single ribs to the support tabs, and then cut them off later, or do I just sit the rib on the support without gluing?
ThunderstruK is offline Find More Posts by ThunderstruK
Sold Stella 1m DLG Kit with D47s and Smart LiPo Mountain Soarer Aircraft - Sailplanes (FS/W) 5 Nov 26, 2013 11:30 PM
Wanted Vladimir Models Elf or other 1m DLG Mr. Wiz Aircraft - Sailplanes (FS/W) 3 Nov 25, 2013 09:04 PM
Discussion My first try building a > 1m DLG depron glider Markus A. Hand Launch 1 Aug 10, 2009 12:27 PM
Idea 3D-Sneak preview of Balsa 54" Cumulonimbus Dlg airfoil, and build thread dougmontgomery Hand Launch 101 Aug 22, 2008 08:05 PM
Question balsa build it yourself DLG ??? Knippels Hand Launch 92 Feb 28, 2005 05:24 PM
