Old Aug 20, 2013, 02:33 PM
Verrak is offline
Find More Posts by Verrak
Joined Jul 2013
Help!
Wich ESC do i need?!
I have bought the HK Combat & Sloap Soaring Wing and a motor and all the other bits i need.
i have bought the Turnigy L2210-1230 and a plush 18Amp ESC.
i wanted to put a master airscrew 8,5x6 on this and fly it around at moderate speeds as im still learning and dont want to wreck one of only two flying models.
now to the battery. I have a 2200mah 3S and a 1300mah 2S. Wich of these will work with the 18Amp plush? I do have a 30Amp plush as well if that is needed.
will my motor handle that prop on 2S or do i need to put in the 3S and bigger ESC?
Verrak is offline Find More Posts by Verrak
Old Aug 20, 2013, 02:48 PM
Daz393 is offline
Find More Posts by Daz393
Depron Daz
Daz393's Avatar
United Kingdom, England, Basingstoke
Joined Feb 2012
18a and 2s with that prop should be fine. I use a 15a and an 8x3 on 2s and the esc stays cool. 3s may cause it to get warm/hot so be careful.
Daz393 is offline Find More Posts by Daz393
Old Aug 20, 2013, 02:56 PM
Verrak is offline
Joined Jul 2013
Then i wasnt a totalt idiot after all. Thanks!
Old Aug 20, 2013, 05:25 PM
Daz393 is offline
Depron Daz
Daz393's Avatar
Joined Feb 2012
Best bet Verrak, is to get yourself a watt meter. It saves all that guess work and burnt out items! Best 20 I've ever spent on RC gear.
Old Aug 21, 2013, 11:05 AM
Verrak is offline
Joined Jul 2013
Im not too concerned with this setup as i have noticed after some digging on the interwebs found out that it seems to be quite common.
Mini-HowTo Battery of the TX died, need to replace, but for wich one?? joaomangolini Batteries and Chargers 6 Aug 06, 2013 03:54 AM
Discussion need help with choosing wich esc to match a simon k rc timer pls help quadcopterguy Multirotor Electronics 2 Jun 09, 2013 09:11 PM
Question I need to know wich would i be better off doing when buying the PZextra300 BNF or PNP skarface Parkflyers 1 Sep 25, 2011 06:27 AM
Question foamy glassing atemt ; wich R&G epoxy do i need? cmulder Composites Fabrication 18 Oct 13, 2009 07:48 AM
Discussion Wich Li-po do I need planedude Electric Plane Talk 16 Jun 19, 2008 12:03 AM
