Old Jan 29, 2016, 11:28 PM
AirDOGGe is online now
Find More Posts by AirDOGGe
Just Plane Nutts
AirDOGGe's Avatar
United States, CA, Mountain View
Joined Dec 2011
Outrunner comparison
I'm looking for a more powerful outrunner to try than my current Sapac 3200KV unit. My current knowledge of brushless motors is still limited...
I ran across another motor of similar diameter that is just a bit shorter in length, but higher in rated wattage. I wonder if it would be a better choice? I seek experienced opinions, please.
http://www.savoxusa.com/Savox_BSM294...m2940m3500.htm
The Savox's wire-wound core is 5mm shorter and the overall motor 39 grams lighter than the one I already have, but is rated 120-watts higher continuous power. It's wound with thicker wire too. Do you think the Savox would be more powerful motor despite the slightly shorter length? Here's some specs for comparison:
Current motor in use:
Sapac 2842-3200KV Ducted Fan Outrunner (link)
Size: Φ28.5 x 68mm
Max lock-rotor current: 75A
Shaft diameter: Φ4mm
None-load current: 2.8A ±0.2A
Weight: 110g
Resistance(mΩ): 15.0
Maximum Continuous Power: : 417W
KV: 3200
Battery: 3S
Savox BSM-2940 3500KV Outrunner Motor (link)
Size: 29mm x 40mm
Rated Voltage: 11.1 Volts
Voltage Range: 2-4s LiPo
No-load Current: 2.7 Amps
Maximum Continuous Power: 538 Watts
Maximum Continuous Current: 51 Amps
Terminal Resistance: 0.019 Ohms
Motor kV (no load): 3500kV
Pole: 10 Pole
Slot: 12 N
Weight: 71g
NOTE that a good deal of that extra physical length of the Sapac is due to the design of it's rotating can. The wire-wound cores are only 5mm difference in length.
AirDOGGe is online now Find More Posts by AirDOGGe
Wanted HSC 380 Outrunner With Integrated HubHSC 380 Outrunner With Integrated Hub Joe Pierson Aircraft - Electric - Power Systems (FS/W) 2 Dec 15, 2015 12:43 PM
Discussion Outrunners “2814 / 3014 stator class” comparison Fourdan Power Systems 16 Apr 05, 2009 03:57 AM
Discussion Comparison Hacker/Eflite Outrunners Ralph A. D'Amelio Power Systems 0 Feb 08, 2006 12:03 PM
Discussion Outrunner Double prop/ wind comparisons Nigelp Power Systems 18 Jan 16, 2006 03:22 PM
Hobby Lobbys Sub Oz. Outrunner comparison sloper steve Power Systems 30 Jan 31, 2005 03:13 PM
