Old Jul 18, 2015, 12:36 PM
tenbuc is offline
Find More Posts by tenbuc
tenbuc's Avatar
Joined Jan 2015
Diode on the super 370
What would happen if the positive and negative diodes were remove from
The HB SUPER 370? I've often wondered about the purpose since the
Standard stock Motor do not have them.
Edit: not diode but capacitor??
Can someone enlighten me why they are used on these motors? ☺☺
tenbuc is offline Find More Posts by tenbuc
Old Jul 18, 2015, 04:21 PM
Ratita77 is offline
Find More Posts by Ratita77
Joined Feb 2014
Originally Posted by rchrist View Post
Ratita, without knowing the direction of the spin, I'll guess that the tail motor is spinning in the wrong direction meaning the wires to the pcb or motor will need to be reverse. Check the rotation of the tail blade, it should be spinning counter-clockwise. If that is not the problem, then there are more things to check. Once we know the spin direction, it will be easier to troubleshoot.
Ric...
Thanks Ric.
I will check this way 1st.
That was my 1st idea too
Ratita77 is offline Find More Posts by Ratita77
Old Jul 23, 2015, 11:56 PM
shonmac is online now
Find More Posts by shonmac
shonmac's Avatar
United States, NJ, Dunellen
Joined Aug 2014
My connect buckles to the servos refuse to stay on. They just pop right off after starting to fly. I bought a new pair and they wont stay on either
shonmac is online now Find More Posts by shonmac
Old Jul 24, 2015, 07:12 AM
JohnFM is online now
Find More Posts by JohnFM
United States, WY
Joined Oct 2014
913 links are meant to snap on from one side only. Look closely and you will see a slight indentation/ring on the attaching side.
If they've become loose take a good flat ended pin punch sized to very slightly overlap that ring (that's a punch with out the tip burred up from use).
Give a very light tap with a small hammer to slightly dent the plastic. It takes only a tiny amount, too much and it'll get too tight.
JohnFM is online now Find More Posts by JohnFM
Old Jul 24, 2015, 06:52 PM
shonmac's Avatar
Joined Aug 2014
Ok . And I imagine if it gets too tight they wont travel properly.
Thanks for the tips.
Discussion WL Toys V911 Short Motor Life?? Brushless Conversion ? scharlach Micro Helis 16 Apr 12, 2014 04:09 AM
New Product $40 MQX / Ladybird by WL Toys (Turnigy Compatible) zadaw Multirotor Talk 19 Jun 27, 2012 04:20 PM
For Sale WL TOYS 3.5-Channel iPhone/ iPad/ iPod / iTouch RC Helicopter with 0.3 MP Camera! Santoyo Aircraft - Electric - Airplanes (FS/W) 3 Jun 13, 2012 11:36 AM
New Product Swift WL Toys S929 - Micro Helicopter with Turbo control Hawai Coaxial Helicopters 39 Mar 08, 2012 05:57 PM
