Old Jun 24, 2015, 08:20 AM
cessna180 is offline
Find More Posts by cessna180
Joined Nov 2013
hyperion prop adapter
I need prop adapter for a Hyperion Z4020-12 motor. As these are discontinued motors I am unable to find any prop adapters. I think a T-MOTOR ( PAO20) would fit. Any suggestions.
Michael
cessna180 is offline Find More Posts by cessna180
Old Jun 24, 2015, 08:28 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Are those collet type prop adapters? If so they can be bought from Maxx Products and many other places. I ask that because that is what Hyperion shows here:
http://media.hyperion.hk/dn/zs/zs4020-25.htm
Here is a U.S. place that has a lot of types and sizes of adapters:
http://www.headsuphobby.com/Prop-Adapters_c140.htm
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jun 25, 2015, 07:44 AM
JurassicJet is offline
Find More Posts by JurassicJet
JurassicJet's Avatar
United States, WI, Chetek
Joined Jul 2011
Cessna 180...
I have a similar thread that I started a month or so ago. I came up empty. I called Allerc and Randy from RC Dude. They seemed to think that the prop adapter for Hyperion was different than other manufacturers. There motors are similar to Scorpion so maybe a scorpion adapter would work. If you have luck finding one please let me know.
JurassicJet is offline Find More Posts by JurassicJet
Old Jun 25, 2015, 08:50 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
I assume you are looking for the bolt on prop drive, as just about any 6mm collet prop adapter could be used.
Have a look though this site, it looks like there is a bolt on prop adapter for the Z40 series.
http://www.airsportsrc.com.au/motors.html
eflightray is offline Find More Posts by eflightray
Old Jun 25, 2015, 09:03 AM
Joined Jul 2011
That site is in Australia or Austria and the prop adapter is $28 or $43 plus shipping.
I could probably make one on my mill and lathe if I really had to, or maybe modify an existing one. Thanks for the link though.
Old Jun 25, 2015, 12:21 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
It was the first site that came up in a search that had a picture, there may be others.
Old Jun 27, 2015, 06:30 AM
Joined Nov 2013
I ordered a bolt on prop adapter from Ready Made RC part # PA020 8mm ccw . I think it may fit. I will let others know when it arrives.
Michael
Old Jul 03, 2015, 10:16 PM
Joined Nov 2013
The T- Motor bolt on prop adapter that I ordered part # PA020 DOES NOT fit a Hyperion Z4020-12 motor. After some thought I think I will press out the shaft and reverse it. I think it should work and use a straight adapter. Any thoughts on this would be appreciated.
Michael
Old Yesterday, 08:23 AM
Jack
USA, ME, Ellsworth
Joined May 2008
These two threads are examples of how to modify shafts for reversing or adapting other shafts from one motor to another:
Making and Replacing a Brushless Motor Shaft - http://www.rcgroups.com/forums/showthread.php?t=1240725
HexTronik DAT-750/DT750 Replacing a Shaft - http://www.rcgroups.com/forums/showp...postcount=1080
The essential changes needed in the process are to sometimes have to add a snap ring groove and/or flats on the shaft for grub screws to bear on. And maybe remove a little bit of length in the adapted shaft. Other than those changes the important considerations are that of removing and replacing the shaft without damaging the bearings and other motor parts and that is easy enough to master.
For a multicopter (with their inherent inability to glide to a safe dead stick landing) I would probably use the set screw type prop adapters to reduce the chance of losing one in flight. I would add a small flat on the shaft for the set screw to bear down on and that and tiny drop of blue Loctite on the screw would make it nearly impossible to lose in flight.
Here is a good source for the adapters:
http://www.maxxprod.com/mpi/mpi-291.html
What they refer to as a 5/32" and 4mm adapter is actually a 4mm prop adapter that is a little less the 5/32". They just used the fact that 4mm (0.1575") is nearly 5/32" (0.15625"/3.96875mm). It never occurred to them that some old machinist would know that 4mm and 5/32" are two different sizes...
Jack
Wanted Hyperion Z40 series bolt on prop adapter/back mount JurassicJet Aircraft - Electric - Power Systems (FS/W) 7 Jan 10, 2015 11:59 AM
Sold Hyperion Z4020-10 with mount and prop adapter Twmaster Aircraft - Electric - Power Systems (FS/W) 2 Oct 09, 2007 05:15 PM
Sold NIB RCER Warp 4 BL415-3 with NIP Hyperion Prop Adapter phoneguy Aircraft - Electric - Power Systems (FS/W) 3 Sep 02, 2006 09:09 AM
Sold NIB RCER Warp 4 BL415-3 with NIP Hyperion Prop Adapter $55 shipped phoneguy Aircraft - Electric - Power Systems (FS/W) 1 Aug 08, 2006 02:39 PM
Alert Dangerous Hyperion M8 prop adapter flaw. Lynxman Power Systems 15 Jul 21, 2006 10:27 PM
