Old Feb 23, 2015, 08:08 PM
New Zealand, Wellington, Lower Hutt
Joined Sep 2011
Looks like the same one
http://hobbyking.com/hobbyking/store...eller_9x6.html
DaveTheKiwi is offline Find More Posts by DaveTheKiwi
Old Feb 23, 2015, 09:04 PM
What place .... is this ???
Australia, SA, Adelaide
Joined Oct 2011
See the stopped prop on the back of the SW, on post #18843, It's a Master Airscrew G/F 3 series9 x 6, which is a tad wider, but very similar in performance. Check the balance on arrival, most are ok, but some will need to look at a little sandpaper. I have a counter rotating APC, just too lazy to change it I guess ...
Heppy Ket is online now Find More Posts by Heppy Ket
Old Feb 24, 2015, 03:17 AM
Joined Sep 2011
So how do you find the MA vs the APC? Or was that vid not yours?
Old Feb 24, 2015, 04:31 AM
Joined Oct 2011
The video is mine I have used two MA's and one Turnigy Beech (which seemed quieter) and not yet used the APC, it is counter rotating so I have to break the loc-tite seal and reverse the motor, like I said, I am lazy Lol.
I am happy enough with the Master Airscrew prop so if it ain't broke ...
Here's a Flight Camera recording of a recent flight with the OSD, and the amp draw is pretty low at cruise, which suggests to me that the prop is doing it's job.
Flight Camera, Outer Harbour (21 min 9 sec)
Old Feb 24, 2015, 08:36 AM
Exodus 4:13
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
what loctite seal do you need to break, to reverse the motor?
Is it not possible for you to swap two of the three wires from ESC -> Motor?
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Feb 24, 2015, 02:20 PM
Joined Oct 2011
The APC is a counter rotating prop, yes you will need to reverse the motor wires to use it. The Loctite seal is on the prop nut and is not that hard to break, but it all works so why? If you look at the prop from the tail, then the standard prop will rotate clockwise, it will tend to loosen the prop nut. A counter rotating prop will rotate counter clockwise so it tends to tighten the prop nut.
The result of loose nuts can be seen here in Octane81's video adventure
Skywalker FPV Didn't make it home (4 min 55 sec)
Joined Sep 2011
Thanks Ket! I'll give it a go next week some time. I don't trust my current prop balancer as far as I can throw it, so may wait until I replace that.
@bhoov128, I'll stand corrected here. Sounds like Ket is using it on his prop nut.
Old Feb 26, 2015, 02:00 PM
Joined Dec 2008
I'm looking at getting a new 2015 version Skywalker or a revolution. I had a 2014 1700mm last year. Anyone who has flown both t tail and conventional, can you comment on the difference? I found mine dove really hard under full power and hated that so much I never enjoyed it. Is the t tail any better?
Forced_Inducti is offline Find More Posts by Forced_Inducti
Old Mar 11, 2015, 11:41 PM
Joined Oct 2011
A classic calm Autumn morning this morning, just the thing for an early morning cruise around the waters of Torrens Island.
https://www.youtube.com/watch?v=c7mbm9zJhj4
Old Mar 12, 2015, 11:42 AM
Birchleigh, South Africa
Joined Apr 2007
Beautiful, Ted!
hethjo is offline Find More Posts by hethjo
Old Mar 12, 2015, 03:04 PM
Joined Oct 2011
Thanks, it was one of those one in a million days
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
