Old Oct 18, 2007, 09:35 AM
Its not IF... Its WHEN.
The.Timinator's Avatar
West Yorks
Joined Feb 2007
Thanks for the offer Ben
Originally Posted by fatboywings
Well Bugger me!!!!!!!!!!!!!!!!!!!!!
But not while there are Sheep in the fields
The.Timinator is offline Find More Posts by The.Timinator
Old Oct 18, 2007, 09:39 AM
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Originally Posted by MarkusN
The only high lift device which I could imagine working on a plank are slats or nose camber increasing devices such as a drooping nose or Kruger flaps. I'd hate to steer a plank through the deployment phase of the latter, though.
A small split flap at 40%c will slow the plane without pitching the nose down (in fact it may pitch up a bit). Also a drag bar that extends from the tip of the fin could be used to make the Cm more positive without the lose of lift associated with elevator.
--Norm
nmasters is offline Find More Posts by nmasters
Old Oct 18, 2007, 09:52 AM
Joined Jun 2007
When I hear "slow down" I first think "high lift". But FBW has come clean now that it's mostly about bleeding away speed, so the split flap does work. Or does it increase Cl as well? I also like the idea to pitch up with drag high up without losing section Cl.
MarkusN is offline Find More Posts by MarkusN
Old Oct 18, 2007, 10:13 AM
The Predator
The Predator's Avatar
Golden, Colorado
Joined Dec 2004
I sure dig Ed's ballast drop plan with minichute/big streamer. Personally I think the lands can be done without any help slowing. Ian and I have been doing it with our JW/Firebird all season and never get/got dinged on landings ever.
For me, I'm not going to fly any ship at a weight I can not handle. I fly a few pretty fat ships. Sometimes the slowing IS the reason for a crash. Once near the ground and slowed your OPEN SEASON for any little bit of tubulance. I think a low fast down wind approuch, yes diving in at the front side of the hill a bit off angle with enough speed to handle a strong pull then stall turn without mushing works well if practiced. Then you're only exposed for that quick second in the stall turn with minimal ground speed and close to the dirt already. LOTS of practice runs required in BIG lift to establish the judgement require to approuch the hill with EXACTLY the right amount of speed to finish the turn at LOW speed. When in doubt just come in hotter and complete the turn with too much speed and just float back out onto the front and try again.
It'll still be cool to see a better mouse trap though, I like the BBB, BYE BYE ballast move! Not toally sure I want a floater in a hurricane landing either though. Speed = control in low rough air landing situations.
Yesterday I brought in my LJ up the backside and I just brought it in HOT did one S turn to make it a bit less painful then snagged it out of the air by a wing tip in substantial turbulence after one of the best DS acro flight of my life. I was estatic!!!
The Predator is offline Find More Posts by The Predator
Old Oct 18, 2007, 11:45 AM
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Anything that produces drag (decelerates the air) bellow the wing increases the circulation so there must be some lift but itís definitely not efficient lift.
--Norm
Old Oct 18, 2007, 01:37 PM
Biting ankles since '53
No Pants Island
Joined Feb 2007
Oh great. The Pred likes it, so now I'm committed to building it.
I just hope he never hears about my ballast weight on a threaded rod linked to a sail servo so I can do in-flight adjustable CG trials on on a single flight...
mr_editor is offline Find More Posts by mr_editor
Old Oct 18, 2007, 02:14 PM
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
Ed, I'm certain that ejectable ballast is against the BMFA safety code, which would, if my understanding is correct, invalidate your insurance......
satinet is offline Find More Posts by satinet
Old Oct 18, 2007, 03:10 PM
No Pants Island
Joined Feb 2007
Well shoot, life is full of risks.
8 hurricanes
2 stabbings
3 muggings
Several nasty Cuban/Brasilian/Venezuelan ex girlfriends.
2 ex wives
22yrs extreme sports
Where were the BMFA when I needed them for more than tossing a plane off a hill?
Old Oct 18, 2007, 04:01 PM
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
WOW! You've had a brasilian girlfriends? Thats A LOT of girlfriends!
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Oct 18, 2007, 04:43 PM
No Pants Island
Joined Feb 2007
Yeah. A close shave there...
Old Oct 18, 2007, 04:55 PM
fatboywings's Avatar
Newcastle Australia
Joined Nov 2002
I am sure most RCGroupies are able to use a jettison ballast system with caution.
So I guess the disclaimer would be, Check your policy and local club rules before making your final decision and always jettison safely.
Nuf about safety, any other ideas?
fatboywings is offline Find More Posts by fatboywings
Old Oct 18, 2007, 05:00 PM
smokin electrons...
skyzking's Avatar
Brisbane, Australia
Joined Jan 2007
I was thinking of using blade type spoilers on my next plank. I thought of a 4 servo setup but i want to reduce the amount of control surfaces on my TE to reduce the risk of flutter. I think either Graupner or Multiplex make some very good blade type spoilers.
skyzking is offline Find More Posts by skyzking
Old Oct 18, 2007, 05:02 PM
smokin electrons...
skyzking's Avatar
Brisbane, Australia
Joined Jan 2007
Wow jeeeezzz, when i was writing up my post (the previous one) i didnt know there were already 4 pages to it. Woops, sorry if im just repeating someone else's answer...
Old Oct 18, 2007, 05:06 PM
smokin electrons...
skyzking's Avatar
Brisbane, Australia
Joined Jan 2007
Another idea or technique i used was to program about close to 80 degrees of up elevator on my flying wings. And when i come in for landing pop the elevators up to a near vertical point, and it stalls the wing into the ground. If you do this while your into the wind, the landings are much more smoother...Works great with a fomie...
Old Oct 18, 2007, 06:02 PM
Twisted and Confused
flyonline's Avatar
Joined May 2003
Who, you or the brazilians.......?
Can't believe that no one else picked that first!!!!! D:
Steve
(sorry for hijacking the thread)
flyonline is offline Find More Posts by flyonline
bolt down wing instead of rubberband? Steph280 Sport Planes 5 Sep 10, 2003 02:19 PM
Slowing Down A D-99 Mark Haigh High Performance 18 May 07, 2003 07:30 PM
Trick for slowing down retract servos? Ben74 Radios 2 Sep 26, 2002 11:39 PM
Slowing down retract speed JayParke Electric Plane Talk 8 Apr 19, 2002 09:18 PM
