Old Apr 25, 2015, 10:23 AM
kelchm is offline
Find More Posts by kelchm
kelchm's Avatar
United States, PA, Shippensburg
Joined Jan 2015
what are most of you guys using for your throws? I'm 50/50 on aileron/elevator mixing and as I have things setup now I have around +/- 11mm at full elevator up/down -- Not sure what it is with full elevator and aileron together.
kelchm is offline Find More Posts by kelchm
Old May 01, 2015, 09:08 PM
kelchm is offline
kelchm's Avatar
Joined Jan 2015
Originally Posted by kelchm View Post
I'm using the following:
Motor: Turnigy Aerodrive SK3 - 2122-2100kv
Prop: Gemfan 5x3
ESC: HobbyKing 12A BlueSeries
Servos: HXT500
Receiver: FrSky V8R4-II
Battery: ZIPPY Compact 850mAh 3S 35C
What's the next step up from this setup? I want something a bit faster.
Old May 04, 2015, 09:08 PM
Dewane is offline
Find More Posts by Dewane
Dewane's Avatar
Joined Dec 2007
Another good motor option for mid range speed is Sunnysky x2204.
Anybody who's into 250 fpv quads probably have a few these laying around
along with a 12amp ESC and a few Gemfan 5x3's.
Dewane is offline Find More Posts by Dewane
Old May 04, 2015, 10:18 PM
CelloGuy is online now
Find More Posts by CelloGuy
CelloGuy's Avatar
Australia, NSW, Sydney
Joined Apr 2013
Like Andy said, go the HK 24g 3000kv. Very powerful for its weight. It'll draw up to 27A with the right pack/prop. The Bonsai is limited a bit in speed by the high drag of the surface so most motors will only get it to a certain point but the 24g 3000kv will push it well past that limit. Good training for planes that are designed to go faster.
CelloGuy is online now Find More Posts by CelloGuy
Old May 05, 2015, 02:28 AM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Yep, that motor rocks! I've used both of these
http://www.hobbyking.co.uk/hobbyking...er_3000kv.html
http://www.hobbyking.co.uk/hobbyking...or_3000kv.html
as well as the Blue Wonder version. Difficult to pick between them so just go for what's in stock/local. Some esc's don't like the high kv but this one works and is cheap
http://www.hobbyking.co.uk/hobbyking...hless_ESC.html but you might need to opt for the 30 amp version if over propping the motor.
I do think that my scratch built KFm-4 wing of a similar size was faster on the same set up. It might be possible to coax a bit more speed out of the airframe by covering with laminating film.
Here's an example of how fast the motor can power a model where it's got a nice aerodynamic shape
The Wicked Little Babyshark Depron foamie RC micro speed plane (3 min 17 sec)
Just mental I reckon it would crush most "100 mph" out of the box RTF/ARTF's . Would love to see one race against the Durafly EFX racer and HK Funfighter Rare Bear on 3s
Andy
headlessagain is online now Find More Posts by headlessagain
Old May 05, 2015, 02:37 AM
CelloGuy's Avatar
Joined Apr 2013
The nanoplanes people from that video recommend the ZTW ESCs because they have the higher frequency that the motor apparently needs. The Blue Series ESCs on HK (and Mystery ESCs) are made by ZTW and have the same high frequency. I usually just use the 20A Blue Series if I'm not going to be up around 27A for more than a few seconds. Works a treat. Awesome little motor.
Old May 05, 2015, 04:10 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Thanks for the tip re the Blue Series esc's
Discussion HK Bonsai Wing ashdec87 FPV Talk 350 Apr 23, 2015 09:25 PM
Discussion Bonsai Wing FPV Maiden ashdec87 FPV Talk 9 Aug 21, 2012 04:59 AM
Discussion some questions about the HK Bonsai 4Anket2 Electric Plane Talk 4 Oct 23, 2011 07:20 AM
Video: "Bonsai" Heli with vstabi Kraeuterbutter Electric Heli Talk 13 Mar 11, 2005 04:23 AM
