Old Oct 03, 2014, 11:27 AM
United States, FL, Apopka
Joined May 2012
Futura Sport Jet Plans
Looked high and low for Futura plans after deciding it would be my next scratch build and could not find any. So after a few hours in sketchup I came up with some workable plans. I wanted to share my results here with anyone else that has more time or resources than I do to complete the build as both are very limited for me. I included a 3d template that helps form the curve in the shape of the intake/thrust upper decking. This design was originally created to build a 56" wingspan for 90mm edf using the 3/4" pink foam. To get a feel for the build I have shrunk the plans to 25% and am building a test model out of Dollar Tree Foam. This turns out to be a 14" wingspan. I am so pleased with how its taking shape that I am going to put an AR6400 brick in it and try to make it a micro pusher before starting on the large model. I am willing to share the sketchup file or resize for anyone that would be interested in building on a different scale.
NotFastEnuf is offline Find More Posts by NotFastEnuf
Old Oct 03, 2014, 01:01 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
This model ? --
https://www.google.co.uk/search?q=Fu...H&ved=0CCAQsAQ
eflightray is offline Find More Posts by eflightray
Old Oct 03, 2014, 01:30 PM
Joined May 2012
Yes that's the one. Here is my progress so far...
Old Oct 03, 2014, 01:35 PM
Joined May 2012
This is the initial assembly
Old Oct 03, 2014, 01:41 PM
Joined May 2012
Here everything is glued together with some minor sanding to shape and awaiting an AR6400 brick most likely located where an EDF fan will go on my full size 56" build. Without electronics, fuselage is weighing in at 17 grams.
Help! Minx or sport jet plans 91pilot Scratchbuilt EDFs 30 Dec 20, 2013 09:31 AM
Discussion Futura ss /Funkey 60 size Jet Ranger conversion egall232 Large Electric Helis 2 Mar 31, 2010 11:09 AM
Sold Invader II All-Wood Ducted Fan Sport Jet Airplane Plans junieb Aircraft - Electric - Jets (FS/W) 0 May 27, 2007 10:09 PM
Sold F-15 Eagle Sport Scale Ducted Fan Jet Airplane Plans junieb Aircraft - Fuel - Jets (FS/W) 0 May 27, 2007 09:42 PM
