Old Dec 03, 2013, 11:07 PM
Enforcement is offline
Find More Posts by Enforcement
Australia
Joined Feb 2013
New Product
Blackout Mini Spider Hex - 290mm - Carbon Fiber - Built for FPV
http://www.minispiderhex.com/
I'm pleased to announce my second mini multirotor frame, the Blackout Mini Spider Hex !
Using everything using I've learnt from building my Mini H Quad, it was time to step up the game and bring GoPro footage to Minis.
A big thank you to all of the testers and people I annoyed with questions
Goals
  • Durable !
  • Under 300mm MTM
  • GoPro 1/2/3 carrier
  • Designed for Open Pilot Revolution w/ integrated V8 GPS mount
  • Under 1 kilogram (2 pounds)
  • Integrated Anti-Vibration tray for GoPro & Battery
  • More stability for better video
  • Integrated CCD camera mount
  • Good run times, 10minutes +
  • Good performance (at least 2.5:1 power:weight ratio)
Specifications
  • Frame Weight: 180 grams
  • Size: 290mm MTM
  • Materials: 3k Twill Weave Carbon Fiber
  • Fasteners: Stainless Steel & Black Polymaide GV
  • Maximum Propeller: 5"
  • Motor Mount: M2 12mm - 19mm
  • Fight Controller Mount: 30.5mm x 30.5mm & 45mm x 45mm
  • Board Camera Mount: 32mm x 32mm
  • GoPro mount: Accepts LayerLen & Eyefly GoPro 3 Carbon Fiber (or G10) case
Suggested ComponentsAUW: 895grams
Flight Time: 11-13minutes
Hover Time: 13 minutes +
Power:weight ratio: 2.8:1
This includes absolutely everything listed above. GoPro3 Black, Nano Tech 3300mah 3S, CCD camera, Revo, GPS, OP link antenna - no trickery here
Is it possible to run a small 2200mah with Mobius (or no HD camera) to reduce the AUW to 600-700grams. This results in a lot more power and run time, a perfect racer !
If I've missed anything, please ask
History
I drew a lot of inspiration from the Shrediquette MM6, this guy is a legend and has done all of this long before me !
MK1 Prototype
Several prototypes were made and tested, the first being the "MK1". This Mini Spider Hex was 280mm MTM and used the MT1306 motors.
Originally designed with these motors, this hex was 2S powered and was about 700grams.
You may have seen this Hex in use from Vegetoast. Sadly the little MT1306 motors (even on 3S) didnt have the puff to deliver the experience we wanted.
While this was happening, the Tiger MN1806 "Blackout 3S" 2300kv were being developed. The project was put on hold until these motors were put into production.
There were a few design fubars, like not leaving enough room for the Revo Right Angle servo pins. Woaps !
The battery tray was too short and didnt entirely support the battery at it's correct CoG location
But, this is what prototypes are for !
MK2 Prototype
The MK2's MTM was increased to 290mm MTM to better clear thrust obstructions.
A "tail" was added to the battery tray for vertically mounting large batteries. Vertically mounting helps remove the battery as an obstruction of thrust.
Arms were increased to 3mm, they are now fully compatible with my Mini H Quad V2 Arms. This helps reduce the amount of spare parts needed ! The middle and rear arms are slightly longer than the front arms, both are identical.
Most importantly, she had MN1806 motors added Now it was a rocket !
Most of the videos you have seen are of this prototype.
One slight bug remained. The hanging style bobbins. They held in during hard flying and removed all jello perfectly.... until a hard crash. This is when the pain started ! While nothing ever broke, sitting on the side line furiously pushing bobbins back in was an awful experience
Several methods of fastening were explored, but none were 100% successful. An upgrade to the more expensive Sandwich Style mounts was required.
Version 1
Not being able to find the right type of mounts at an acceptable price, I had custom sandwich mounts made.
Instead of being the male/male mounts, they are male/female. The idea is nylon will be inserted into the female section. During a hard crash the nylon will break, saving the expensive sandwich mount.
This version bought together all of the development from the previous prototypes. Finally the frame is ready for prime time
Enforcement is offline Find More Posts by Enforcement
Old Dec 03, 2013, 11:08 PM
Australia
Joined Feb 2013
Build Log
Below is a mash up from 3 different builds combined into 1.
As always, I enjoy the build process as much as the flying.
The trick is to do it in small jobs, not an 8 hour bender !
Australia
Joined Feb 2013
Australia
Joined Feb 2013
Australia
Joined Feb 2013
Australia
Joined Feb 2013
Old Dec 04, 2013, 07:13 AM
Oso Grande is offline
Find More Posts by Oso Grande
Need more props..........
Oso Grande's Avatar
United States, TX, Houston
Joined Jan 2013
You are an evil man my friend. This came out beautifully!
Oso Grande is offline Find More Posts by Oso Grande
Old Dec 04, 2013, 09:05 AM
awdspider is offline
Find More Posts by awdspider
Team cobra USA/ team n-armed
awdspider's Avatar
Joined Jan 2006
That's what I've been telling him too. I'm glad he finally posted official pics because it's been driving me crazy knowing what he had in the works and I had to keep my lips sealed. Bravo Enforcement, Bravo! It's a thing of beauty! Is mine in the mail? Lol
awdspider is offline Find More Posts by awdspider
Old Dec 04, 2013, 01:24 PM
1sq is offline
1sq
Find More Posts by 1sq
1sq
1sq's Avatar
United States, CA, Imperial Beach
Joined Mar 2013
That's looks like an Alien craft we watch on tv.
Very nice BO.
1sq is offline Find More Posts by 1sq
Old Dec 05, 2013, 02:10 AM
Australia
Joined Feb 2013
Teaser 2 video
You can get a good look at it here
Blackout Mini Spider Hex Teaser - Part 2 (1 min 20 sec)
Old Dec 05, 2013, 03:30 PM
Australia
Joined Feb 2013
Demonik being a hoon
Revo Hex Lunchtime flips (5 min 56 sec)
Old Dec 05, 2013, 03:48 PM
1sq is offline
1sq
1sq
1sq's Avatar
Joined Mar 2013
Did you dubbed a formula one car engine sound into this video? Dang that sound is furious and every flip recovery is smooth and no wobbles.
Old Dec 05, 2013, 03:54 PM
Australia
Joined Feb 2013
haha, it sounds angry doesnt it ?
When you do a high speed pass, it sounds like a bunch of angry hornets got into an F1 car haha
Demonik has been doing an awesome job with the tune
Once a few more frames get out there, it will be awesome to see what you guys do with it !
Old Dec 05, 2013, 04:44 PM
MayMayDay is online now
Find More Posts by MayMayDay
Crashing is my thing.
MayMayDay's Avatar
Canada, BC, Vancouver
Joined Mar 2012
Took me a day and a half to load this page (soooo many pics), but it was totally worth it. Guess I'm selling my other kidney now...
MayMayDay is online now Find More Posts by MayMayDay
New Product Blackout Mini H Quad - 220mm - Carbon Fiber - Built for FPV Enforcement Multirotor Talk 14130 Yesterday 09:16 PM
New Product Phoenix Flight Gear 242 Carbon Fiber Flight Ring for Acro/FPV Z06 Tony Mini Multirotors 13 Apr 14, 2014 08:34 PM
New Product Phoenix Flight Gear 328 Flight Ring Carbon Fiber Frame For FPV/Acro Z06 Tony Multirotor Talk 3 Jan 22, 2014 07:50 PM
Sold Spider Hex, Zombie FPV v1 frames, Mystery A2212-15 930KV Motors For Sale Mike Carrio Aircraft - Electric - Multirotor (FS/W) 4 Jun 04, 2013 06:15 PM
Sold Hex Spider FPV still for sale KiTCyclic Aircraft - Electric - Multirotor (FS/W) 0 Aug 05, 2012 10:54 AM
