Old Jan 23, 2013, 05:59 AM
kerdon is offline
Find More Posts by kerdon
Joined Aug 2008
Goldberg Eagle2 to Electric
Hi all,
I have a eagle2 that I used to run Nitro on, and I now have a couple trex500 heli's. I am looking to retrofit an ESC and Motor into the eagle to, so that I can use my 6s batteries from my Trex on the Eagle2.
What parts and items do I need?
kerdon is offline Find More Posts by kerdon
Old Jan 23, 2013, 08:16 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
A search would be useful as there have been several threads that speak to the CG Eagle 2.
Here's an older article; that in the last few postings of the discussion speaks to LiPo & Outrunners: http://www.rcgroups.com/links/index.php?id=4485 .
Are you packs 6S or do you get 6 from two 3Ss in series?
Off pavement the CGE2 could actually fly on 3S!
If off 6S then a much lower Kv is needed at the prop for a 10 to 13" prop -- bigger outrunner or gearbox.
Otherwise the choice is going to a little fast spinning prop.
jrb is offline Find More Posts by jrb
Old Jan 23, 2013, 11:41 AM
pdansalvish is offline
Find More Posts by pdansalvish
Lusby, MD 20657
Joined Mar 2001
If my memory is correct, the Eagle 2 called for a 25-46 motor. I have one NIB and plan on using a Power 25 or Power 32 running 3-4 cells.
pdansalvish is offline Find More Posts by pdansalvish
Old Jan 23, 2013, 12:09 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
http://www.carlgoldbergproducts.com/.../gpma0955.html : 2-stroke .29-.45 .
The issue is what packs/cell count -- then a motor can be found.
As a trainer nothing would be better than A123-6S and a 550Kv motor w/12x10 APCE!
Old Jan 23, 2013, 12:37 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
This gearbox ( http://www3.towerhobbies.com/cgi-bin...?&I=LXMLK0&P=0 ) and motor ( http://www3.towerhobbies.com/cgi-bin...5325&search=Go ) could be used w/6S -- and a mount similar to what I did on the Eagle would make for a nice installation.
Old Jan 23, 2013, 07:15 PM
olds455 is offline
Find More Posts by olds455
USA, AK, Anchorage
Joined Nov 2005
Mine runs on 3s w400watts and will almost hover. Can fly 10+ min on my 2650 packs
That's with a turnigy 3542-1100 using a 10x7 apc-e. mine weighs under 4lbs
olds455 is offline Find More Posts by olds455
Old Jan 23, 2013, 07:54 PM
Lusby, MD 20657
Joined Mar 2001
Olds, what motor are using? I have E-flight Power 25 on a Seņorita. I found the motor on 3 cells pulls it right along.
Old Jan 26, 2013, 05:53 PM
mt_100 is offline
Find More Posts by mt_100
I have no friends
United States, MI, Holland
Joined Dec 1996
The Eflite 25 is a 3548 870kv so a 3542 1100Kv would also do great on 3S. The slightly higher Kv would allow a slightly smaller prop for ground clearance.
So my opinion, go for it with the 3542 1100Kv and play with the prop a little.
mt_100 is offline Find More Posts by mt_100
Sold Goldberg Eagle2 with KB.45 and servo's LPU wing881 Aircraft - Fuel - Airplanes (FS/W) 0 Oct 09, 2012 08:50 PM
Sold Eagle2 Wing kit $30 Bismarck007 Aircraft - Fuel - Airplanes (FS/W) 2 Aug 23, 2012 09:43 AM
Video The Eagle2 boys Webmaster-F Fuel Plane Talk 0 Oct 30, 2011 11:50 AM
eagle2 brushed? ccchris Sport Planes 4 Apr 28, 2005 10:42 AM
Hirobo SST-Eagle2-GS (For Sale) pblgml Aircraft - Fuel - Helis (FS/W) 0 Aug 11, 2004 09:37 AM
