Old Feb 08, 2015, 01:52 PM
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
Tow coupling ready with a 30 kg servo .
The pushrod is a spoke from a bicycle wheel
And wings are ready for cowering wednesday
6 meter DG800s, Towcoupling (0 min 6 sec)
Cheers
Soren
SpeedsterDEN is online now Find More Posts by SpeedsterDEN
Old Feb 08, 2015, 08:51 PM
Blenheim, NZ
Joined Dec 2007
Release design
Release looks a bit of a concern to me. Just my view. You don't want it to jam under extreme load.
I would support the pin over the length that is above the bracket with a thick tube or drilled block. Lube it with grease. Try and get rid of the bend in the spoke. That will just straighten out underload and cost you pin movement. Keep the servo arm as short as possible for the movement you want to maximise pull.
Finally test what every you come up with and prove to yourself you can release with a load of twice the glider weight.
It could save your model and a tow plane.
Allan
AllanK1 is offline Find More Posts by AllanK1
Old Feb 14, 2015, 03:49 PM
Joined May 2010
Tested the coupling with 24 kg pull with no problems, after that I move the spoke to the innermost hole in the servo arm.
Working on the wing root today, this is not easy because its twisting and turning in all angels
Nice to have a large basement.. but it needs 3 rooms when the wings are on.:
D
Cheers
Soren
Old Feb 15, 2015, 07:40 PM
yyz
yyz's Avatar
USA, CA, Paso Robles
Joined Dec 2004
Serious style points for those winglets! Your build is coming along great.
yyz is offline Find More Posts by yyz
Old Feb 16, 2015, 08:37 PM
MTT
I care about rising air !
MTT's Avatar
West Chester, Ohio
Joined Feb 2002
And a serious style point deduction for that tow- release !
Yes, it will work, but..... This is the kind of tow release I would expect to see in a 3m china ARF, not a high end 6m ship....
MTT is offline Find More Posts by MTT
Old Feb 25, 2015, 03:53 PM
Joined May 2010
The evening Work.
Cheers
Soren
Old Feb 26, 2015, 03:14 PM
Less Whinning, More Flying
Sailhigh's Avatar
SF Bay Area, USA
Joined Feb 2003
She is starting to look real nice Soren.
Sailhigh is offline Find More Posts by Sailhigh
Old Feb 26, 2015, 08:59 PM
Burning & Turning
justy g's Avatar
Hong Kong
Joined Jan 2007
Looking great..
justy g is offline Find More Posts by justy g
Old Feb 27, 2015, 12:55 PM
Joined May 2010
Today I got the flaps and ailerons covered.
S
Old Feb 27, 2015, 10:02 PM
Burning & Turning
justy g's Avatar
Hong Kong
Joined Jan 2007
Getting ever closer to a maiden
Old Yesterday, 01:13 PM
Joined May 2010
Now servos are in the wing and working on the wire harness.
Cheers
Soren
Old Yesterday, 01:30 PM
United Kingdom, Glos
Joined Feb 2009
Is this one for the Fun Cub to tow
FrankS is online now Find More Posts by FrankS
Old Yesterday, 02:07 PM
czorzella's Avatar
United States, FL, Kissimmee
Joined Jan 2012
Cheers
Soren
Soren,
Are you really going to use an ORANGE receiver in this sailplane?
Carlos
czorzella is online now Find More Posts by czorzella
Old Yesterday, 03:10 PM
Joined May 2010
Originally Posted by czorzella View Post
Soren,
Carlos
No, just for testing the wire harness and servos
For Sale 6 Meter DG-600 Wingbags qm1usn Aircraft - Sailplanes (FS/W) 1 Nov 22, 2013 01:27 PM
Help! prop/spinner for DG 1000 sailplane 2.65 meters phil alvirez Electric Sailplanes 10 Apr 09, 2013 11:43 PM
For Sale 6 meter all molded RIPO DG 800 marios Aircraft - Sailplanes (FS/W) 5 Nov 27, 2008 01:56 PM
Question DG 800 S (2 meter) from Thermo Flugel isoarthenland Scale Sailplanes 0 Mar 19, 2006 09:52 PM
Fly a DG-800s 6 meter scalesoar Scale Sailplanes 2 Jun 23, 2004 06:59 AM
