Old Sep 04, 2014, 12:10 PM
sureshot__ is offline
Find More Posts by sureshot__
sureshot__'s Avatar
United States, TN, Cleveland
Joined Oct 2013
Cheap $41 5.8Mhz - Got it to work
First, the lame directions were wrong.
The printed DIP switch settings were different between the TX & RX.
After some testing, I just set them to the same up/down positions on both the RX & TX.
Not bad for $41.
I'm using an old Aiptek DVR, that has an AV in, as a ground viewer.
The feed is the 480p live out from a Mobius cam as it records in 1080p.
sureshot__ is offline Find More Posts by sureshot__
Old Sep 04, 2014, 03:18 PM
Dimitris76 is offline
Find More Posts by Dimitris76
United States, IN, Carmel
no you didn't... post video or it didn't happen
Dimitris76 is offline Find More Posts by Dimitris76
Old Sep 04, 2014, 04:03 PM
sv1eia is offline
Find More Posts by sv1eia
Greece, Attica, Athens
Joined May 2014
lol. +1
sv1eia is offline Find More Posts by sv1eia
Old Sep 04, 2014, 05:26 PM
sureshot__'s Avatar
Joined Oct 2013
Video Coming soon.
On the test flight, the stock 2db antennas dropped signal at about 100 yards.
Of course I need better antennas.
I'm currently working on getting more tilt clearance with the gimbal.
The Mobius USB fan-out sticks too far out the back, so I'm fabricating an angle plug.
Old Sep 04, 2014, 08:38 PM
sureshot__'s Avatar
Joined Oct 2013
Quick video of my cheap FPV setup
Here is the quick video:
Cheap FPV setup - Mobius to Aiptek (0 min 20 sec)
Old Sep 05, 2014, 09:12 PM
sureshot__'s Avatar
Joined Oct 2013
I was still a bit off on the TX frequency.
After some more experimenting, it now goes well over 200 yards.
So far the best combination seems to be CH6 on the TX with CH8 on the RX.
Old Sep 28, 2014, 09:49 PM
sureshot__'s Avatar
Joined Oct 2013
Well, the 3" screen was not practical, so I'm now using a 7" TV mounted on a tripod.
Here is a test session:
16 The Lodge at Westmore aerial views (5 min 42 sec)
Old Oct 12, 2014, 08:36 AM
sureshot__'s Avatar
Joined Oct 2013
CX-20 -solid video platform -FPV
A pro photographer once told me: "Shoot a lot and just keep the good ones."
The fall colors are not really showing yet.
So, it’s time I started working on making better looking aerial videos.
This time I cut out some of the boring parts.
A big tree at the north edge of the driveway blocks my line of sight in that direction.
When I flew north I had to rely on the first person view screen for control.
I put a peek at the FPV screen at the beginning.
Anyway, I hope you enjoy the view.
(It’s 1080p, so it shows best full screen.)
https://www.youtube.com/edit?o=U&video_id=grc5AOVRetM
Old Oct 19, 2014, 09:11 PM
sureshot__'s Avatar
Joined Oct 2013
Accidental control signal loss RTL.
This flight video was mostly controlled using the FPV screen.
After turning back I had by back to the CX-20.
I had accidentally lined up myself, my truck, and a big tree blocking the control signal.
That triggered the lost signal RTL.
The FPV was still good, but when the quad turned away and the gimbal tilted back, I knew I had lost control.
The arming & take off zone was under that big tree, so when it came overhead and started to descend, I toggled the GPS SWA off/on to regain control.
I had tested the in-flight signal loss RTL and manual re-bind to the controller on the bench, but this was the first time for real.
One continuous shot, no edits.
Post-processing was done to fix barrel distortion and clip the start & end.
I hope you enjoy it.
Fall sunrise Oct 19 2014 (6 min 39 sec)
Old Oct 21, 2014, 03:26 AM
Very nice. You didn't loose your nerve when RTL kicked in and managed to save it. I wouldn't dare to fly over those trees.
Which Mobius gimbal and controller?
/Dimitris
Old Oct 21, 2014, 09:22 AM
sureshot__'s Avatar
Joined Oct 2013
/Dimitris
It was exciting!
Camera: Mobius with the normal lens A
Gimbal: Low cost GoPro style modified for the smaller & lighter Mobius
TX: Stock CX-20 radio
The Video is post-processed with "ProDRENALIN" to straighten barrel distortion
Old Nov 03, 2014, 11:02 PM
sureshot__'s Avatar
Joined Oct 2013
Lesson learned - Don't switch between LOS & FPV during takeoff.
JAWS, the great white pine tree got me.
FPV crash (2 min 47 sec)
It's all repaired, but I now fly carefully around JAWS.
Fall Morning & Afternoon Colors in Tennessee (7 min 58 sec)
Old Mar 27, 2015, 03:57 PM
sureshot__'s Avatar
Joined Oct 2013
To find a lost drone.
First, a directional antenna for the ground station.
If GPS fails, and you loose LOS before you get manual control, you can use the ground station as a radio direction finder.
Discussion Aomway 1000mw 5.8mhz vtx problems negy1 FPV Equipment 7 May 20, 2014 12:17 AM
Found Wanted :FPV TX and RX(900mhz, 5.8mhz, or 1.3mhz) kirtdog FPV Equipment (FS/W) 12 Feb 13, 2014 04:55 PM
New Product dirt cheap 5.8ghz ebay helical got me to 2 miles today rudyauction509 FPV Equipment 9 Jan 05, 2014 01:48 PM
For Sale CooperUAV "X-Range" 5.8mhz Ground Stations!! 1 mile guaranteed range!!! macentyre Aircraft - Electric - Multirotor (FS/W) 0 Oct 18, 2013 10:48 PM
For Sale CooperUAV "X-Range" 5.8mhz Ground Stations!! 1 mile guaranteed range!!! macentyre FPV Equipment (FS/W) 0 Oct 07, 2013 05:08 PM
