Closed Thread
Old Feb 12, 2015, 07:29 AM
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
Hobbyking (Art Tech) 1700MM PC6 Pilatus Porter Thread!
Hey gang,
I haven't seen a thread for this model, so I figured I would start one.
You can purchase the model HERE
I think it is a fantastic size, and the scale lines are maintained well. I swapped the motor on mine, from the 700kv mushroom type, to a 760kv FMS Edge 540 motor and prop. I trimmed the cowl to line up, and took about 3/4 of an inch of foam off behind the original firewall position. I will take some pics of how I did mine if there is interest, but here is a pic of my completed power swap. I also installed Dubro Low bounce 3.5 inch rubber tires, and I am running an 80 amp Hobbywing ESC, with an HK 5A/6V SBEC. The wingtip lights flash, so I did not leave them hooked up. I will upgrade the lighting package, and add floats. The floats from the E-flite Apprentice S are what I have chosen to retrofit. DImensions are just about perfect for this plane.
Cheers,
-CC
Cubcrazy is online now Find More Posts by Cubcrazy
Latest blog entry: Carbon Z Cub Floats are here!!
Old Feb 12, 2015, 12:30 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Here is my first video using the new Motor Setup. I only did trim flights with the stock power set.
1700MM Pilatus Porter (HK, ArtTech) (3 min 34 sec)
Old Feb 12, 2015, 08:06 PM
United States, NJ, Upper Freehold
Joined May 2012
Just came across your you tube flight video. Looks like a perfect plane for my needs.
Hope to see this thread take off.
LoDolce is offline Find More Posts by LoDolce
Old Feb 12, 2015, 09:39 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
With its high aspect ratio wing, and effective flaps, it performs beautifully. The stock power set is acceptable, but I wanted to correct the cartoonish spinner gap, and go to a 3 blade prop mostly for looks, but also sound. The FMS Edge 540 setup was a perfect match. I used to have a Fly zone Beaver, and I was mildly happy with it. This airplane out-performs that Beaver, even in stock configuration.
Old Feb 13, 2015, 07:46 AM
yorkiepap's Avatar
SW PA
Joined Aug 2010
Hey CC,
There is a thread already started on this plane under the "Scale ARF/RTF" Section. It would be nice to keep this model on one thread & personally, the HK Pilatus is definitely a "scale" model. Maybe get one of the Mods to move it for you. Here's the link.....
Denny
http://www.rcgroups.com/forums/showthread.php?t=2329019
yorkiepap is offline Find More Posts by yorkiepap
Old Feb 13, 2015, 08:31 AM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Thanks for the heads-up. I tried using the search function(which I am pretty good with usually) and came up empty. I will just shut down this thread.
Cheers
Closed Thread
Discussion Pilatus PC6 Porter Jab69 Foamies (Scratchbuilt) 2 Jun 24, 2014 08:11 PM
Contest Scale Build-Off 3 "Pilatus Porter PC6 (1/8.5 scale)" czirh Scale Kit/Scratch Built 15 May 31, 2014 02:48 AM
Discussion Pilatus Porter PC6 czirh Scale Fuel Planes 4 Jan 26, 2014 10:44 PM
Airfoil for Pilatus PC6 Porter ???? dont The Builders Workshop 30 Aug 13, 2007 05:57 AM
Sold FS: Pilatus PC6 Porter Plan Rudderman98 Aircraft - Electric - Airplanes (FS/W) 2 Nov 12, 2003 11:47 AM
