Old Jul 12, 2014, 05:46 PM
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
I know for me when I fly her I use both AIL & RUDD in the same direction & than at some point in the turn I need to go opposite AIL, other wise she'll go into a spiral like maneuver & want to roll over.
Keeping in RUDD allows the nose to follow thru & putting in opposite AIL allows me to keep entering a "tight" banked turn yet still appearing like a coordinated turn. If that makes sense?
Haven't flown her in forever & took her up last month on Father's Day, whoa, after flying FPV & a quad I forgot what she was like, LOL.
I would recommend climbing a little, always helps if you have some altitude to recover ;-)
Best of luck
rcoconut is online now Find More Posts by rcoconut
Old Jul 12, 2014, 08:50 PM
cmd
cmd's Avatar
Niceville, FL
I agree. I put in a touch of aileron and then rudder the aircraft around, keeping the aileron neutral. Opposite aileron is applied before taking out the rudder and it rolls level as soon as the rudder is neutralized. I use just enough elevator to keep the nose from dropping. More bank means more elevator. Be careful in tight turns to keep the airspeed up so the blades don't slow and stall. If you don't have the blades flying, you don't have any lift.
It will cruise just fine at or above 1/2 throttle.
Keep it close. Orientation is a problem for me if I get it too far away.
cmd is offline Find More Posts by cmd
Old Jul 13, 2014, 08:22 AM
sanman55's Avatar
powder springs georgia
Joined Nov 2003
I also agree...she really is not too bad but if she gets away from you she goes down FAST..in that case just cut power and most likely very little demage will occur..
If you do not have the auto spin than take offs are tough...but with the auto she is very easy to take off..
Bank her first, release bank and use rudder and elevator to finish...use opposite airelon if you bank her too much...Once you get use to it she is really not bad and it just loves mild wind...like up to 10 mph...
sanman55 is offline Find More Posts by sanman55
Old Jul 13, 2014, 06:55 PM
cmd
cmd's Avatar
Niceville, FL
Has anyone found a way to get the blades to track? Mine are out by an inch from high blade to low blade. I balanced each blade individually and made each one identical in weight and moment arm, just like for my helicopter blades.
Old Jul 13, 2014, 09:46 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Balancing, normally doesn't effect tracking, pitch effects tracking. One is has higher or lower pitch than the other, or one blade is twisted more or less than the other.
Stevet.
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 14, 2014, 05:51 PM
cmd
cmd's Avatar
Niceville, FL
So how do I fix it?
Old Jul 14, 2014, 06:35 PM
SteveT.'s Avatar
San Jose, CA
Put some different color tape on the ends of each blade. Check to see which one is high or low, then adjust the pitch as needed.
SteveT.
Old Aug 11, 2014, 06:48 AM
QLD Australia
Joined Oct 2009
Yep-a little aileron and a lot of rudder.
Elevator requires constant attention[as it does not self-level itself so much like a plane]
minirotor is offline Find More Posts by minirotor
Old Aug 11, 2014, 06:59 AM
QLD Australia
Joined Oct 2009
1'' is not a big problem for a gyro[unlike helicopters]
Best balancing can be done by removing the head [with blades attached] Then insert a screw driver sharft[or simular tool] which is slightly smaller than the origional gyro head bolt.
Hold the head and blades side-on and see which blades drops.
Turn blades and hub 3 times in 1/3 of turn.
Add 1wrap of insulation tape to light blade[apx2" from tip] if required.
Also measure between the tips of each blade, when they are mounted on the hub[2-3mm diff is close enough]
I guess most people are using blade savers.
Remove inner bolt[the one closest to the centre of the head] and replace it with a wooden tooth pick.
Helps save blades in a rollover or crash.
Old Aug 11, 2014, 05:31 PM
cmd
cmd's Avatar
Niceville, FL
Thanks. I will give it a shot.
Help! Slow-g slow stick auto gyro PilotDragonfly Auto Gyros 4 May 23, 2012 08:14 PM
Sold Zenoah G-23 w/muffler and FEMA auto start LotusTRBO Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 05, 2006 11:27 PM
Discussion Xero G Auto. epc2 Electric Heli Talk 2 Apr 01, 2006 07:08 PM
Video Xero G Auto. epc2 Electric Heli Talk 0 Apr 01, 2006 02:35 PM
