Old Jun 02, 2015, 11:46 PM
SJN is offline
SJN
Find More Posts by SJN
SJN
Boston
Joined Dec 2003
Question Re: Eagle Tree Guardian Setup using JR XP9303
Appreciate any advice on setting up an Eagle Tree Guardian I recently purchased. On my JR 9303, I copied a working 5-channel plane config to a another model memory location. This config is an electric plane using flaperons with ch 5 set for left aileron. Receiver is a Berg 7 channel. I connected the servos (right aileron, elevator, rudder & left aileron) to correct outputs on the Guardian with left aileron to AUX. From the Guardian to the receiver via connection harness, I connected aileron, elevator, rudder to the correct receiver channels & Guardian AUX to receiver channel 5. When powered up, all surfaces seem to work fine with exception of left aileron. Left aileron servo has power, but does not respond to left or right stick input. Not sure what I need to do.
I also would like to use the 3 position AUX2 switch on the 9303 to disable input from the Guardian and also to enable 2D or 3D flight modes.
Any feedback is much appreciated!! Thanks!!
SJN is offline Find More Posts by SJN
Sold Eagle Tree Guardian - Used - SOLD Lilienthal Aircraft - General - Radio Equipment (FS/W) 1 Apr 17, 2015 01:58 PM
For Sale Eagle Tree Guardian 2D/3D Stabilizer: (2) new (1) used JimG_AZ Aircraft - General - Radio Equipment (FS/W) 3 Mar 03, 2015 07:55 AM
Found used Eagle Tree Guardian 2D/3D Stabilizer-- Wanted jimmbo Aircraft - General - Radio Equipment (FS/W) 0 Feb 26, 2015 12:03 AM
Question Can the Eagle Tree Guardian Stabilization Module for OSD Pro be used by itself? bobrc11 Eagle Tree Systems 3 Feb 14, 2015 06:58 AM
Sold Used: Eagle Tree Guardian 2D/3D Stabilizer jafo216 Aircraft - General - Miscellaneous (FS/W) 2 Jan 24, 2015 09:46 AM
