Old Nov 03, 2012, 01:26 PM
Mreyello's Avatar
Deutschland, RP, Niederzissen
Joined Dec 2011
Almost new F5d racer
Hallo,
I would like to introduce my updated F5d -Flipper.
It is based on the "old" Flipper wing, which was slightly modified, but with new fuselage and tail.
Following the progress in accu-technology and drivetrain developement, the fuse is much slimmer and is able to take the new geardrives with up to 12,5" folders.
5S 2200 fits nicely splitted in 2s+3s,even 7S 1800 APL are easy to fit, but fuse frontarea is reduced to 60% of the usual commercial F5d.
As we use the Flipper to support the newbys in F5d and in composit building in germany, it is designed to be easy built, the crosstail requires less laminating experience and gives more accuracy in the elevator linkage, compared to the T-and V-tailed Flipper -versions.
The Flipper will not be sold commercially, but there will be the complete set of rental positive moulds available to open options to get into selflaminating and get your own mould for a small fee.
Even a rental negative mould will be available for those who just want to build one or two planes , but i think this may only make sense for germany and the close neighbors!
Some Datas:
Wingspan:140cm
Lenth :88cm
Wingarea:15,9dm2
Airfoil:HS522 mod Paul Schreiber
Max FAI weight:1024g
Design: Christoph Meier, Paul Schreiber
Dusty and sticky stuff:Ralf Gockel, Marco Fichter
This is an open source projekt, the plug will travel arround germany in the next 2-3 month, maybe it will get much more milage next year so if you are interested just PM me
Regards
Yello
Mreyello is offline Find More Posts by Mreyello
Old Nov 03, 2012, 02:04 PM
arcticflyer's Avatar
Canada, SK, Prince Albert
Joined Jan 2006
I'd like to take a crack at it next year...put me on the list...I'll pay the shipping!
arcticflyer is offline Find More Posts by arcticflyer
Old Nov 03, 2012, 03:14 PM
Mreyello's Avatar
Joined Dec 2011
Some Pics of the positive wing:
Old Nov 03, 2012, 04:56 PM
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Very nice Yello!
Tell me, how does the wing mount work? It looks like the wing bolt holes are spaced wider than the fuselage itself. Or maybe optical illusion?
Peter M is offline Find More Posts by Peter M
Old Nov 04, 2012, 10:37 AM
Mreyello's Avatar
Joined Dec 2011
Arctic,
You are on the list!
Peter, you are right, the wing at the pictures is one of my old ones.
The new will get the bolting holes closer to the center.
There is also a third hole at the trailing edge prepared, we will see if its necessary.
I have flown this configuration with a mogup fuse and its quite promising. The final fuse gets moulded at the moment.
Yello
Old Nov 16, 2012, 03:45 PM
Mreyello's Avatar
Joined Dec 2011
Ok,
The complete positive set is ready, tomorow we will take the first mould.
Yello
Old Nov 16, 2012, 03:58 PM
Joined Aug 2009
Yello,
When it makes it over to Arctic I'd like a shot at it as well. I'm in the states.
Terry
Chuchuf is online now Find More Posts by Chuchuf
Old Nov 16, 2012, 05:46 PM
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Originally Posted by Chuchuf View Post
Yello,
Terry
You have to take a ride to Germany if you want some of this action....I would kill to go spend the time and learn from Yello,no less bring home a plane i made .Amazing work Yello,i would probably trade a limb for your skill set
VooDoo Child is offline Find More Posts by VooDoo Child
Old Nov 16, 2012, 05:49 PM
Joined Aug 2010
Yello,
Terry
Maybe if we pool our money,we can talk Yello into sending it this way....You are only a couple hours from me
Old Nov 16, 2012, 05:52 PM
Livin it UP when Im goin DOWN
Arcteryxxx's Avatar
Norway, Telemark, Skien
Joined Feb 2010
Originally Posted by Mreyello View Post
Ok,
Yello
Glad to be on that list
Looks really nice!
Arcteryxxx is offline Find More Posts by Arcteryxxx
Old Nov 17, 2012, 03:23 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
amazing work..
sebbe is offline Find More Posts by sebbe
Old Nov 17, 2012, 05:17 PM
Joined Aug 2009
If it's going all the way to Canada then it SURELY should go through Atlanta on it's way back to Europe.
Come up when it gets here VooDoo and you and I and a friend of mine can hav a laying up get together.
Terry
Old Nov 26, 2012, 04:16 PM
Mreyello's Avatar
Joined Dec 2011
Some news...
First fuselage is ready.
Some of you may not like it cause its slim and light
Single fuse with motormount is 48 g (1,7oz)
Complete tail is 16g( 0,56 oz)
Fuse with tail, servo and linkage is 82g(2,9 oz)
But prototype is able to take 8S 1200 Gens Ace with a Lehner 1535 and Reisenauer Micro Edition.
I will play with the combination of GB ratios 3,5:1 ,4:1, 4,5:1 and 5:1 and Lehner 1535/9 and 1535/ 11 to find the best setup for 5- 8cells.
Drivecalc promises freakin Eta numbers at up to 2,5 kw static!
All over weight is calculated to 900g at 8S ;maybe i will build a 4 flap wing which would add about 35g.
Wing still has to wait until i finished the builders -workshop next week.
Some pics:
Old Nov 26, 2012, 05:28 PM
Arcteryxxx's Avatar
Joined Feb 2010
8S and 900g at 2500W!
Very nice
Old Nov 26, 2012, 09:44 PM
Joined Aug 2010
I like the naked fuz for sure,Frickin Sweeeeeet ! not to mention the prop and spinner
For Sale f5D El Nino Pylon Racer kipp geisler Aircraft - Sailplanes (FS/W) 4 Oct 30, 2012 12:03 AM
For Sale F5D El Nino Pylon Racer kipp geisler Aircraft - Electric - Airplanes (FS/W) 0 Oct 12, 2012 10:24 PM
For Sale F5D Pylon Racer kipp geisler Aircraft - Electric - Airplanes (FS/W) 0 Oct 07, 2012 11:17 PM
For Sale F5D El Nino Pylon Racer kipp geisler Aircraft - Sailplanes (FS/W) 0 Oct 07, 2012 09:55 PM
Sold Viper F5D Pylon Racer marknopfler Aircraft - Electric - Airplanes (FS/W) 3 Jul 02, 2012 03:55 AM
