Old Oct 12, 2014, 09:20 AM
Joined Jul 2005
Inlet Ring Design
Going to try something out on my Slymaster Sabre, struggling with high battery and ESC temps, so going to look at going with a half unducted system.
Duct inlet directed to the fan with about 150mm gap between them and the Inlet ring. I will stick the ESC in the airflow and batteries will be in the vicinity but not directly getting airflow.
I've knocked up an intake as shown below (as well as polishing off a cupcake !!!). I've made it so air speeds up to the inlet. I've seen a number of different designs, I've got a radius on the lip, some have been a very round and large radius others a bit more simple.
How does mine look below to the big brains out there ??
Cheers
Wayne
Waggas is offline Find More Posts by Waggas
Old Oct 12, 2014, 01:00 PM
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Looks pretty good to me!
But I am a pea brain, too . You're gonna need a few more yea's to be secure.
Got any more cupcakes?
PikeStaff is offline Find More Posts by PikeStaff
Old Oct 12, 2014, 01:15 PM
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Inlet Ring and Sabre = AIR SALLY
He'll let you know!
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Oct 12, 2014, 02:40 PM
Slovakia, Veľký Krtíš
Joined Dec 2006
My inlet rings I do from balsa...
http://www.rcportal.sk/zachranene-dmychadlo-g2362
pajlotmato is offline Find More Posts by pajlotmato
Old Oct 12, 2014, 04:15 PM
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
The cross section should resemble a Clark-Y airfoil. With the base of the airfoil facing outside of the fan.
Fuzz
St. Martin is online now Find More Posts by St. Martin
Old Oct 19, 2014, 09:42 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
I have Had good luck with an eclipse
AIR SALLY is offline Find More Posts by AIR SALLY
Old Oct 20, 2014, 07:36 AM
St. Mary, Maryland, United States
Joined Dec 1996
Sun or moon?
ellipse
Chris True is offline Find More Posts by Chris True
Old Oct 20, 2014, 09:43 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Elliptical shape......it is the pain meds.
Old Oct 20, 2014, 11:56 AM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Eclipse makes coffee syrup for milk shakes, here in RI. Good stuff..
Old Oct 20, 2014, 01:05 PM
jhaywood's Avatar
United States, VA, Suffolk
Joined Nov 2007
so what are the pros and cons with using an inlet that stops short of the fan w/an intake ring vs. no ducts at all w/an intake ring vs. fully ducted?
I know that fully ducted will give you the best top end, right?
jhaywood is offline Find More Posts by jhaywood
Old Oct 20, 2014, 03:05 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
Right. Any turbulence results in thrust loss both static and dynamic.
Fuzz
Old Oct 20, 2014, 04:20 PM
Joined Jul 2005
I'm sure there is some losses doing half ducting. Speaking to a learned friend in such things with a lot of experience with edf send he said he couldn't tell the difference when he flew with full ducting and half ducting (with a ring).
I don't think I gave the courage to try it with no ducting at all. Might add that to my testing on the weekend. But would have to make everything is tied down well.
Could this be an advantage of the new multi blade fans being a bit more flexible on the installation ???
Wayne
Wanted Inlet ring for 90mm CS fan Frankensteen Aircraft - Electric - Jets (FS/W) 5 Feb 28, 2014 06:54 AM
For Sale fiber glass inlet ring AIR SALLY Aircraft - Electric - Jets (FS/W) 15 Feb 14, 2014 04:23 PM
For Sale Air Sally inlet ring for Ramtec Fan AIR SALLY Aircraft - Electric - Jets (FS/W) 0 Feb 11, 2014 11:35 AM
Wanted 90mm EDF INLET RING cnchelicopter Aircraft - Electric - Jets (FS/W) 0 Nov 10, 2013 02:29 PM
Wanted 70mm fan inlet lip/inlet ring PaulDaniel Aircraft - Electric - Jets (FS/W) 2 Dec 10, 2011 06:39 PM
