Old Dec 02, 2014, 03:51 PM
Joined Dec 2014
99 in butterfly setup ?
I'm building the "Butterfly" which calls for a 15 glow engine but I would rather make it electric. It has a 99 inch wingspan and flying weight around 50 ounces - wing loading around 7 and a half oz. What I want to know is what do I need in the way of a brushless setup?? motor size/esc/battery??
dumm thumbs is offline Find More Posts by dumm thumbs
Old Dec 02, 2014, 05:35 PM
If it flies - I want one!
Petem's Avatar
Werribee, Victoria, Australia
Joined Jul 2008
Butterfly elec conversion
The Butterfly is basically a powered glider, so a good starting point might be between 150 and 200 watts per kilo of all-up weight.
Weight should increase very little with the conversion, so work on 1.5kg total, that gives somewhere between 225 and 300 watts - or 20 to 30 amps from a 3S LiPo delivering approx 10V under load.
A battery to deliver that sort of power for, say, six minutes will need to be around 2200mAh.
For the motor, have a look at the HK SK3 Gliderdrive series with the hard case and connectors on the back - the 3.5 960kv might work well here, with a 10x6 folding prop. Easy to install and will handle the power you need.
For a speed control, allow some 'headroom' and go for a 40A ESC - I use the Turnigy Plush series with zero problems.
Be aware, though, that there are as many answers to your question as there are modellers - you can certainly spend a fair bit more on a quality setup if you prefer that route (and I do, with my larger or more expensive models), but the setup above should work well and provide good performance at very moderate cost.
Cheers, and have fun,
PeteM
Petem is offline Find More Posts by Petem
Old Dec 02, 2014, 08:41 PM
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
I think you have good advice above from Pete! That motor is very easy to mount compared to other brush-less motors (no wires to rub).
I would add that you want an ESC with a switching BEC (as opposed to linear), they cost a "little" more but worth the "buffer" for servos.
If you are going to fly this like a glider, a smaller battery (3Cell 40C 1800mAH) will be better and possibly a 11x6 prop. If you want it to fly like a powered plane, go with the bigger battery for longer run time.
From a safety perspective, get a spinner that allows you to use Aeronaut or Graupner (Esprit hobby is a great source) folding props (assuming you want a folder). There are various brands but these have published specs' on speed and are a known quantity. I am not a fan of some the Hobby King plastic ones...
Scott
ScottSails is online now Find More Posts by ScottSails
Old Dec 02, 2014, 10:17 PM
Petem's Avatar
Joined Jul 2008
Agree all, Scott: I buy lots of stuff from HK, but have found their props to be something of a lottery in balance, fit and strength/longevity. Trouble is, a decent folder setup can cost more than the rest of the equipment fit!
And you are right, if model is to be flown as a powered aircraft most of the time, a folder is not needed.
Pete
Old Dec 02, 2014, 10:18 PM
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Hi,
Nice info shared.
I would also check out this thread as Kimber ended up extending the nose some to aid in balance.
http://www.rcgroups.com/forums/showt...y#post24523609
Jared
jcstalls is online now Find More Posts by jcstalls
Old Yesterday, 01:05 PM
Joined Dec 2014
Since the butterfly has a tendency to be tail heavy and since my wing is 5/8 inches wider than the plan shows, should I move the wing forward or back 5/8th of an inch to compensate ? I'm still in the build stage and a little confused on this question.
Old Yesterday, 01:23 PM
jcstalls's Avatar
Joined May 2002
Hi,
Well, if you read through the whole thread, you should be fine if you are extending the nose.
5/8th either way is not that much for the main wing.
Split the difference and move on.
Where are the snappies,
Jared
Discussion In the 9C butterfly setup menu, what is Preset? RCGwhinerFest Sailplane Talk 3 Sep 10, 2013 12:37 AM
Sold dynaflite butterfly 99" lpu for $75 in north park san diego warhawk crazy Aircraft - Fuel - Airplanes (FS/W) 0 Jul 19, 2013 08:15 PM
Discussion Butterfly 99" So many possibilities. Eric1180 Night Flying 0 Aug 20, 2008 07:15 PM
FS--Daynaflite Butterfly 99" wing dumbthumbs Aircraft - Electric - Airplanes (FS/W) 6 Dec 01, 2004 03:01 PM
