Old Jun 29, 2016, 01:29 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
Max signal rate of digital servos
Is there an overview somewhere regarding what signal rates the different GWS servos can handle?
If not,
1. what is the correct setting for Naro+ D, 250 or 333Hz?
2. Analog Naro works with 111Hz (9ms), but is it safe to use this rate?
Fred
flarssen is offline Find More Posts by flarssen
Old Jun 29, 2016, 05:09 AM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
Hi Fred,
I've been told that the frame time used on GWS Analog servos is 16 - 21 ms, 18 - 20 ms is better.
While frame time period used on Digital servos is 5 ms.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Jun 29, 2016, 05:51 AM
flarssen is offline
Son, Norway
Joined Sep 2004
Thanks Chen.
5 ms is only 200Hz. Most gyro stuff is 250/333Hz.
Sounds like I should at least avoid 333Hz .
Fred
Old Jun 30, 2016, 03:50 AM
GWS CHEN is offline
Taipei, Taiwan
Joined Oct 2005
Hi Fred,
It's ok working with Gyro in 250Hz, but not the 333Hz one.
Chen
Old Jun 30, 2016, 03:55 AM
flarssen is offline
Son, Norway
Joined Sep 2004
OK. Thanks for clarifying this.
Fred
Question Taranis Setting min max servo travel High / Low rate Ndanger Radios 14 Jun 06, 2016 06:29 AM
For Sale spektrum 6gram digital servo pair weak signals saturday pu jbrracer Aircraft - General - Radio Equipment (FS/W) 1 Apr 04, 2014 10:41 PM
Discussion are all digital servos good for 300Hz PWM signal? hamburger Micro Helis 0 Jun 12, 2013 12:25 PM
Discussion Frame Rate Variation with Digital Servos jihlein Hitec/Multiplex USA 2 May 23, 2008 03:42 PM
