Old Jul 10, 2015, 01:27 PM
SeByDocKy is offline
Find More Posts by SeByDocKy
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
Mini-Review
FX758 200mW VTX (vs the TX5823) (Under construction)
INTRODUCTION
Here is a new competitor in the lighweight 200mW 5.8G VTX market, the FX758. This model is a direct competitor of the Boscam TX5823 and the Flysight TX5200m. I will compare the first two models in this mini-review
OVERVIEW
In term of size, both models are similar
With the metal casing, the weight is equal to 2.2g
versus the TX5823
or the TX5200m
Without casing, the weight decreased to
Pin 3 & 4 of the RTC6705 are used to select frequency band. Actually the Band "A" is selected.
Short pin1 to activate freq selection, select band "E" (Boscam band like the TX5823)
according to this table
FOR ONLY BAND E + Channel select with DIP switch: pin1 to gnd
FOR ONLY BAND A + Channel select with DIP switch: pin1 to gnd + pin3 to gnd + pin 4 to gnd.
For example, for the band E, jump like shown in blue
TESTING
200mW 5.8G VTX: FX758 vs TX5823 (Courtesy Banggood) (19 min 59 sec)
CONCLUSIONS
Even if the output power seems a little bit less versus the TX5823, the signal is much more cleaner and robust to noise/motor interferences.
With 1.5g without casing, this FX758 can be ideal for cheap and light 5.8G FPV DIY projects.
PROS
+ Clean signal (as good as the TX5200m)
+ Light
+ Cheap
+ Band "A" by default (like the TX5200m, ~fatshark compatible)
+ Work from 3.3V up to 5V
CONS
- Not true 200mW
- Band selection requires to remove the metallic cover
- Not Band "E" by default (Boscam)
- Can't select freq out of the box (need to short pin 1 for band E and eventually pin3&4 for band A as depicted in photo)
This VTX have been courtesy provided by Banggood in order to make a fair and not biased review. I would like to thanks them for this attitude.
You can find it actually for 11 USD at FX758
SeByDocKy is offline Find More Posts by SeByDocKy
Old Jul 15, 2015, 09:22 AM
LumpyLouis is offline
Find More Posts by LumpyLouis
United States, VA, Alexandria
Joined Nov 2012
Seby, I wasn't quite sure from your pic where to jump. Your diagram just kind of points to what looks like a cap but I cant tell which end I should jump to. Please let me know if this is correct, thanks.
LumpyLouis is offline Find More Posts by LumpyLouis
Old Jul 15, 2015, 09:55 AM
SeByDocKy's Avatar
Joined Dec 2012
I see more like this
Old Jul 15, 2015, 10:02 AM
derelicte is offline
Find More Posts by derelicte
Joined Aug 2006
the a band frequencies are 5mhz higher than fatshark frequencies. how well does that work?
derelicte is offline Find More Posts by derelicte
Old Jul 15, 2015, 10:24 AM
Joined Nov 2012
[QUOTE=SeByDocKy;32161048]I see more like this
Ah, OK I see now, thank you for the clarification youre the best.
Old Jul 16, 2015, 10:52 AM
mallettron is offline
Find More Posts by mallettron
Ronnie - Sheffield UK (G0NJD)
mallettron's Avatar
Sheffield, S. Yorks, UK
Joined May 2007
So its not 32 channel and you have to dissasemble to get to the band points
Bit of a waste, think I will stick with the standard 8channels
mallettron is offline Find More Posts by mallettron
Old Jul 16, 2015, 12:14 PM
SeByDocKy's Avatar
Joined Dec 2012
Yes it's a good choice ... now almost everyone got a 32CH VRX
Old Jul 20, 2015, 05:02 PM
matrixFLYER is offline
Find More Posts by matrixFLYER
matrixFLYER's Avatar
Italy
Joined Nov 2011
To remove the metallic case you need hot air or just a soldering station? Is the metallic case soldered in 2 points? Is it hard to remove?
3.3-5v so it works with 1s lipo? And with lower voltage you get less mW output? Thank you!
matrixFLYER is offline Find More Posts by matrixFLYER
Old Jul 21, 2015, 07:59 AM
SeByDocKy's Avatar
Joined Dec 2012
yes I removed with my normal iron. Little by little. Only two points. It's not hard but not too easy. Just a little of patience.
Yes it work with a 1S. I will publish a DIY step by step building of a cheap and lightweight 200mW 5.8G kit with this VTX. Yes the less input voltage, the less power you will emit
Old Jul 22, 2015, 10:34 AM
Joined Nov 2012
That's a great idea, thanks Seby, people are charging/paying way too much for micro 5.8 setups when they can diy their own for so cheap.
Does this get as hot as the TX5823? My TX5823 gets seriously hot even on 3.7V. I received my FX758 but I haven't tested it yet.
Old Jul 22, 2015, 11:07 AM
SeByDocKy's Avatar
Joined Dec 2012
I published the builtlog/tutorial here: http://www.drone-maniac.com/diy-chea...nd-cl-antenna/
Old Jul 28, 2015, 08:15 AM
Joined Nov 2012
So I pulled the shield off yesterday... OMG, there is no way I will be able to bridge that microscopic cap! Its a fraction of a millimeter between each one. I am very comfortable with a soldering iron but this is a job for Ant Man.
Old Jul 29, 2015, 02:52 AM
SeByDocKy's Avatar
Joined Dec 2012
Yes it's pretty hard.... need a very thin tip and x20 magnifyer I think
Old Jul 31, 2015, 06:07 PM
ludorc is offline
Find More Posts by ludorc
Joined Jun 2014
Sorry noob question : doesn't the shield act as a cooler ?
Is it OK then to remove it permanently for flight? What would be the pro and cons?
ludorc is offline Find More Posts by ludorc
Old Aug 01, 2015, 01:56 PM
SeByDocKy's Avatar
Joined Dec 2012
It's acting more as a Faraday's cage .... to limit RF external interences but as you can see in my demo video, the signal is really clear without....
Discussion This 5.8G 200mW (TX5823) 5v compatible ? Altura FPV Talk 231 Apr 25, 2016 10:36 AM
Careful! Lots of TX5823 200mW modules are actually ~50mW PSI. FPV Equipment 66 Jan 16, 2016 04:34 PM
New Product FX758-2 200mW VTX, direct competitor of the TX5823, TX200m SeByDocKy FPV Equipment 9 Oct 29, 2015 05:14 AM
Discussion 10mW vs 200mW VTX Power Consumption Witterings FPV Equipment 7 Jan 31, 2014 02:14 AM
Sold Boscam TX5823 5.8G 200mW 3.3V - 13 USD incl. shipping kornetto FPV Equipment (FS/W) 2 Sep 16, 2013 08:09 AM
