Old Jul 06, 2016, 01:44 PM
adamalbert is offline
Find More Posts by adamalbert
United States, CA, San Jose
Joined Jan 2005
Question
Flyzone Micro Calypso, Binding rudder/elevator
Hello,
I have a new Micro Calypso. The rudder and elevator movements are jerky like the the controls are binding. There is a very noticeable delay between full right and full left, In slower movements the rudder and elevator seem to be moving in steps instead of linear.
I have checked the servo wire exit from the fuselage and the servo wire 'guide' half way down the tail. Neither seem to be the cause.
I am looking for other ideas before I disassemble the fuselage(which I would like to avoid)
Thank you,
Adam
adamalbert is offline Find More Posts by adamalbert
Old Jul 08, 2016, 11:44 AM
CorvetteC5 is offline
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
Maybe loosening the hinge joints of the elevator and rudder would help with the binding. Should be easy enough to unhook the control rod at the control horn and then flex the control surfaces to their extremes a few times to loosen the foam hinges.
While disconnected, exercise the servos and confirm they are smooth. If they are not then look for binding from the control rods around the fuselage exits.
CorvetteC5 is offline Find More Posts by CorvetteC5
Old Jul 09, 2016, 05:17 PM
Joined Jan 2005
good idea, thanks
Old Jul 18, 2016, 01:25 PM
Joined Jan 2005
solved
The issue was two fold.
The servo rods were binding on the supplied guide, even if they appears loose enough. I replaced them with tubes.
The second issue were the rods binding as the exited the fuselage. I piece of tape at the exit point reduced friction enough to fix it.
Old Jul 23, 2016, 01:21 PM
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
Nice!
Discussion Flyzone Micro Calypso jobinseattle Electric Plane Talk 65 Jul 08, 2016 08:55 AM
Article Flyzone Micro Calypso Jason Cole Electric Sailplanes 2 Jun 18, 2016 06:30 PM
Sold Flyzone micro P-38 Lightning Bind and Fly shschon Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Oct 31, 2015 02:37 PM
Discussion Problem Binding Flyzone Calypso Bellke Beginner Training Area (Aircraft-Electric) 17 Oct 12, 2014 05:54 AM
Sold Flyzone Sensei, New Wing/Rudder/Elevator/Landing Gear/Cowl/Motor Ifly101 Aircraft - Electric - Airplanes (FS/W) 0 Feb 24, 2013 03:16 PM
