Old Apr 30, 2015, 01:22 PM
kitfoxdrvr is offline
Find More Posts by kitfoxdrvr
Authorized Self-Portrait?
kitfoxdrvr's Avatar
Greensboro, NC
Joined Nov 2003
Wiring a Four Servo Wing
I love soldering! Sarcasm of course, but it is necessary duty I guess. I am wiring my wing on an Omega 2.5 and have all the wires soldered and pulled from the servos to the root, and have a four plug Deans connector soldered in place at the end, one on each wing (black on one, red on the other, glad they come in two colors!). Pretty simple thus far...
Now my question, on the receiver side, I know I need two for signal, but do I need a + and - for both servo leads or just for one? Could one lead to the receiver have just the signal wire? Can't think of a reason not. Not much of a weight savings, but thought I would ask.
Thanks!
Kit
kitfoxdrvr is offline Find More Posts by kitfoxdrvr
Old Apr 30, 2015, 01:51 PM
greyhound flyer is offline
Find More Posts by greyhound flyer
Genie Builder
greyhound flyer's Avatar
Portland, Oregon, United States
Joined Aug 2004
This document has everything you need: http://augiemckibben.tripod.com/site...ng_harness.pdf
greyhound flyer is offline Find More Posts by greyhound flyer
Old Apr 30, 2015, 02:03 PM
kitfoxdrvr's Avatar
Greensboro, NC
Joined Nov 2003
The answer is yes! Thanks for the very well explained link, greyhound, I will be flying this weekend!
Old Apr 30, 2015, 04:31 PM
Genie Builder
Joined Aug 2004
You're welcome, Kit. Harley's documents are a treasure trove of building techniques and ideas!
Old Apr 30, 2015, 07:20 PM
mlachow is offline
Find More Posts by mlachow
Joined Oct 2005
My standard connection is to use one 24 Guage wire for power and a 26 or 28 for signal. I put a signal and ground on one and signal and positive on the other. You need the two pins to make sure the connector stays in the rx. The wire is silver plated copper with a thin Teflon insulation but it is expensive.
If you really hate soldering, the nicest wiring I have seen delivered with a model comes with the pike perfection. It is nicely done and not overweight.
mlachow is offline Find More Posts by mlachow
Old Apr 30, 2015, 09:26 PM
kitfoxdrvr's Avatar
Greensboro, NC
Joined Nov 2003
Good idea on the two pins. Makes sense.
Where do you source that wire? I just used heavy duty Hitec three strand like I always have, but individual wire would make parts of the process easier. None of the runs on the Omega are very long, but still...
Old Apr 30, 2015, 10:01 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Ground Penetration Tester
United States, VA, Waynesboro
Joined Dec 2005
The quality of the wire and connectors are important. I get my wire from Hansen Hobbies.
http://www.hansenhobbies.com/products/
You can take the 3 wire and pull it apart for individual wires.
Lou is offline Find More Posts by Lou
Old May 01, 2015, 08:38 AM
mlachow is offline
Joined Oct 2005
Alpha wire 2844/19 is the 24 guage. Newark carries it. The 26 and 28 start with a different number.
If you crimp the 28 then you need a short piece of heat shrink right at the end to crimp.
Old May 01, 2015, 09:27 AM
kitfoxdrvr's Avatar
Greensboro, NC
Joined Nov 2003
Great resources, thanks Lou and mlachow! Got more than I was looking for, thanks for the direction!
Discussion F3K wing servos wiring awacsCZE Hand Launch 17 Yesterday 12:06 PM
Sold Four servo plug wing Harness FieldofDreamsFlyer Aircraft - General - Miscellaneous (FS/W) 2 Jan 04, 2015 09:57 AM
For Sale Four servo plug wing Harness FieldofDreamsFlyer Aircraft - General - Radio Equipment (FS/W) 0 Jan 03, 2015 09:39 AM
Sold Four servo plug wing Harness FieldofDreamsFlyer Aircraft - General - Miscellaneous (FS/W) 1 Dec 31, 2014 12:18 PM
Sold Four servo plug wing Harness FieldofDreamsFlyer Aircraft - General - Radio Equipment (FS/W) 0 Dec 31, 2014 11:53 AM
