Old Aug 13, 2015, 05:06 PM
anewton is offline
Find More Posts by anewton
Whoa……it flies
anewton's Avatar
Australia, VIC, Geelong
Joined Feb 2007
Excellent. Glad you like the detachable boom.
anewton is offline Find More Posts by anewton
Old Aug 14, 2015, 08:34 AM
leadfeather is online now
Find More Posts by leadfeather
Winging it Ò>
leadfeather's Avatar
Joined May 2006
On my next trip to California I'm going to try this whip stick idea with my Fusion. Should be able to get to thermal heights...maybe?
Whip Stick glider launcher (1 min 52 sec)
leadfeather is online now Find More Posts by leadfeather
Old Aug 14, 2015, 06:46 PM
anewton is offline
Whoa……it flies
anewton's Avatar
Joined Feb 2007
Speaking of thermals. My fusion went way higher a few times while the wind dropped off at this less than ideal slope.
Very interesting, thermals even on a cold overcast day.
Fusion glider catching slope and thermal lift (1 min 53 sec)
Old Aug 14, 2015, 09:41 PM
Diceman89 is online now
Find More Posts by Diceman89
Ultrabatics enthusiast
Diceman89's Avatar
United States, CA, San Jose
Joined Aug 2012
What wing chord and thickness you guys using? Thanks. Want to make mine a 50" wing span
Diceman89 is online now Find More Posts by Diceman89
Old Aug 15, 2015, 07:02 AM
Winging it Ò>
Joined May 2006
Nice Andrew!
Does you stab go full 90 up for the multi-flips? With that kind of altitude you could easily capture the southern hemisphere multi-flipping record.
Old Aug 15, 2015, 07:14 AM
Winging it Ò>
Joined May 2006
Dice,
Are you planning a clipped wing build or a scaled down build?
Dan
Old Aug 15, 2015, 10:13 AM
Diceman89's Avatar
Joined Aug 2012
I am making mine to similar dimensions of a Coquillaj from Aeromod. So scale down a bit.
Old Aug 15, 2015, 04:19 PM
anewton is offline
Whoa……it flies
anewton's Avatar
Joined Feb 2007
Mine is 180mm root 140mm tip RG15 about 16mm max thickness.
Originally Posted by leadfeather View Post
Nice Andrew!
Yes 90º up but I have not achieved multi flips yet. One flip then radical stall yes, but sustained rotations no. Will keep trying.
Old Aug 15, 2015, 04:36 PM
dawsonh is online now
Find More Posts by dawsonh
Flagstaff, AZ
dawsonh's Avatar
USA, AZ, Flagstaff
Joined Mar 2003
If you have 90 degrees up, then all you need to do is work the CG back and multi-flips will become automatic.
Dawson
dawsonh is online now Find More Posts by dawsonh
Old Aug 16, 2015, 01:51 AM
anewton is offline
Whoa……it flies
anewton's Avatar
Joined Feb 2007
Thanks Dawson. Just as soon as I glue it back together (after the last multi flip attempt) I'll play with the CG.
Old Aug 16, 2015, 03:22 PM
RNAF is offline
Find More Posts by RNAF
Κάτω Χώρες
RNAF's Avatar
The Netherlands
Joined Dec 2003
Hi guys,
I got the "slope fever" after buying the Alula Trek. Browsing the slope forum I found this great thread and became really enthusiastic about the model. With given information and the plans I drew up a model in CAD. Thinking about a slightly different pod.
Just need to build a larger wire cutter to make the wings..
RNAF is offline Find More Posts by RNAF
Old Aug 16, 2015, 07:04 PM
Winging it Ò>
Joined May 2006
Dawson
+1 ... Same formula for planes, wings and planks to multiflip. Cg back to where you need some expo to fly smoothly in pitch ,and also full 90 on the elevons/stab.
Old Aug 16, 2015, 07:05 PM
Winging it Ò>
Joined May 2006
Originally Posted by RNAF View Post
Hi guys,
Nice drawing. What materials are you thinking of building the pod from. Looks like a nice and clean design. Best of luck.
Old Aug 17, 2015, 01:43 PM
RNAF is offline
Κάτω Χώρες
RNAF's Avatar
The Netherlands
Joined Dec 2003
Hi Leadfeather,
I'm thinking of sanding it from a block of foam, then glass it. Maybe make a mold for later use. It would be a first try.
The design is completely from your plans, just the pod is different
Build Log E-Supra for ALES - How many mistakes can you make in the build and still succeed? MrE Composites Fabrication 335 Jun 21, 2015 11:38 PM
Question Building ultra-light plane from scratch: help me decide what components UWME Foamies (Scratchbuilt) 17 Nov 19, 2013 09:49 AM
36" wings that are aerobatic and fly in light lift Web Slope 60 Jun 25, 2004 12:12 AM
I want to scratch build an aerobatic RFFS plane - What's the secret? flytowner Scratchbuilt Indoor and Micro Models 114 Jul 06, 2003 07:39 PM
Light lift scratch-built tenover Slope 7 Sep 11, 2002 09:06 PM
