Old Jul 14, 2015, 07:06 PM
Gerry Santos is offline
Find More Posts by Gerry Santos
Manila, Philippines
Joined Jul 2001
gram thrust/oz thrust to watts
Is there a conversion table available to determine static thrust - grams/oz. to watts?
Purchased this 50mm fan which claims 580g static thrust and wondering what is the equivalent in watts?
http://www.x-flight.com.hk/index.php...&more=&lang=en
Thanks.
Gerry Santos is offline Find More Posts by Gerry Santos
Old Jul 15, 2015, 02:04 AM View Post
HSD Team
A moderator felt this post violated the following rule: Excessive Advertising (Spam). It is temporarily hidden while HSD Team edits it. Show it to me anyway.
Old Jul 15, 2015, 02:09 AM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
How many cells are you running? Check your amp current draw.
jofro is offline Find More Posts by jofro
Old Jul 15, 2015, 08:55 AM
Manila, Philippines
Joined Jul 2001
As per recommendation by xflight.com, just a 2200 mah 3s lipo pack.
Old Jul 15, 2015, 10:29 AM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hello Gerry
There is no chart or graph that would apply as all fans do not have the same performance. If some one like the manufacturer has done a chart for that exact fan maybe but that would be it. You can gather info from others and build a data base but unfortunately no 2 people test in the exact same manner so each set of data will not match.
Old Jul 15, 2015, 01:36 PM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
This graph done by Klaus Scharnhorst back in 2006 will get you close.
Klaus was RCG's "winmodels" back then and if you do a search you will find quite a lot of info on EDF design and performance theory.
Just convert Newtons to grams or lbs......
- Mike
Mike Warren is offline Find More Posts by Mike Warren
Old Jul 15, 2015, 05:08 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
I wish we had more of guys like Klaus..He always had good info..And still pretty close to what we see in use today
Old Jul 15, 2015, 06:49 PM
jofro is offline
Joined Jan 2010
Check your amp current and multiply it by your voltage, with above stock set up you get more likely 360Watts figure.
Old Jul 15, 2015, 07:24 PM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
- Mike
1000 watts for 23 N in 70mm.
I think around 1500 watts in.
manuel v is offline Find More Posts by manuel v
Old Jul 15, 2015, 09:23 PM
BOHICA!
Joined Dec 2010
Remember: the noted diameter is NOT fan diameter.....it is tail pipe exit diameter.
So the 1000watts/23N/70mm equates to FSA for maybe an 80mm EDF.
Static thrust from an 80mm at 100% FSA would be really close to 23N no?
- Mike
Old Jul 15, 2015, 10:21 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Mike.Thank you very much,
And it seemed to me very high.
Cool 6,300 grams of thrust on a quad?! ---- (YES PLEASE!!) Catalystmachine FPV Racing 10 Jul 07, 2015 11:48 AM
Discussion Watts to Grams of Thrust? Flexserve Electric Ducted Fan Jet Talk 7 Apr 12, 2010 06:14 AM
Discussion Watts of Power to Grams of thrust Flexserve Beginner Training Area (Aircraft-Electric) 3 Apr 11, 2010 01:48 AM
18 gram Brushless CDR with 10+ oz of thrust jskrebs Product Announcements 7 Mar 30, 2005 06:41 PM
18 gram Brushless CDR with 10+ oz of thrust jskrebs Power Systems 4 Mar 20, 2005 07:39 PM
