Old Feb 07, 2011, 03:14 PM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Question
I tried searching, I promise... max voltage for LiFePO4 pack?
I swear I tried searching the forum first and I couldn't really come up with a definitive answer. So, here goes the question that's probably been answered 1,000 times:
Situation: I am an all-electric flier with a large range of airplanes. Everything I own flies off a BEC of some sort, with the exception of two planes... my Morris Hobbies "Big Boy" (80" WS, 7 standard analog servos) and my GP Ultimate Biplane (65" wing, 7 high-torque/analog servos). Both of these have NiMH receiver packs; one is a 4-cell pack and the other is a 5-cell pack. My Futaba 9C transmitter has an 8-cell 1900 NiMH pack as well.
Problem: My beloved and trusty Ace Super DigiPulse charger is dying... I had two of them, and one died last year. Procured another one in a trade and this one is experiencing problems as well (the display is non-operational; only have LED lights that indicate charging.... if it loses power, there's no way to reprogram the charge rates without the display). It's just a matter of time before it dies completely, leaving me no convenient way to charge these two planes as well as my transmitter. I thought this would be a good time to switch my remaining items over to LiFePO4 batterties, rather than try to buy yet another DigiPulse. LiFePO4 packs do not require a voltage regulator, and I have the infrastructure to charge them properly.
Question: What is the max output of LiFePO4 cells? I know that LiPo cells are 3.7V/cell nominal and 4.2V/cell full charged, and LiFePO4 cells are 3.3V/cell nominal... I do not know the voltage of a fully-charged LiFePO4 cell so I want to know this to make sure I don't fry my transmitter, 2.4 FASST receivers, or servos.
Thanks!
Mike_Then is offline Find More Posts by Mike_Then
Old Feb 07, 2011, 03:18 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
3.6
rampman is offline Find More Posts by rampman
Old Feb 07, 2011, 06:02 PM
Mike_Then's Avatar
Joined Apr 2001
Thank you, Rampman. So a fully-charged 2-cell LifePO4 pack would be 7.2 volts. How does that compare to a fully-charged 5-cell NiMH pack? They are close, I assume, which is why it can be used with regular servos and receivers?
Old Feb 07, 2011, 06:11 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Depending on the specific brand of LiFePO4, 7.2 volts would be the maximum that you should see when you 'plug it in'. My A123 cells typically 'settle' to ~3.45 volts a few hours after charging. A 2S pack would be about 6.9-7.0 volts. NiMH cells are typically ~1.45 volts after charging. 1.45 x 5 = 7.25 volts.
Bottom line - If a 5 cell NiMH pack works for you, you'll have no issue with a 2S LiFePO4 pack.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Feb 07, 2011, 06:14 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
http://www.rcgroups.com/forums/showt...light=receiver
Old Feb 07, 2011, 07:34 PM
ledgehunter is offline
Find More Posts by ledgehunter
USA, MI, Grand Ledge
Joined May 2006
Thanks for asking the question Mike, I have been looking for simliar info lately as well. I have similiar set ups and have been considering going the LiFe route but in my planes I have digital servos. It seems I read somehwere that the LiFe and digital may not work well together. Does anyone have any comments to that?
These just seem so much nicer than the BEC route. I just don't understand taking a 6S and converting it to a 6V for the rx....
ledgehunter is offline Find More Posts by ledgehunter
Old Feb 07, 2011, 08:07 PM
Southern Pride
Perhaps use the link I posted and read post #1,26,27 and 29 at mininum.
Charles
Old Feb 07, 2011, 08:18 PM
Mike_Then's Avatar
Joined Apr 2001
Thanks for the replies, everyone. I'll go ahead and order a Hyperion LiFePO4 pack or two.
Old Feb 07, 2011, 09:18 PM
TheTick is offline
Find More Posts by TheTick
Spoooooon!
TheTick's Avatar
San Fernando Valley, California, United States
Joined May 2003
What is the benefit over a123?
TheTick is offline Find More Posts by TheTick
Old Feb 07, 2011, 09:54 PM
Munch is offline
Find More Posts by Munch
El Cajon, CA, USA
Joined Feb 2001
It's funny you guys ask this question. I read a ton about LiFeP04 and then decided to go with them. I"m running them on two helicopters and love the setup. I've occasionally forgot some of the data regarding these cells and have had horrible times finding it again.
Charles' thread is very helpful but occasionally I feel stupid reading them. He's providing a ton of information but like any good teacher he leads you to your own conclusion rather than telling you his opinion. Does make it more of a challenge though sometimes when I read it and then reread it and still am not sure what it all means.
My 2 cell LiFe's come off the charger at 7.2 volts but they then quickly settle (5-10 minutes I guess...haven't timed it) down to 6.7 or so volts where they will basically stay for a long long time (even under load).
The thing you need to be careful of is that the power curve is super dooper flat. They hardly drop at all so it's very difficult to estimate how many mAh is left in them. I just peak them every night or right before I fly. I bring 3-4 batteries to the field every day and so far my flights are pulling 100-120 mAh out per flight. I'm running a 1400 mAh pack so I figure I can fly 4-5 before I'm even at half a pack. Been working like a charm so far.
Fingers crossed it stays that way.
I do have a quick question that I swear I've read but have had trouble finding again.
It's No problem storing fully charged right? It's not going to shorten their lifespan like Lipo's.....right?
Munch is offline Find More Posts by Munch
Old Feb 07, 2011, 10:16 PM
Mike_Then's Avatar
Joined Apr 2001
That shouldn't be a problem for me as these are flight packs, and I always charge them the night before flying. Now I don't have to kick myself if I forget to charge them as they can quickly be topped off at the field.
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Unlike a lipo, storing at full charge is OK.
Rick
Last edited by rampman; Feb 07, 2011 at 10:17 PM. Reason: Mike, you beat my by a few seconds. ;)
Old Feb 07, 2011, 10:45 PM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
Rick
Thats a bonus!
lipoflyer is offline Find More Posts by lipoflyer
Old Jan 13, 2015, 10:59 AM
glassdogangle is offline
Find More Posts by glassdogangle
Fatalities caused by FPV: Zero
glassdogangle's Avatar
United States, OR, Springfield
Joined Jun 2011
I just bought a ZIPPY Flightmax 8400mAh 4S2P 30C LiFePo4 Pack
http://www.hobbyking.com/hobbyking/s...dProduct=20645
I am going to use it on my experimental aircraft (hy-tek hurricane) to power the avionics and starter. After a full night charging, I was dismayed to see only 3.45, 3.46, 3.49, and 3.51v per cell, for about 13.9v total.
Since I am used to seeing 4.2v per cell with Lipos on my R/C planes, I was getting ready to send this LiFePoS back to Hobby King!
Then I read this thread, and learned the voltage will settle down after 10 minutes of charging to right around what I am reading.
Thanks for the info! Now to finish soldering this baby in!
glassdogangle is offline Find More Posts by glassdogangle
Old Jan 13, 2015, 03:06 PM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
Looks like everyone keeps forgetting about Google. Amazing what they know.
Les
LesUyeda is offline Find More Posts by LesUyeda
Wanted Hyperion LiFePO4 9.9v 3S 2100mAh JR Transmitter Pack ohsnap Aircraft - Electric - Batteries & Chargers (FS/W) 0 Nov 21, 2010 03:24 PM
Question Max voltage for S148 servos MOTOR? gernith Radios 7 Nov 17, 2010 11:03 PM
Discussion Futaba 8 cell NiMH pack max charge voltage? venquessa Batteries and Chargers 5 Oct 03, 2010 09:19 AM
For Sale Hyperion LiFePO4 9.9v 3S 2100mah Transmitter Pack WeazyMan Aircraft - Electric - Batteries & Chargers (FS/W) 5 Sep 02, 2010 09:46 PM
Question Max voltage for 8 cell Nimh pack? mc-lite Batteries and Chargers 2 Jun 03, 2005 07:03 PM
