Old Jul 11, 2014, 07:30 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
New Product
FFM 200 QX (Replacement airframe for the Blade 200 QX)
FFM 200 QX
Blade is making some great little quads and we like making them even better. The FFM 350 QX replacement frame is a popular upgrade for that quad and having just got a 200 QX we decided to mod it too.
The frame weight came out between 42g and 60g depending on how you build it.
The top plate is optional and provides a platform for FPV and or a Mobius HD camera. The battery can be mounted on top as well or underneath.
The landing gear is also optional. The frame weight with out the top plate and gear is around 42g. With is 60g.
We will post some build pictures shortly in post #2 but the conversion is easy. The electronics are removed from the stock frame and the plate with the control and ESC boards is cut out. The plate sandwiches between the two plywood plates and then the electronics are reinstalled. The motor mount holes even have the alignment flat spots.
Check out the pictures and ask any questions you have. As for why plywood? We have found that the plywood gives great durability for the weight, there is no signal loss with FPV like on a carbon frame and the wood tends to dampen any vibrations.
Fancyfoam
motorhead is offline Find More Posts by motorhead
Old Jul 11, 2014, 07:41 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
Unscrew the body screws and carefully split the top and bottom halves.
Unscrew the nuts on the motors and remove the motors.
Remove the screws holding the speed control board and lift the board. Be careful with the ribbon cable.
Remove the screws holding the control board and remove it. Lift the electronics as one assembly and set aside.
Proceed with the pictures below.
After the motors are mounted the frame will be secure and you can mount the control and speed control boards to the plastic tray.
The LEDs can be inserted into the holes in the arms. You will need to carefully bend the LED wires over so the wires lay flat.
The top plate can be mounted along with the landing gear and camera mount.
The battery can be mounted on bottom or top with a velcro strap.
Please post any questions, comments and pictures of your setups.
Fancyfoam
Old Jul 11, 2014, 10:12 PM
Timmyd463229's Avatar
Joined Jan 2012
Looks cool...and cheaper...is it heavier or lighter than stock and are we going to he able to buy the parts separate if we break say a arm or plate
Timmyd463229 is online now Find More Posts by Timmyd463229
Old Jul 11, 2014, 10:14 PM
Reunion
Joined Nov 2010
Very nice! Will we have to solder?
Papangue is offline Find More Posts by Papangue
Old Jul 11, 2014, 10:37 PM
Multirotor Enthusiast
United States, FL, Hollywood
Joined Dec 2006
Isn't plywood going to make the frame heavier than stock?
Is there a weight savings with this Frame!
SteveNunez is offline Find More Posts by SteveNunez
Old Jul 14, 2014, 08:47 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
The plates/arms are one piece but if you need a specific replacement part I can supply it separately.
Fancyfoam
Old Jul 14, 2014, 08:49 PM
motorhead's Avatar
Kansas, USA
Joined Sep 1999
No soldering is required. The frame is designed so you can unbolt your electronics and drop them right on. You will need to cut the speed control and control board tray loose from the stock frame and reuse it.
Fancyfoam
Old Jul 14, 2014, 08:54 PM
Joined Jan 2012
So is it heavier or lighter than the stock frame
Old Jul 14, 2014, 09:10 PM
Joined Dec 2006
Timmy, I'd like to know that also. +1
Old Jul 14, 2014, 09:29 PM
Joined Feb 2014
Me too
Little Cow is offline Find More Posts by Little Cow
Old Jul 15, 2014, 12:25 AM
dx4life
Wichita KS
Joined Nov 2004
Useful weights
stock frame - 42g (no hardware no board mount)
stock frame + lg - 52g
ffm 200qx frame - 42g (no hardware no board mount)
ffm 200qx frame + lg - 46g
ffm 200qx frame + lg + top plate - 60g
200qx goes on vacation (4 min 54 sec)
Mine RTF in my videos = 244g
minus mobius = 204
minus battery = 154
BrainDrain_dx is online now Find More Posts by BrainDrain_dx
Old Jul 15, 2014, 12:47 PM
Joined Feb 2014
Thanks BrainDrain for the info.
Old Jul 15, 2014, 12:57 PM
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
What is your VTX ?
SeByDocKy is online now Find More Posts by SeByDocKy
Old Jul 15, 2014, 02:04 PM
dx4life
Wichita KS
Joined Nov 2004
Originally Posted by SeByDocKy View Post
What is your VTX ?
vtx (bottom 3 of the search, I'm 1280)
http://www.readymaderc.com/store/ind...d=pico&x=0&y=0
Old Jul 15, 2014, 02:33 PM
Always, against the wind
Thetis's Avatar
United States, IL
Joined Oct 2011
What are the advantages and benefits vs stock? How much ?
Thetis is offline Find More Posts by Thetis
Discussion best replacement frame/body for QX 350 RickC2009 Multirotor Talk 16 Yesterday 05:47 AM
Discussion FFM 350 QX (Replacement airframe for Blade 350 QX) ***Official build*** BrainDrain_dx Multirotor Talk 32 Aug 14, 2014 12:04 PM
New Product FFM 200 QX (Replacement airframe for the Blade 200 QX) motorhead Multirotor Talk 1 Jul 11, 2014 07:02 PM
Sold Blade 350 QX / 200 QX - USB-Interface - Multi Rotor Programmer - BLH7840 Fidelity101 Aircraft - Electric - Multirotor (FS/W) 1 May 31, 2014 01:21 PM
