Old Dec 15, 2014, 06:07 PM
Shove it punk!
Towson
Joined May 2009
Question
So, what ELSE can I do with 3000 watts of 12v - 30v dc?
I've finally got my two JD200 server power supplies all modded up and finished proper. So I can now charge at full speed with two PL8s at the same time. But what else can I do with such a powerful DC supply? Seems like there ought to be something cool to do with it besides charging batteries. I came up with HAM radio, and not much else. Any suggestions?
0reo is online now Find More Posts by 0reo
Old Dec 15, 2014, 06:22 PM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Wow! Perhaps you could process aluminum or do some arc welding.
whitecrest is offline Find More Posts by whitecrest
Old Dec 15, 2014, 07:23 PM
Joined Jul 2011
Trust me, it comes in handy in the summer time. My case has 4 external USB ports so I can keep my phone charged, WiFi hotspot powered, etc. In the summer though, it is nice having that much power because as an example, I might be flying my 700 heli (using 2 x 6S 5000 packs for one fight) and my friend might be flying my Carbon Cub (another 6S 5000 pack) so you can charge about 7 of those packs in about 15 minutes. Translated no waiting for batteries to charge
rocket_33 is offline Find More Posts by rocket_33
Old Dec 15, 2014, 07:34 PM
Shove it punk!
Towson
Joined May 2009
As far as I know, you can't arc weld with 30v DC. Not sure about processing aluminum. I'll look into it.
And, yea, great for charging batteries. No doubt.
Old Dec 15, 2014, 08:50 PM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
http://www.lincolnelectric.com/en-us/education-center/welding-safety/Pages/electric-shock-faqs.aspx
Excerpt from above:
Q: What voltages are used in the arc welding process?
A: Arc welding involves open circuit (when not welding) voltages which are typically from as low as 20 volts to as high as 100 volts.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Dec 16, 2014, 02:20 PM
Lake's Frozen Let's Fly
Rhea's Avatar
United States, MN, Eden Prairie
Joined Oct 2008
You can run a whole lot of LED Christmas tree lights and your doorbell too.
Rhea is offline Find More Posts by Rhea
Old Dec 16, 2014, 05:28 PM
juanjulian's Avatar
Guatemala, Guate
Joined Jul 2007
Power your electric motors directly from power supply.
Get a high power 90 mm edf to max out the power supply.
Cut your own foam cores.
Cheer
Juan
juanjulian is offline Find More Posts by juanjulian
Old Dec 16, 2014, 08:10 PM
Shove it punk!
Towson
Joined May 2009
Cutting foam cores sounds interesting. I'll have to look into that.
Old Dec 16, 2014, 09:16 PM
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
You can weld with 24 volts dc... you can weld sheet metal with 18 volts, but those power supplies wont do either, not nearly enough amps....
dacaur is offline Find More Posts by dacaur
Discussion I got a Watt Meter - so what now? almondsaz Power Systems 48 Yesterday 07:45 AM
Discussion What else do I need?! neavissa FrSky 6 Oct 15, 2014 04:29 PM
Discussion What else can I fly with my BNF Champ Remote? FTLOSM Beginner Training Area (Aircraft-Electric) 29 Feb 21, 2014 02:23 AM
Discussion What can you do with so much channel on your transmitter (Related to the Fut. T18MZ) Andreasdiaz Beginner Training Area (Aircraft-Electric) 10 Feb 03, 2012 03:17 AM
Idea What else can I do with this glider? fr4nk1yn Electric Plane Talk 0 Mar 15, 2007 06:34 PM
