Old Jul 10, 2016, 11:37 AM
johnnydaking is offline
Find More Posts by johnnydaking
Joined Jul 2016
Help!
PPM Signal from PC to Transmitter Module
Hello there,
what i aim for:
-500m - 1km range.
-Send PPM Signal from PC to Transmitter Module to Quadcopter receiver
product thoughts:
-http://www.hobbyking.com/hobbyking/store/__90770__OrangeRX_DSMX_DSM2_Compatible_2_4Ghz_Tran smitter_Module_V1_2_JR_Turnigy_Taranis_compatible_ .html
-https://www.sparkfun.com/products/9718
approach toughts:
-connect USB to FTDI Adapter
-connect FTDI Adapter to PPM IN PIN on Transmitter Module
-Use FTDI Driver to send serial data in form of PPM
question:
-is there any "open source" ppm receiver? I guess if i would like to use my Turniny 9x Transmitter module/receiver pair i would have to know their encoding for the ppm signal, right?
Any help appreciated
johnnydaking is offline Find More Posts by johnnydaking
Old Jul 10, 2016, 04:30 PM
phil_g is offline
Find More Posts by phil_g
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
Originally Posted by johnnydaking View Post
...approach thoughts:
PPM isnt RS232 serial !
Maybe RS232 serial from the PC to a dedicated serial-in/ppm-out board.
Have a look at the FMS flight sim dongles on ebay. They convert USB to ppm and appear as a virtual serial port to the PC. Otherwise homebrew a serial-in/ppm-out arduino, easy enough.
Then you'll need to write your PC app which generates the serial commands.
I'd suggest some further study as this isnt a trivial task if you're going DIY.
Cheers
Phil
phil_g is offline Find More Posts by phil_g
Old Jul 10, 2016, 05:08 PM
Joined Jul 2016
Cheers
Phil
Hello phil_g,
thanks for your answer.
Do you know a good serial-in/ppm-out board? http://www.ebay.de/itm/12in1-RC-Flug...YAAOxyUrZS53fj is that what you mean? But isnt that PPM to USB (or can it be also used for USB to PPM)?
Another question is: Do i have to send the serial data in a specific format/protocol? Doesnt every brand have different protocol?
Also do i have to attach this to the RC-Controller trainer port or do i have to attach this to the RC-Controllers Transmitter Module? (They have serial in pins)
And basically, dont these RC-Transmitter Modules actually act as a kind of serial in/ppm-out converter? http://www.hobbyking.com/hobbyking/s...Module_RX.html
Im a little bit confused
Thank you
Old Jul 10, 2016, 05:21 PM
kuroguy is online now
Find More Posts by kuroguy
United States, NC, Raleigh
Joined Nov 2010
Arduino can do this if you know how to solder. There's ppm pins and a serial or usb port depending on how you want to interface to ypur computer. You'll need to write some code but it is a simple problem if you know how to use an arduino.
kuroguy is online now Find More Posts by kuroguy
Old Jul 21, 2016, 02:11 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Check flytron cable USB-PPM, it does exactly what you want and has a library to use from almost any programming languages.
renatoa is offline Find More Posts by renatoa
Old Jul 21, 2016, 09:47 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Why not use the PC's sound card? That's how we used to do it...
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Jul 21, 2016, 10:35 AM
renatoa is offline
Joined Sep 2007
Weak resolution... at 44100 sampling rate will have 44 samples per millisecond.
Thus 44 steps per channel...
Discussion Obtaining a PPM signal from a RoyalPro transmitter (V3.30 firmware) YannickF DIY Electronics 290 Feb 25, 2015 03:00 AM
Discussion inserted signal PPM to modules 2.4ghz use NRF 24L01 John michel DIY Electronics 1 Jul 11, 2013 11:54 PM
Discussion PPM signal from a PPM rx vegasbs FPV Talk 3 Apr 30, 2011 08:52 AM
Help! Getting PPM signal from noname transmitter hefest DIY Electronics 2 Nov 24, 2009 02:45 AM
Discussion MPX RoyalPro, PPM signal, 2 modules (41 MHz and 2.4 GHz) YannickF Radios 6 Feb 28, 2009 04:03 PM
