Old May 21, 2015, 04:23 PM
Tommy Ted is offline
Find More Posts by Tommy Ted
Joined May 2015
Propellers
Good day sir! Can any body help me please? I am a newbe and i want to make an rc boat, i have a homelite mighty lite 26cc 2 stroke weed wacker engine that i want to use for my boat project and planing to make a 40inch body. What diameter size of propeller can i use for this engine. And will it be a 2 leaf prop or 3 leaf?
Thank you so much
Tommy Ted is offline Find More Posts by Tommy Ted
Old May 21, 2015, 04:28 PM
txt killer is offline
Find More Posts by txt killer
Joined Apr 2008
The 26 cc Homelite engines are not the best to use as they are crappy engines. Not as good as the 25-30 cc engines but will work. For a prop size Prather S 260 2 blade. The hull should be 48" long.
txt killer is offline Find More Posts by txt killer
Old May 21, 2015, 05:22 PM
Joined May 2015
Thank you so much for your fast reply sir. Do you have any idea were i can buy that & the propeller shaft for the prather s 260? I am from anaheim sir and i am not so familiar with the place cause i am new here. Thank you so much for your help! God bless!
Old May 21, 2015, 05:28 PM
Joined May 2015
And by the txt killer sir, what rudder model or rudder size do i need? Thank you!
Old May 21, 2015, 06:31 PM
Joined Apr 2008
Online is the best way to shop. You will need a turn fin as well as a prop.
http://www.ebay.com/itm/Rudder-strut...item1e59052457
http://hyperprod.bizhosting.com/
Old May 21, 2015, 06:40 PM
Joined May 2015
Thank you!��
Old May 22, 2015, 08:23 AM
Joined Apr 2008
You have a lot of work ahead of you. Don't buy stuff you don't really need. If you don't know ask. Use every part of the trimmer head tank, throttle cable, flex cable. Keep mounting brackets for the motor simple and light weight. Weight is your biggest enemy when building a boat.
Discussion Have you found it? fluorescent propeller( the most comprehensive propeller ) lina2014 Power Systems 2 May 16, 2014 05:52 PM
Question What is the story on APC style propellers...one propeller is both CW & CCW? bobdul13 Multirotor Power Systems 6 Dec 20, 2013 02:03 AM
is a PUSHER Propeller is a "regular" Propeller ? lempert Beginner Training Area (Aircraft-Electric) 2 Apr 13, 2004 04:39 AM
propellers,propellers and more propellers zicmu Modeling Science 5 Jan 16, 2004 08:12 PM
Propeller Clerance and Propeller Size okan Power Systems 1 Dec 30, 2002 11:08 AM
