Old Feb 01, 2015, 10:23 AM
fly-crash-and crash-more
AirBro621's Avatar
United States, LA, St Francisville
Joined Dec 2014
flyzone F4U corsair
so i got this corsair for free! its in pretty good condition for a free plane the motor mount is bent- and the prop shaft is bent- and i need 2 new servos. here's some pics
AirBro621 is offline Find More Posts by AirBro621
Old Feb 01, 2015, 01:58 PM
Coy, peruser of worlds
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Good fortune, there! FYI, thread running on those here: http://www.rcgroups.com/forums/showthread.php?t=1769940
Cowls are relatively expensive. I did a little investigating and discovered the one on the Lx F4U 1200mm from Banana Hobby (Blitz Works..?) can be adapted, is cheaper, and sturdier. Only, a bit heavier.
gnats82 is offline Find More Posts by gnats82
Old Feb 01, 2015, 03:11 PM
AirBro621's Avatar
Joined Dec 2014
thanks
Old Feb 02, 2015, 01:36 PM
Unregistered User
Eagle2Nitro's Avatar
Joined Apr 2014
Does anyone know if this motor will fit the Flyzone Corsair mount?
http://www.hobbyking.com/hobbyking/s...10Kv_350W.html
http://www3.towerhobbies.com/cgi-bin...?&I=LXCVBY&P=Z
If it doesn't, what cheaper motors are there that do? The Flyzone replacement motor is $59.99!
Eagle2Nitro is offline Find More Posts by Eagle2Nitro
Latest blog entry: Full Scale Aircraft
Old Feb 02, 2015, 02:28 PM
AMA 994002
matiac's Avatar
United States, RI, Westerly
Joined May 2012
I would just look on Hobby King's site for their nearest number to stock, I'm sure they have something close, if not the same output. As for the motor mount, mine nosed in and bent the mount, I just bent it back, and I'm still using it. Needless to say I did get a spare, should the need arise. They're GREAT fliers once you get 'em dialed in, mine's one of my go-to's for the field, and cuts a beautiful figure in the sky...
matiac is offline Find More Posts by matiac
Latest blog entry: Stability issue
Old Feb 02, 2015, 04:01 PM
F106DeltaDart's Avatar
United States, AZ, Prescott
Joined Jan 2011
There are plenty on hobby king that will work, but it depends what you want. Do you want to turn a big scale diameter 3 Blade prop, go fast, or try to keep equivalent stock performance with a 2 blade?
F106DeltaDart is online now Find More Posts by F106DeltaDart
Old Feb 02, 2015, 07:03 PM
AirBro621's Avatar
Joined Dec 2014
I just painted the corsair today! it looks great
Old Feb 03, 2015, 08:11 PM
Unregistered User
Joined Apr 2014
I'm not trying to break a speed record, I just want a motor that will perform well, for a budget price. A warbird should have pretty good power. I don't know how powerful the stock setup was.
I just need to know if the HK motor's mounting holes will line up with the stock mounting holes.
Sold Flyzone F4U Corsair T-RX NIB Local pick up land guru 1 Aircraft - Electric - Airplanes (FS/W) 5 Nov 16, 2014 09:14 PM
Sold Flyzone F4U Corsair Select Scale NEW $125.00 MIGPILOT44 Aircraft - Electric - Airplanes (FS/W) 1 Oct 26, 2014 08:32 PM
Help! Hobbyking Orangerx RX3s w/ Flyzone F4u Corsair question ShakeNbake718 Radios 0 Oct 18, 2014 09:42 PM
For Sale Flyzone Corsair F4U --- $100 plus shipping jeb6684 Aircraft - Electric - Airplanes (FS/W) 2 Dec 15, 2013 06:18 AM
Sold NIB flyzone f4u corsair RTF w/battery!!!! jackal111 Aircraft - Electric - Airplanes (FS/W) 6 Nov 06, 2013 10:41 AM
