Old Sep 30, 2014, 09:57 AM
Kid at heart..
United States, TX, Houston
Joined Apr 2014
Best way to fix/touch up clear coat finish on fiberglass hulls.
Hi all, I did a search but did not find anything on this topic.
I have a fiberglass hull that is painted and clear coated. The clear is peeling/gone on some parts of the hull due to taping down the hatch. Is there a product/way to touch up and fix the clear coat on the hull? I want to avoid the tape from utlimately damaging/peeling the paint once the clear is completely gone.
Regards,
Dillin
hangtheman is offline Find More Posts by hangtheman
Old Sep 30, 2014, 10:08 AM
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
I am guessing the paint was not sanded/roughed up, before the clear was sprayed on. Sanding it down, and re-clear coating, after, roughing up the paint slightly, is probably going to be your only cure.
CaptCB is offline Find More Posts by CaptCB
Old Sep 30, 2014, 10:13 AM
Kid at heart..
Joined Apr 2014
Thanks CaptCB. Sorry I forgot to mention that this is a RtR boat so under the clear I believe are decals. I don't think its paint underneath so I can't sand it. Didn't know if there was a product to spray on over the existing clear. I was going to spray some clear over the area, but I am guessing that it will probably not stick to the existing clear nor last very long.
Old Sep 30, 2014, 10:22 AM
CaptCB's Avatar
Joined Aug 2011
On some of the RTR's, the "clear," is not even paint, it is a some sort of Vinyl coating.
Old Sep 30, 2014, 02:41 PM
United States, IN, Greensburg
Joined Jun 2014
I'm also interested in this topic.Im wanting to start racing so I thought it would make more sense if I restored an old boat instead of buying a nice new one and worrying about crash damage.
With the exception of the scuff on the deck and chips on the sponsons I haven't found any other damage on the hull.
This will be a slow restore over the winter and I'll start a thread for it.Id just like some advice on fixing the sponsons before I start ordering stuff.
micromodder is online now Find More Posts by micromodder
Discussion Advice on best way to find CG on f550 with landing gear? Troiano27 Multirotor Electronics 0 Oct 05, 2013 09:53 PM
Discussion Delta Force Fiberglass hull.....question on clear coat thomaslambo Racing Boats - Electric 2 Nov 26, 2010 07:45 PM
Discussion Finishing Chris-craft clear coat dietcoke Scale Boats 3 Jan 06, 2006 02:06 PM
best way to remove epoxy from fiberglass gel coat? JoeR Composites Fabrication 3 Feb 09, 2005 10:29 PM
