Old Sep 09, 2014, 07:45 PM
Dpetsel is offline
Find More Posts by Dpetsel
Dpetsel's Avatar
United States, IA, Coralville
Joined Jun 2012
Build Log
BBCC5 JETEX F4 Phantom - Dpetsel
Well....
2 weeks ago my beautiful 90 MM F4 lost an aileron servo horn through the styrofoam and did a beautiful roll onto it's back and into the ground. I have decided to reincarnate the Phantom as a 70 mm EDF balsa framework based on the FF model by Jetex.
I am currently working on my scratchbuilt proto of the Sukhoi SU26m, so it may be a couple of weeks before I can start the build. I have started CAD drawing of the model to estimate AUW, battery compartment and fiberglass ducts for the 70 EDF. I did some tests on a couple of EDF's I have and have found one that puts out about 1 lb 7 oz. of thrust on a 3 cell. My electronics weigh about 9 oz. If I can get the airframe to come in under 1.5 lbs it will probably be a flyer.
Here is a shortcut to the contest.
http://www.rcgroups.com/forums/showthread.php?t=2218067
For any of you that have never seen Jetex/Rapier FF jets fly there are a few neat videos on youtube.
Here are the plans.
Dpetsel is offline Find More Posts by Dpetsel
Old Sep 09, 2014, 07:51 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Single fan or dual?
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Sep 09, 2014, 07:58 PM
Dpetsel is offline
Dpetsel's Avatar
Joined Jun 2012
Right now it's a single Himax HA 2825-3600. Roughly a 28 inch wingspan. I have a couple of Het 2w20's with Wemo's that would really make it cook. I'm not sure if I want to go that big though. I would have to really do some creative designing.
Old Sep 10, 2014, 03:15 PM
builderdude is offline
Find More Posts by builderdude
builderdude's Avatar
United States, TX
Joined Jun 2011
I am subscribed.
But I'm worried it's going to weigh a lot more than a pound and a half.
The EDF in my 38 inch Vampire weighed a pound just by itself.
builderdude is offline Find More Posts by builderdude
Old Sep 10, 2014, 04:22 PM
United States, TX
Joined Jun 2011
By the way, did you post in the BBCC5 thread also, and link it back here?
Please do that if you haven't. I need the link there so that I can make the list of all the entries at the end of this month.
I didn't mention it before because I was on my cell phone typing, but, nice build.
I hope it turns out great. I was just worried because the ESC, the 70 mm fan and motor, and the 3 (preferrably 4) cell lipo combined would wipe out your weight budget of a pound and a half. Not trying to pop your bubble, honest. I just don't want you to fall into the same thing I did with my Vampire. I ended up at about 2 pounds on mine, with a 38" wingspan. The 64 mm fan might be underpowered for the weight it needs to haul. Either I should have gone up with my wingspan or I should have increased the size of my EDF.
Welcome to the contest!
Old Sep 10, 2014, 07:42 PM
Dpetsel is offline
Dpetsel's Avatar
Joined Jun 2012
I do a lot of upgrades for guys that want screamers from their stock airframe. The stock motors from the major hobby shops on the web are usually very underpowered.
The 3 edf's I have to work from my spare parts drawer are:
Sapac MB1 - I had it in a L39 that weighed in at about 4.5 lbs and flew great.
I have an Het 2w20 with 70 mm Wemotec minifan 4 blade that puts out 3.3 lbs of thrust on a 4 cell.
Last one in the drawer is a Himax A 2825-3600. About 2 lbs of thrust on 3 cell.
Those motors give me a wide latitude in airframe weight. The thrust tubes will be toilet paper rolls impregnated with the West System Epoxy. I am drawing everything in CAD and will lighten up all of the fuse formers. I plan on .3 inch carbon arrow shaft as my wing main spar support. I don't think I'll add a rudder servo to save weight. The main thing now, during the design process is to keep all of the electronics positioned to keep my CG in position without adding any ballast.
I did post a shortcut to this thread from the BBCC5 thread.
This should be fun
Dave
Old Sep 10, 2014, 07:58 PM
Dpetsel is offline
Dpetsel's Avatar
Joined Jun 2012
Just weighed all my electronics.
Himax 70 mm edf unit
Turnigy 2200 mah 3 cell
Spectrum 600
Castle ESC
3x 9gram servos
All of this weighed in at 15.6 oz
With the Himax putting out 1 lb 7 oz thrust I can make the airframe (minus electronics) about 22 ounces.
Old Sep 10, 2014, 08:42 PM
United States, TX
Joined Jun 2011
Okay.
I'm anxious to see the results.
For Sale E-Flite F4 Phantom thfirefighter479 Aircraft - Electric - Jets (FS/W) 4 Jan 21, 2014 11:37 PM
Sold Fly Fly f4 phantom rcspeedjunkie Aircraft - Electric - Jets (FS/W) 14 Nov 06, 2013 11:10 PM
Sold Airfield (FMS) 70mm F4 Phantom Camo RTF (San Diego pickup) jared salbato Aircraft - Electric - Jets (FS/W) 2 Oct 14, 2013 10:50 PM
Sold Airfield (FMS) 70mm F4 Phantom Camo RTF (San Diego pickup) jared salbato Aircraft - Electric - Airplanes (FS/W) 2 Oct 11, 2013 09:06 AM
Question e flight f4 phantom duck now Electric Ducted Fan Jet Talk 2 Sep 20, 2013 06:10 PM
