Old May 30, 2015, 11:19 AM
markm75 is offline
Find More Posts by markm75
Free Falling
markm75's Avatar
Joined Feb 2007
RC Plane Stand that can be used to test motors?
I'm looking for a better/safer way to test the motors on my Twinstar II.. has anyone used this HobbyKing stand..
I'm wondering if there is a way i can strap the plane to it and crank the engines to test..
What method/stand does everyone else use for testing.. curious..
markm75 is offline Find More Posts by markm75
Old May 30, 2015, 11:34 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Test.. what test?
I test my motors in my workspace.. then never give them a second thought.
These are not IC engines, they either work or they don't :-)
Bare is offline Find More Posts by Bare
Old May 30, 2015, 11:46 AM
markm75 is offline
Free Falling
markm75's Avatar
Joined Feb 2007
Originally Posted by Bare View Post
Test.. what test?
Well recently I was using a new battery pack (likely unrelated). During the flight one of the fronts if the motors flew off. EDIT.. i think it was just a broken prop mount bolt.. though the other half is embedded in the hole..
I figured maybe pre flight or like now after installing engines a full thrust test with the blades on could be useful beforehand.
My ts2 doesn't have wheels so the stands at the air strip aren't that useful
Old May 30, 2015, 12:08 PM
Clive66 is offline
Find More Posts by Clive66
Clive66's Avatar
United States, CA, Fontana
Joined May 2011
Put on the prop you want to test, plug a watt meter in, hold the plane & throttle it up (easy as that)
Clive66 is offline Find More Posts by Clive66
Old May 30, 2015, 01:54 PM
markm75 is offline
Free Falling
markm75's Avatar
Joined Feb 2007
I had a mishap inside once where i accidentally kicked the throttle.. for inside testing i figured it would be safer to strap it down
Old May 30, 2015, 03:22 PM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
That stand is basically just a plane cradle and it is to light to be holding back your plane unless it also is secured to something solid.
tacx is offline Find More Posts by tacx
Old May 30, 2015, 07:13 PM
Ira NZ is online now
Find More Posts by Ira NZ
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
Yeah, not heavy enough on its own, But no reason you can't strap your plane to it and then strap the stand to a couple bricks or something.
Ira NZ is online now Find More Posts by Ira NZ
Old May 30, 2015, 08:57 PM
redh is offline
Find More Posts by redh
Fla.
Joined Apr 2005
Do us a favor and NOT refer to a "MOTOR " as an ENGINE .
Then throw a rope around your tail and stab a screwdriver in the ground to hold the plane back or tie the rope to your work bench or something. ENJOY !!! RED
redh is offline Find More Posts by redh
Old May 31, 2015, 07:34 AM
mcnowhere is offline
Find More Posts by mcnowhere
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
I had not thought about running up a motor while plane is in the stand till I saw your post. These are easy and cheap to build and I think would do what you are asking?
Transport rc planes (1 min 2 sec)
mcnowhere is offline Find More Posts by mcnowhere
Old May 31, 2015, 06:16 PM
papadwight is online now
Find More Posts by papadwight
papadwight's Avatar
United States, TN, Murfreesboro
Joined Apr 2013
I like the pcp type that well hold the plane together.
papadwight is online now Find More Posts by papadwight
Latest blog entry: Flying Weather
Old Jun 01, 2015, 03:31 PM
markm75 is offline
Free Falling
markm75's Avatar
Joined Feb 2007
This looks fantastic.. i guess i'd just have to calculate the lengths of pipes to get and put it together.. not bad
Old Jun 01, 2015, 04:03 PM
3rd Try is offline
Find More Posts by 3rd Try
United States, NY, Champlain
Joined Jul 2012
The pipe comes in 10 ft lengths, then cut to desired size. Lay out the design to determine the number of elbows and tees your going to need . 1/2 inch schedule 40 pipe and 3/4 inch foam pipe insulation will complete the list.
Regards
Dennis
3rd Try is offline Find More Posts by 3rd Try
Old Jun 02, 2015, 09:12 AM
markm75 is offline
Free Falling
markm75's Avatar
Joined Feb 2007
Regards
Dennis
Any ideas what is being used to keep the elbows together, at least on the upper part.. i'm assuming maybe some welders glue or CA Medium in the joints to keep it tight for forward thrust tests..
I see in the one photo maybe two 5" bolts at the front with washer/nut combos it appears, then covered in foam for that part..
Old Jun 02, 2015, 12:39 PM
3rd Try is offline
Joined Jul 2012
PVC glue, on the shelf next to the PVC pipe, dries almost instantly on contact with the mating piece. You will also find a ratcheting plier style cutter in the same aisle.
Any good home improvement or hardware store will have everything you need.
Regards
Dennis
Old Jun 02, 2015, 01:04 PM
markm75 is offline
Free Falling
markm75's Avatar
Joined Feb 2007
Regards
Dennis
Thanks.. perfect..
I suppose if PVC glue holds well.. no need for the bolts then.
Discussion Best 3D micro heli that can be used with Futaba snuvet75 Micro Helis 7 Mar 09, 2015 11:41 PM
Question Starter Glider that can later be used for FPV? atuarre FPV Aircraft 5 Jul 02, 2014 07:57 AM
Discussion Starter Glider that can later be used for FPV? atuarre Beginner Training Area (Aircraft-Electric) 3 Jul 01, 2014 08:42 PM
Sold I have a Used Tatone Engine Test stand for .049 - .74 nitro engines sst2000 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 05, 2014 10:21 AM
Discussion Charger that can be used for 18v tool batteries deadhead Batteries and Chargers 1 Dec 25, 2013 05:17 PM
