Old Dec 12, 2014, 09:58 PM
stonerscolony's Avatar
The Netherlands, NH, Enkhuizen
Joined Jul 2007
Revell 1/64 car in a can RC - Futaba conversion + nano FPV
First of all big thanks to benito with his thread here: 1/64 Gran Torino
However he's using a mix of old components which only helps so far for people like myself who want to use new or real brand radio gear.
For the most part I've followed benito's method with cutting the chassis into 3 pieces and dumping the middle. Then turning the front steering block around 180 leaves a nice empty space to make an attachment to the original steering rack.
However I used an servo horn as the connection method with wire that was originally the cars mhz antenna (recycling).
For a speed controller I stripped a $3 turnigy servo for its PCB and pot which I kept as one piece so I can trim by the pot if there is any stuttering.
Here is the progress so far but it's not done. Note there is a set of spare power lines left open which is for the nano FPV setup section this weekend.
More to come!
stonerscolony is offline Find More Posts by stonerscolony
Old Dec 13, 2014, 04:27 PM
Joined Jul 2007
I get a new batch of 10mW nano 5.8 video transmitters tomorrow and so cannot continue the car build until then however given the aim of this project is that myself and 3 other friends can all race we need a track and to make these look somewhat nice with the FPV kit onboard.
As the camera is the primary issue height wise it means I cannot make a car shell or similar as it just won't fit. But after seeing a small static lorry model I have on my shelf here I realised a Lorry front end would house the camera and the lipo can go on the back!
As for the track and because I ain't so rich I plan to recycle an old paste board table that is pretty untouched but not so flat (a cheap one). However I've found driving around it testing its more fun this way but I need to extend the width.
The table is 200 cm by 60cm wide so I plan to make removable side sections to extend to 100cm wide in parts. Reason for removable is so the table can fold back up and be put away.
Old Dec 14, 2014, 03:14 AM
Joined Jul 2007
I've continued with the shell for the build. The lorry idea worked out pretty well and allows me to mount the camera in the cabin area so it perfectly sticks out the front and the VTX should fit in there also (in theory ha).
I find decorating things this small a bit fiddly but I like the end result.
Old Dec 14, 2014, 10:09 AM
Joined Jul 2007
I have a problem with clearance on the front, when reversing its all fine but on forward motion with the motor pushing the front end down it scrapes along at any real speed.
I've noticed that if the front wheels had the same thickness as the rear motor wheels that it would be fine.
Anyone know a trick to make them thicker? I have tried heat shrink pipe but it pops off. Or where to buy the thicker motor tyre types / something .
*edit found certain hotwheel models have rubber tyres the same wheel diameter, looking in shops this week.
Old Dec 14, 2014, 11:22 AM
American-TableTopTrophyTruck
United States, CA, Riverside
Joined Sep 2013
187trophy trucks
ya you could use some lego tires like the ones in pic ,but yes your going to have to heat them up with some boiling water then fit and cool them ,to the rim's , you may have to widen frame and body fenders . yeah i have the same chassis and some stretched lego tires , and i check the cleance its about 4mm from the ground ,it should work just fine.
187trophy is offline Find More Posts by 187trophy
Old Dec 14, 2014, 11:33 AM
Joined Jul 2007
I had considered exactly that (photo is my computer shelf lol), although heating them up etc does make a lot of sense but hadn't thought of it.
The only issue is the traction they provide, or do they become more sticky after a round of heating ?
Old Dec 14, 2014, 11:40 AM
Joined Sep 2013
great traction,i use them on my 1/64 offroad trucks all the time.
Old Dec 14, 2014, 11:49 AM
Joined Jul 2007
Ah it now all makes sense, I tried warming one of mine and the rubber has recovered a little to the original tacky like state. But the vibration from the wheel pattern is no good for the nano FPV camera because I'll see nothing and maybe go green a little lol
I think looking for a cheap hot wheels car or similar is best option.
Nice tip though for 4*4 projects - I won't forget
Nice builds also
Old Dec 14, 2014, 11:59 AM
Joined Sep 2013
yes hotwheels/matchbox tires work to, orignal tire from rc /just put it round hotwheels tire
Old Dec 14, 2014, 12:42 PM
Joined Jul 2007
Well after your input and talking to the other drivers I'm now looking tomorrow for one of these:
Hot wheels or similar thick rubber wheels
Hot wheels or similar thin rubber wheels and just double up as you said will also work if all else fails.
Scaletrix parts < ! didn't even think of that before either
Bound to find something now
Old Dec 15, 2014, 11:52 AM
Joined Jul 2007
Well I went and got some Hotwheel models with the right size tyres to find back home there all now plastic ...... grr.... There is a hobbyshop not so far away by train that sells them but his site has no images of the scalectrix tyres and the price of a train ticket is more than the parts+shipping, stuck between a rock and a hard place lol.
Old Dec 15, 2014, 01:00 PM
Joined Jul 2007
Scalectrix will work for anyone else attempting this.
But I've found a good substitute which I have readily available. This is 6/4mm bungee line from Hobbyking.
Because it has a lot of stretch it was perfect to cut a piece off and slip it over the original tyre as an extra layer. It increased the front end ride height by 1mm which is perfect, the bottom no longer hits anything
Maybe later I'll get proper ones but for now this is fine, loads of traction. Tonight is FPV set-up and to see if I can dig out a 10 Ohm resistor somewhere for the motor to stop the start-up stutter effect (Step down the voltage a tiny bit)
Old Dec 15, 2014, 05:55 PM
Joined Jul 2007
Well the rebuild of this revell car in a can so far has went excellent no real complaints to speak of beyond being fiddly as hell but that's to be expected.
So this post aims to wrap up the rest of the build. The above posts already show the conversion of the chassis and making a custom shell, now it's time to add FPV and push the boat!
So first the 5.8ghz 8 channel 10mW nano VTX (video transmitter) has power and video line soldered in place. The camera requires the same 3 lines and so when both are soldered they can be joined together with the video cable being direct camera to VTX and the power cables just joined up ready to use but not covered.
I decided to see if I could push my luck and use the original lights that where on the model, the rear light died but no matter the fronts still work and so I soldered them in also to use the same power line
To make the shell still removable I put the final power connections on 2mm bullet plugs so it can always come off. I also extended the power line cable for the lipo itself as it needs to go all the way to the back and plug in.
See photos for rest of description
Still not done as this thing needs a track to race on - wait for it
Old Dec 15, 2014, 06:50 PM
Joined Aug 2007
Maybe this video could help in making your own tires.
Making of Rubber Wheels 1/87 (8 min 47 sec)
benito is offline Find More Posts by benito
Old Dec 15, 2014, 07:14 PM
Joined Jul 2007
http://www.fatedev.com/project?p=145...s+and+nano+FPV
My project page with every photo I took and full step by step instructions.
Thanks for the video link but I've arranged with a friend to visit a big model shop this weekend where we have a pick of small tyres
Edit I've watched the full video and I think I have to give that a go!
Discussion RC Trucks & Cars incl in FPV scavenger hunt Spec UAV Car Talk 0 May 29, 2014 02:02 PM
Discussion someone should make a FPV RC CAR video in TRAFIC! muckfoot Car Talk 7 Feb 28, 2014 04:05 PM
Discussion How i can put a second carema for see back on my rc car in fpv ... mtlcom FPV Talk 2 Oct 28, 2012 02:11 PM
Help! Can I conver the Giant Scale 83" CMPro Cessna in to Brushless? lrplin Giant Electric Planes 29 Jul 16, 2009 09:58 PM
