Old Oct 11, 2014, 09:49 AM
Joined Sep 2014
Idea
CZ wing bolt holes elongated?
Recently while at a float fly several Carbon Z owners were discussing an issue with the elongation of the wing bolt holes.
I have corrected the problem on my CZ by grinding down brass servo grommet bushings to the same thickness as the wing attachment tabs and inserting and gluing them in the holes.
This corrected the loose condition of the wing and will prevent the plastic holes from being eroded in the future.
I used a pair of 5 hemostats as a thickness gauge while grinding.
fire capt. is offline Find More Posts by fire capt.
Question WOT4 wing bolt holes drilled wrong jimmyhorns Fuel Plane Talk 1 Jan 04, 2011 05:22 PM
Question Wing bolt holes jmole49037 Beginner Training Area (Aircraft-Electric) 0 Sep 22, 2009 10:15 AM
Discussion Elongated radial motor mount holes sam.huggins Electric Motor Design and Construction 0 Feb 17, 2007 05:54 AM
Ion wing strength around bolt holes EricSoar High Performance 13 Aug 16, 2005 03:41 PM
wing hold down holes elongating austinflyer Sailplane Talk 5 Sep 10, 2003 01:33 AM
